Dead battery | FerrariChat
Dead battery
Discussion in '296' started by Fred’s 296, Dec 8, 2024.
  1. Fred’s 296
    Fred’s 296 Rookie
    Dec 8, 2024
    1
    Frederic Poulin
    Canot open door.. car battery is dead..
    How can I open it from outside!!
    Nothing happened with key?
  2. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,879
    France
    Stupid question (which refers to the following, not yours) - did you try the so-called "emergency key" which should be "supplied with the keys" according to the manual ?
  3. ntatfas
    ntatfas Formula Junior
    Apr 27, 2011
    286
    Once you find the emergency key, the lock is underneath the door handle.
    Do not attempt to turn the car on unless you want to be greeted, depending on remaining charge, to a barrage of "everything is wrong" messages. Do not try and "jump start" the car but put the battery (passenger foot well) on a slow trickle charge using a NOCO or similar.
    Best of luck.
