Dead cylinder: My Lotus for sale
Discussion in 'British' started by thecarreaper, Apr 7, 2012.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. thecarreaper
    thecarreaper F1 World Champ
    13,989
    southeast
    name
    #1 thecarreaper, Apr 7, 2012
    After changing fluids , filters, plugs and wires i could not get rid of the ignition miss this 1990 Esprit SE has at idle. We took the engine lid off and sent it to our shop to do the timing belt service and diagnose the miss. #3 cylinder has a burned valve.
    Car runs and drives, does NOT smoke, nor does it leak into the crankcase, so the bottom end seems solid. great oil pressure, runs cool, no check engine light.
    I paid $10700 at an auction through a licensed GA car dealer buddy of mine, car has a clean clear Title. i have about $13k in the car and want it gone as is. I will put on the engine lid and reinstall all the panels we took off. I dont have the time or energy to mess with a project as i am going to buy something else and go back to school part time.
    I will post an ad in Ferrari.ads, Ebay and both the Lotus message boards i am on.
    **Make offer**
    Michael zip code 31407
  2. MITYRARE
    MITYRARE F1 Rookie
    May 21, 2008
    2,611
    Canada
    As an Esprit owner I think you are being very optimistic regarding price given the situation.
    beev
  3. thecarreaper
    13,989
    southeast
    name
    What part of *make offer* do you not understand?
  4. full_garage
    full_garage Formula 3
    Rossa Subscribed Owner
    Feb 15, 2010
    2,173
    Metrowest Boston
    Jay
    Geez kind of uncalled for given the guy DID NOT NAME a price..no?
    Michael- I'm sure you'll move this and be done with it- but you kinda could see this one coming... For all our *****in about Fcars- The Lotus thing requires an entirely new understanding of the word "patience".
  5. GuyIncognito
    GuyIncognito Five Time F1 World Champ
    59,781
    Floriduh
    Chas
    do you still have those black (green?) X180R wheels? those chrome ones don't float my boat.
    also, any other glaring faults on the car? electrical (duh, it's a Lotus), gearbox/clutch/flywheel, suspension/bushings/shocks, etc etc etc.
    and, any idea on parts availability?
  6. agup48
    26,142
    Phoenix
    AG
    Uh oh, another car purchase?! :D
  7. Tired of seeing this ad? Upgrade now
  8. GuyIncognito
    59,781
    Floriduh
    Chas
    I'm a sucker for a green Lotus
    :eek:
    problem is I have nowhere to put it.
  9. agup48
    26,142
    Phoenix
    AG
    I have a parking spot! :p
  10. thecarreaper
    13,989
    southeast
    name
    What is wrong with you you guys?
    Make offer means just that. $2.00 , $8500, ??????
    I dont know or care what the market value is of the car. i have the 308 and the 911 so i want this car gone. Ill put it on Ebay no reserve if no one here or on the Lotus boards wants it. SJsports cars UK has all the parts needed, piston rings (while you are in there, change them) bearings, all engine gaskets, send the head off to a machine shop for valves and you are done. we estimate about $3000 parts and labor ( my price as i am affiliated with the shop).
    i just dont want the damn broken car.
    http://www.sjsportscars.co.uk/index.php?mod=9
  11. thecarreaper
    13,989
    southeast
    name
    #10 thecarreaper, Apr 8, 2012
    the car runs well, we think that cylinder is firing under load from the turbo, but at idle it has a miss.
    The gearbox feels great, I have tags and insurance on the car and have driven it some, but I did not want to hurt anything with the weird idle. I changed the oil as soon as the car was delivered, as well as the coolant in the engine and the charge cooler.
    I have a factory Lotus non airbag steering wheel for the car, the other set of 4 x180R wheels, some gaskets, a charge cooler pump rebuild kit, and the new drivers side door handle.
    Drivers side window does not work, nor does the left headlight. i think the switch needs to be cleaned for the window, and the headlight motor plastic gear needs to be replaced with a kit for a Firebird and it will work. car has spare, jack and tool kit. Georgia title is clear in my name.
    SJ Sports Cars (UK) and JAE in California have all the parts and gaskets.
    Oil pressure is great, temps stay nice and cool, car does not smoke nor is the check engine light on. Brakes and suspension feel fine.
    To properly fix it before something breaks will require a valve job.
    While the head is off its no big deal to drop the oil pan and replace the rings and rod bearings.
  12. finnerty
    finnerty F1 Veteran
    9,081
    indeterminate
    David
    #11 finnerty, Apr 8, 2012
    Michael ---
    If you have any interest in selling that OEM steering wheel (non airbag) separately, please send me a PM :) It looks like the wheel you have mounted on the car now is one of the later (airbag) OEM ones for the V8 Esprit --- is that correct ???
    If so, I assume the non airbag wheel will also fit on the V8 cars ??? (I have an '03 V8 and am wondering whether it will fit my car).
  13. MITYRARE
    MITYRARE F1 Rookie
    May 21, 2008
    2,611
    Canada
  14. Tired of seeing this ad? Upgrade now
  15. thecarreaper
    13,989
    southeast
    name
    I have an adapter to use the non airbag wheel on an airbag car. we think the steering column is a Range Rover, as they changed the steering column completely in 1990 with the arrival of airbags. I dont know what wheel will fit the V8 cars, and to be honest i am going to keep everything as a package. its a very nice car, love the color, i just dont want any projects cars.
  16. thecarreaper
    13,989
    southeast
    name
  17. thecarreaper
    13,989
    southeast
    name
    Car is $8500.00 firm.
  18. GuyIncognito
    59,781
    Floriduh
    Chas
    dammit, just bought another proejct car a few weeks ago, no time, money or space for this one....otherwise I'd be on it like stink on Ashwin.
    GLWS....I'm jealous :(
  19. whatspeedlimit?
    whatspeedlimit? Formula Junior
    350
    Denver, Colorado
    I know it sounds too simple to help; but you should try using Seafoam. I had a burned valve in a 62 super 90 and we seafomed it like 3 times and that valve came loose and worked fine! We ended up rebuilding the engine because it had a bearing that was failing but it did seem to fix the problem.
  20. thecarreaper
    13,989
    southeast
    name
    Thank you. But it failed compression and leakdown, so we feel its best to assume it needs rings and a valve job.
    I dont want the car anymore.
  21. thecarreaper
    13,989
    southeast
    name
    Car is staying with the shop that did the inspection.
    Car is off the market awhile.
  22. dwhite
    dwhite F1 Rookie
    Remember what does "L-O-T-U-S" stand for. I love British cars, but they can give us grief. Good luck on whatever you decide to do with her.
