DCT Fluid change | Page 2 | FerrariChat
DCT Fluid change
Discussion in '458 Italia/488/F8' started by jk356, Mar 31, 2022.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,867
    Central NJ
    Dominick
    Did you look at motul high torque dct fluid ?
  2. Ferrari Car Guy
    Jan 7, 2024
    1
    Hit Newborn
    I asked my certified Ferrari mechanic for a good substitute for Shell and was told to use Pentosin FFL-3.
    https://amzn.to/3ShaVFw
  3. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
  4. Giallo27
    Giallo27 Formula Junior
    Sep 21, 2020
    264
    JB
    Whatever oil you pour into your DCT, don’t try to change viscosity as these transmissions have very small tolerances and can be affected by minor changes.
    deli333 likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,867
    Central NJ
    Dominick
    Give the high torque says specifically for Ferrari ..that would be the one I choose
    Challenge likes this.
  6. nguyennhatquang
    nguyennhatquang Karting
    Feb 13, 2016
    206
    Hanoi
  7. 458yogi
    458yogi Rookie
    Aug 28, 2022
    16
    Long Beach CA
    Sal
    Hello.! Does anybody know how to drain the DCT clutch part of the transmission?
    I referenced the workshop manual, but it makes no mention on how to drain it ( only how to fill it)
    Thank you.!
  8. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    Section C3.03
  9. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,885
    Have a quick side question
    When performing the DCT fluids change, does the rear bumper need to come off?
    Or is it as simple as removing the rear diffuser panels and the under tray?
  10. 458yogi
    458yogi Rookie
    Aug 28, 2022
    16
    Long Beach CA
    Sal
    you only need to remove the under tray and diffuser.
    Also buy this pump, it has an adapter that will make pumping the DCT fluid very easy.
    https://a.co/d/cguwbyP
    T
    he whole process is fairly simple, DM me if you’ve got any troubles
  11. hgoodwiniii
    hgoodwiniii Formula Junior
    280
    Hi everyone, I want to replace the gearbox oil in my 458. I don't want to buy a bucket of the Shell Spirax S5. I spoke to the parts department at my local dealership today and they said they carry a brand called Mcculloch (sp?). I'm wanting to ask if anyone has heard of and used this brand? Thanks.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,867
    Central NJ
    Dominick
    I had recommended in the above post Ravenol VSG -
    hgoodwiniii likes this.
  13. hgoodwiniii
    280
    Correction - My local dealership says what they sell and use is Pakelo
  14. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,425
    Tampa FL
    Same here with Pakelo. Seems to be a trusted and good product of fluids and oils. I have seen there bottles in use with the Risi Ferrari team at IMSA races.
  15. hgoodwiniii
    280
    Yeah, I asked Pekelo for a spec sheet. I don't race my car or anything. I rev it, nail it and run it hard for a few seconds now and then so I may just go with the Pekelo since it's available locally. Thanks.
    flash32 likes this.
  16. hgoodwiniii
    280
    Hi everyone, I'm trying to confirm what to expect when flushing and filling the DCT fluid and gearbox oil in my 458.
    Are you all pretty much getting 8L out and 8L in when flushing the DCT fluid and 4L out and in when flushing the gearbox oil or is there some in there that I won't be able go get out? Thanks.
  17. hgoodwiniii
    280
    Hi everyone, for the record, I was only able to get about 3.25L of gear box oil in my gearbox and about 6.5L if DCT fluid in my car after following FSM procedures and a couple of you tube videos for flushing and filling.
  18. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,425
    Tampa FL
    @hgoodwiniii thanks for the follow up. What brand fluids did you end up finding since the Shell fluids are near impossible to find and purchase.
  19. sfcarguy
    sfcarguy Formula Junior
    525
    Earth
    Redline DCTF for the hydraulic side and Redline 75W-90NS for the gears
  20. hgoodwiniii
    280
    You are welcomed. I went ahead and used the Pekelo Gear Oil and DCT fluid since it was readily available here in town. The one thing that caught me off-guard is that the guy at the dealership parts department asked if I were doing the work myself. I told him yes.
    Then he said "I can’t remember if you need to actuate any of the valves to properly flush it. DCT fluids have friction modifiers to keep the clutches cool engaging smoothly and reduce failure. You’ll want to make sure you remove any residue to prevent it from clogging anything within the system."
    I have seen no mention of actuating the valves when changing the DCT fluid anywhere else. I checked my diagnostic scanner and there is no option to actuate the DCT valves for a 458. I checked with a couple of other folks and they saw nothing that this needs to be done. I would appreciate if anyone here that may know otherwise will kindly chime in so we can all be informed. Thanks.
  21. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,425
    Tampa FL
    #46 mdrums, May 15, 2024
    @hgoodwiniii they do a DCT 458 refill on this video and show the process. They are actually fixing a cut transmission line that was leaking so past that the fill process starts around 8.55 on the video
  22. hgoodwiniii
    280
    Yes, I saw this one for sure and a couple others. No mention of actuating any DCT valves when flushing/refilling.
    mdrums likes this.
  23. hgoodwiniii
    280
    Yea, I just wanted to bring it up since the parts guy said it and to see if anyone heard of it. Thanks.
