DEAD BATTERY AND PAINT SCRATCHES | FerrariChat
Discussion in '360/430' started by fastguy1012, Feb 28, 2013.
  1. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    A luggage compartment light drained my battery completely.
    I removed it from the car and need to know if I can leave it discharged until I am ready to use the car....a few weeks to month. When I am going to use it, I will charge it and put it back in.
    AND.....
    Any advice on a good wax to use for swirls and scratches. My 360 is red.
    Your advice and opinion is appreciated.
    ANTHONY
  2. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    battery will be useless if you leave it uncharged a few months, keep it on the trickle charger.
  3. PbPedis
    PbPedis Formula Junior
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    As above, your battery will be an expensive paperweight if you don't charge it up now and maintain it. In fact, the life of it may already be shortened since it has been completely discharged.
    As for the swirls, you need more than just a wax job. A random orbital polisher with swirl remover is needed. For the price of hiring someone to do it, you can buy everything you need and do it yourself. Lots of detailing sites on the net where you can buy the stuff and learn about how to do it.
    Car Care, Detail Supplies, Garage Organization, Car Accessories - Griot's Garage 800-345-5789
    Adam's Premium Car Care - Cleaners, Waxes and Polishes Made in the USA
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    +1; lead acid batteries must be kept charged, and run through cycling like a trickle charger. I recommend the CTEK 3300 or 4.3.
    http://www.ferrarichat.com/forum/360-430/395948-diy-battery-tender-installation-f430-360-ctek-4-3-a.html
    +1; Paint scratches & swirls. Best handled by a professional, but also agree you can buy the equipment to do-it-yourself (for the same or maybe less money than paying a professional). Practice on the wife's Mercedes first ;)
    http://www.ferrarichat.com/forum/360-430/394190-diy-light-paint-correction-f430-spider.html
  5. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Just went through this, glove box light on for a week, pulled the battery out and it read 2.6 volts ! Decided I did not want to take any chances with getting stuck somewhere, sprung for a
    Sears Diehard AGM for $170, safer for passenger in case of accident and perfect fit.
    Less chance of leaks also.....
    I could of changed it up, but it was over 2 years old, and prior owner discharged it once.
    I also added a Battery tender connected to the battery buss behind the driver seat.
    These cars are power hogs and can run a battery down in a few weeks with no tender.
  6. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    With the battery issues I simply avoid it all by getting a new battery every three years and always keep it on a tender.
    And cross my fingers!!!
  7. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
  8. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,203
    Beverly Hills, CA
    Jay
    Is there a sticker with the date on the battery? If it is more than 4 years old, I'd probably can it and then buy a new Interstate when you are ready to drive the car in a few months. It's not exactly east to get to and change the battery
  9. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I recommend a trickle charger for the battery and contacting Jason of Xcaliber to handle the swirl marks. A novice with an orbital buffer is destine for a paint job.
  10. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Have you personally run into problems? I'd be curious to hear what happened. In my experience (which is limited to a few cars) I've been comfortable making careful steps with a dual action unit - and not sure why specifically to caution folks to leave it only to pros. It takes a lot of time, attention to the little details, and no one formula is going to work right off the bat.
  11. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    #11 up4speed, Feb 28, 2013
    I have found that the Random Orbital buffer from Griots Garage works great. It's VERY easy to use, and if you follow directions, and use a little care, it should be nearly impossible to ruin the paint. I've used it several times with their #3 (fine) and #4 (super fine) polish, and it works wonders. Always make sure you clay it first.
    I think they have nice videos on using it either on their site, or on youtube.
    The polishers that you definitely want to avoid, are the direct drive rotary polishers. You will destroy your paint in seconds if you don't know what you are doing.
  12. PbPedis
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    Don't know about that. Watch these videos if you have time.
    [ame=http://www.youtube.com/watch?v=2XAqpOe9Zt4]How Safe is the PC-7424XP? - Part 1 - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=y7A5BCCb7Gg]How Safe is the PC-7424XP? - Part 2 - YouTube[/ame]
  13. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    This is also my practice. A new battery is not that expensive and getting one a little early beats the heck out of dealing with dead ones.
  14. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Thank you for all the excellent help!
  15. Mo T
    Mo T Formula Junior
    Nov 26, 2011
    478
    Saudi Arabia
    Mohammed
