Decent flash/tune for 612? | FerrariChat
Discussion in '612/599' started by danmano, Aug 3, 2020.
  1. danmano
    danmano Rookie
    43
    San Francisco, CA
    Danny Manoukian
    Has anyone modified their 612 for more power? Was it worth it, and what company did you go with?
  2. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I did it on my FF with eurocharged. Those guys are great but I didn’t notice much difference to justify the price. Mostly turbo engine gets the most out of tunes.
    danmano likes this.
  3. ttforcefed
    ttforcefed F1 World Champ
    19,257
    MASE shld be able to do it no?
    danmano likes this.
  4. randkin
    randkin Formula 3
    1,497
    Somis, CA
    Randy
    I would think that may hurt the resale value if that is important to you?
  5. Natkingcolebasket69
    It’s reversible and I’m
    Not sure how one could tell
    danmano likes this.
  6. brogenville
    brogenville Formula 3
    2,268
    Robin
    A tune will wake up a 612. You can improve the fueling to favour max torque through the rev range, tweak the ignition a bit to be less conservative, and remove the torque demand delay that Ferrari put into early cars. This last bit makes the biggest subjective difference, as you’ll feel more “connected” to the engine.
    I would personally advocate Trev360 on here as the person that understands this stuff better than anyone else outside of the original development team. Trev is super busy, but as an “affiliate”, you can send me your ecu’s and I can load them up with a tuned flash file.
    -K1- and danmano like this.
  7. FIN612
    FIN612 Karting
    May 10, 2017
    118
    Finland
    + the rev limiter increase to 8,000rpm :)
    danmano likes this.
  8. danmano
    danmano Rookie
    43
    San Francisco, CA
    Danny Manoukian
    Hello Brogenville,
    Thank you for your response. I PM’d you
  9. danmano
    danmano Rookie
    43
    San Francisco, CA
    Danny Manoukian
    Hi FIN612,
    Can I ask which tune you went with? Much appreciated.
  10. brogenville
    2,268
    Robin
    This sounds fun! You quite happy that the valve springs can take those revs? You find the engine is still building power at those revs?
  11. tazandjan
    39,191
    Power will drop off rapidly above 7250 rpm. Likely slower shifting at 8000 rpm than at 7500.
  12. FIN612
    FIN612 Karting
    May 10, 2017
    118
    Finland
    612 has 300rpm lower limiter than 575. 8000rpm is not a prollem. 6-1 headers and high flow cats improve breathing at high revs. Pulls very hard up to 7940 where tune starts to limit a bit ( dyno checked ) . These are all 8K shifts: tps://www.youtube.com/watch?v=zN8ldgAKzYI
    Makuono likes this.
  13. Makuono
    Makuono Formula 3
    1,008
    Ricardo
    This sounds like fun! Is there any available dyno data sheet to compare against stock?
  14. brogenville
    2,268
    Robin
    Interesting on the rev limit- I feel cheated now knowing the 575 gets a higher cieling!
    I suspect that the 6-1 manifolds are making quite a big difference though on high RPM performance.They also sound pretty good too. :cool:
  15. FIN612
    FIN612 Karting
    May 10, 2017
    118
    Finland
    Sound:
    danmano, brogenville and Makuono like this.
