Decided to give my F355 Berlinetta some TLC..... | Page 11 | FerrariChat
Discussion in '348/355' started by 275GTB, Apr 8, 2014.
  1. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #251 275GTB, Mar 13, 2017
  2. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #252 275GTB, Mar 13, 2017
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    those white ceramic headers will look sweet in the engine bay.
  4. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #254 275GTB, Mar 13, 2017
    RWP137 and crinoid like this.
  5. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #255 275GTB, Mar 13, 2017
  6. 308 GTB
    308 GTB F1 World Champ
    11,659
    New Jersey
    Barry Wolinsky
    #256 308 GTB, Mar 13, 2017
    Right. Those headers look great!
  7. MAD828
    MAD828 F1 Rookie
    2,619
    Elliott Caras
    Nice to see you back, I took inspiration from this thread when completing my own restoration. You will love the Tubi Evolution exhaust.
  8. GSF355
    GSF355 Karting
    54
    Brisbane
    Great thread! I've just read it from start to finish... Looking forward to more updates.
  9. yvesolution
    yvesolution Karting
    Apr 26, 2010
    182
    Cabo Verde
    tidy looking car! Many thanks for the pictures!
    What are the reason(s) that you chose a Tubi and not a Capristo?
  10. yvesolution
    yvesolution Karting
    Apr 26, 2010
    182
    Cabo Verde
  11. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    Hi, thanks!
    I have always fitted Tubi systems to my cars, really like the quality, fit and off course the sound......plus i had bought this system at a good price ages ago, it was sitting in my store waiting for the right car to come along.
  12. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #262 275GTB, Mar 25, 2017
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    sweet :)
  14. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    Looking good!
  15. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    Cheers Travis, and thank you for all your help!
    much appreciated
    Mark
  16. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,119
    Fort Washington, PA
    John S
    That's why I am here my friend! Anytime.
  17. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    #267 275GTB, Apr 2, 2017
    Hi
    As you know I have fitted Fabspeed manifolds, connected to Larini de-cat pipes, connected to a Tubi Evo exhaust box. Which all sounds incredible!!
    The de-cat pipes still had the pre & post o2 sensors, along with the original thermocouples and OEM CAT Ecu's.
    So I decided to install Gothspeed CAT ECU replacements and completely remove the thermocouples, replacing them with the Gothspeed End Caps....problem solved.
    The cap nut: https://www.ricambiamerica.com/gs179-cap-thermocouple-bung-cap.html
    and the ECU: https://www.ricambiamerica.com/gs179278-catalyst-temp-ecu-simulator.html
    All designed and manufactured by Fchat's very own, Gothspeed, in California, available through Ricambi.
    I also have the OEM exhaust valve connected to the Tubi - which I am keeping the same.
    Just to go a bit further I fitted Fabspeed's 90 degree offset tubes for the post o2 sensors. This will keep them out of the exhaust gas stream.
    Universal O2 Spacers with Catalytic Converters - Fabspeed Motorsport
    Flashing lights and errors are often caused by malfunctioning CATs or Thermocouples, since I dont have any CATs, using Goth's ECU replacement sends a signal to simulate that the CATs are operating in the correct temperature range.
    The post o2 sensor tests the exhaust gas, part of the process to check that the CAT is operating correctly and cleaning the exhaust gases. To avoid error codes, the post o2 sensor needs to detect fairly clean gas. To help this process, getting the post o2 sensor further away from the exhaust gas stream by using the Fabspeed 90 degree o2 Spacers with Catalytic Converters pipe.
    Plus they are soooooo beautifully made and look fantastic!
    here is everything you need....
  18. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
  19. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  20. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    Hi, took the 355 out for a blast at the weekend, but before we went, i thought i would do a long overdue job - fit the fire extinguisher. Thought it would be a pain of a job, finding a suitable place, drilling holes to mount the brackets etc....
    Turned out to be dead easy, i didn't even use the brackets, instead used the seat adjustment bar on the passenger seat, the seat stays in one position anyway.
    Just put a sleeve of rubber tubing along the seat adjustment bar, slipped the metal straps around the bar and locked in place. absolutely rock solid and very tight, so no fear of it coming loose Image Unavailable, Please Login Image Unavailable, Please Login .
    RWP137 likes this.
  21. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Beautiful color. Is that blue scuro mica?
  22. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    thanks, Le Mans Blue
  23. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Do you know the paint code? That is a great dark blue.
  24. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
  25. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,965
    London
    Mark McCracken
    Hi guys, I haven't used the car much this past year, I got kinda side tracked with an arrival,or two....my little twin boys!
    I have now finally caught up with everything and can get back to some car time and some updates and fun ;)
    MikeeB355 and MAD828 like this.
