Dead Battery While on the Ferrari Trickle Charger | FerrariChat
Discussion in '458 Italia/488/F8' started by racerdj, Jun 2, 2012.
  1. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    I have driven my car once a week since I was released from the Doctor that did my knee replacment. I drive and then connect the trickle charger as I am not exactly sure when I will drive again. I went out today to pull the car out of the garage so I could get it cleaned for the Itallian Brunch with the Central Indiana Ferrari club. It was completely dead. I called Continental and got permission (their OK) to charge directly connected to the battery posts. Several drives ago, my I-Pod was completely dead so since then I have turned it off thinking it was doing something to the electrical system. I have 20 total drives and wonder if perhaps my battery was never up to 100%. Continental told me that the trickle charger will not bring up a depleted battery. Any advise will be appreciated.
  2. TheMayor
    106,141
    Vegas baby
    My guess is a defective battery from what you've described.
    If you've had it on the trickle and you've driven it once a week and it's completely dead, it can't be either the alternator AND the trickle charger that are both defective.
    BTW: I leave mine alone for over 2 weeks without starting and it's always started without an issue. Even 3 I think. I've never used the trickle once.
    Hope they get you on the road quick!
  3. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Suspect it is a dud battery. Mine is good for just about three weeks between drives but dead after anything more. Trickle charger solved it.
  4. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Easy to test for a dud battery.
    Good luck. Please let us know the results.
  5. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    I have a new Sears charger with many modes and microcircuits for charging. If I can't get to 100%, is it a bad battery? Is there another way to find out? Thanks for everyones quick responses. The battery is up to 70% charged.
  6. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Can the I-pod be responsible in anyway?
  7. TheMayor
    106,141
    Vegas baby
    I can't see how. You may have had a bad battery from the start.
  8. Traveller
    Apr 10, 2009
    6,323
    Tim
    I leave mine in the whole time and never caused an issue so very unlikely. I agree with The Mayor, it was a dud from the beginning.
  9. TheMayor
    106,141
    Vegas baby
    70 is BAD. 90 would be "ok".
    When you say you can't get it to 100, over what time are you charging it to get to 70? Where did is start from when you first charged it? 0? If it was zero, the battery will never come back to 100% ever...
    The starting voltage is really on the very bottom at about 11-11.5 volts in most cars.
  10. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    #10 PhilNotHill, Jun 2, 2012
  11. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    8% then 45% within an hour and now up to 73% in 2 hour charging at 40 amp setting. Still climbing but slower from 60% Also now reading 13.9 volts
  12. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
  13. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    #13 PhilNotHill, Jun 2, 2012
    Added a third which may help as well. Trickle charger should be showing 1.2 to 2 amps when plugged in. Check the specs on your charger. It takes about 7 hours to charge a 12 volt battery with a 2 amp charger. A 1.2 amp will not charge a battery that is 90% down.
    Good luck.
  14. TheMayor
    106,141
    Vegas baby
    You will need to charge it a good 4 to 6 hours more. It will get slower and slower as it climbs.
    Starting at 8% is really bad. Most likely, the battery has had some damage now. The question is how the battery got to 8%. That part, I do not understand as you say you drove it once a week and trickle charged it. Something does not add up. You may have an electrical problem.
  15. SmokeyJoe
    SmokeyJoe Karting
    Mar 4, 2012
    218
    Had a similar problem today. Wanted to take out my beloved Spider for a ride but it did not start after only 3 days in the garage. Battery was not dead but below 11 which was not enough. I have now connected the trickle charger and the car should start ok tomorrow again (had this issue before).
    Three days is obviously way too short so I wonder what could deplete the battery so fast? (or the battery is damaged). I had removed my Ipod so this was not the issue.
    I have spoken directly with Ferrari in Maranello about this problem but clearly I am not the only one.
    I will take the car to the dealer next week to see what is going on.
  16. TheMayor
    106,141
    Vegas baby
    Wow three days... that's bad. Let us know what the situation is.
    I have often wondered if switching to a higher capacity battery would help this. In my Maserati, I put in a Interstate Megatron and it's absolutely the best battery I've had for long term storage problems. No other battery even comes close, including Optima (which ironically was one of the worst).
  17. Cavallino 458
    Cavallino 458 Karting
    Jun 24, 2008
    144
    Australia
    Vic Rob
    Bob, that seems unsual to be able to leave your car without the trickle for 3 weeks and it still starts. I presume you don't lock your car when its not used. Locking the car does draw substantially more on the battery even with the trickle charge on.
  18. mhh
    mhh F1 Veteran
    Feb 16, 2004
    5,894
    Australia
    Mark
    I accept what you are saying but I'm not sure why a locked car uses more power than an unlocked one.
  19. Cavallino 458
    Jun 24, 2008
    144
    Australia
    Vic Rob
    The head mechanic at our dealership explained to me that it has someting to do with the additional antitheft systems (internal motion sensors and anti-lift system) being activated when the car is locked. I'm sure there is other program issues that are activated but there is certainly a marked difference between locked and unlocked.
  20. TheMayor
    106,141
    Vegas baby
    No, I put on the alarm and lock the doors. It's never had a problem starting.
  21. TheMayor
    106,141
    Vegas baby
    I think it's because you are activating the alarm.
  22. Cavallino 458
    Jun 24, 2008
    144
    Australia
    Vic Rob
    Ok, that's interesting - I wonder if the trickle then is perhaps the culprit!!
  23. TheMayor
    106,141
    Vegas baby
    I have no idea. I can't charge it in my condo complex and when I travel, it just sits there. I'll be back home next Saturday afternoon and that will be a little more than 2 weeks since the last drive. It's not unusual for me as I travel a lot.
    Mine's a 2012. I don't know if that matters but maybe they did some software or hardware to improve it. Or, maybe it's that the battery is still really new.
    BTW: I never had this problem with my F430 either under the exact same situation for 3 years. I never had a dead battery once, but the dealer did replace it about 2 years in because they found a small leak during it's annual.
    *Covered under warranty which was cool.
  24. Cavallino 458
    Jun 24, 2008
    144
    Australia
    Vic Rob
    Yeh, mine's a 2012 as well so no issue with longevity. I might try not using the trickle like you and see if there is a difference.
    Also, are you saying you that can lock the car without activating the alarm?
    Cheers
  25. TheMayor
    106,141
    Vegas baby
    No, I just do what I normally do with the remote. The alarm is on. I never tried it by just using the key.
    My understanding is that if you start a car, it takes about 20 minutes at idle to make back that lost energy. That may be old data but that was the rule of thumb I used in the past.
    So, if you start the car and let it run a few minutes to charge, you're not really doing much of any good aside from warming it up.
