Decided to give my F355 Berlinetta some TLC..... | Page 8 | FerrariChat
Discussion in '348/355' started by 275GTB, Apr 8, 2014.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Knuckles
    Hub carrier
    Bleedin yanks!!!
    Only kidding
    Don't flame
  2. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    Ah ok, got you! I rubbed them down, used a wire brush and a wire wheel in places. Cleaned everything off with brake cleaner, then gave them a few coats of Wurth Automotive silver aluminium paint. I done all this while on the car, without removing the hubs - its not 100% perfect refurb, but every area that is visual through the wheel is looking very sharp.
  3. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #178 275GTB, Jun 7, 2014
  4. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Exact same carpets on mine.
    I have a 1995 M2.7 GTS...blue swaters and ivory.
    Put this on your list if i can suggest....
    Check or just replace the plastic pipe, 2 gaskets and clamps that connects the fuel filler neck to the fuel tank...there has been a fire in the states recently due to this plastic pipe being porous, cracked or split.
    I do not fill mine up to the brim...do not want fuel in that little bit of pipe..just in case..it sits right close to the manifold...heat and fuel not a recipe for happy days.
    Keep the photos coming.
    How's your headlining?
  5. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #180 275GTB, Jun 10, 2014
    Hi, I checked out the fuel filler pipes. I gave them a clean and a very close inspection, they look to be in perfect condition, with no damage or fuel odour around them. I suspect they have been changed in the past.
    One thing i did notice, the large pipe is very close to touching the feeder pipe for the rad. I was not happy with this, my fear being vibration or movement could rub a hole in the pipe. Just for a little extra protection i fitted a sleeve around the fuel pipe using a length of large radiator hose and two tie pulls - picture below.
    (Still think i will fit a fire extinguisher for peace of mind!)
    The headlining - i have posted a picture, it a beauty. A factor option in Cream Leather:
    D5 Ceiling in Cream Leather 3997
    I have not cleaned it yet, but given the car has never been smoked in, a gentle clean with Saddle soap will bring it up like new.
    And a new battery about to be fitted before i finish off the arches and put the wheels back on.
    cheers
    Mark
  6. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #181 275GTB, Jun 10, 2014
  7. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #182 275GTB, Jun 12, 2014
    Hi,
    I managed to buy a good replacement electric air pump. It was very clean when it arrived, but i had half an hour spare so i washed out the filters, repainted the brackets, and replaced the screws and nuts - looks like new now! And blows a strong stream of air, with a very quiet motor.
    cheers
    Mark
  8. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Super work Mark.
    How's the large bracket to which the air pump and solenoid switches mount?
    Bet you will clean that up!
    May i suggest a Capristo bypass valve from Germany?
  9. cuneo
    cuneo Formula 3
    2,487
    That was me with the 355 fire in the States, and I was lucky enough to spot it and pull over in time before it touched the timing belt covers. Not a mark! If I were you I would definitely change that fuel-filler hose and all associated hose clamps/gaskets as it seems like that was the cause of the fire at this point, and mine looked like new until things went awry.
    Absolutely be sure to put a Halon or similar extinguisher in your car, at least 2 pound size, just not the dry-chemical variety, very corrosive to aluminum and electrics.
    It would be such a shame to lose all your hard work because of something as simple as not having a fire extinguisher in your car. I'm just lucky the PO of my car had done it, because I probably wouldn't have on my own.
    Your car is amazing by the way!!
  10. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #185 275GTB, Jun 13, 2014
    Hi, yes I will definitely be fitting a fire extinguisher, i may even fit a plumbed in system similar to what i have in my rally car.
    Very happy you and your car are ok!
    all the best, Mark
  11. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    Hi, I will get round to that shortly when i refit the pump, but it looks pretty good, just 17 years of road dirt and grim, but no corrosion.
    The car had a new valve fitted when Verdi fitted the Capristo exhaust for the previous owner, she has only done a few thousand miles since.
    cheers
    Mark
  12. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Problem....
    Halon is banned in Europe....banned for years now.
    Do you know of an alternative that won't do any harm?
  13. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Oem valve or the more robust capristo was fitted?
  14. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
  15. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    Great thread thanks for posting! That blue is to die for.
  16. Steve Harkness
    Steve Harkness Formula Junior
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Erm still waiting on u no what !
  17. Steve Harkness
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Hey Mark have you gone into hiding? Also is that a mark 1 escort rally car? I'm getting very jealous and will need to pay you a visit next time I'm in the uk!!
  18. Steve Harkness
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Got my floor mats today Mark exactly the same as yours. Fantastic fit and extremely well made! I also purchased a used Mille Miglia f1 exhaust and carbon fibre door sills and I'm going to do a buttress repair over the next couple of weeks. Guess I have the tinkering bug after reading this thread!!
  19. Thomas Iannella
    May 12, 2014
    8
    hi;
    great job. I love the seats. I have a 1995 F355 Spider and my seats are getting a little tired. where your seats re-upholstered or brand new. if new, who was the supplier?
    Tom
  20. Thomas Iannella
    May 12, 2014
    8
    sorry I meant "were?
    tom
  21. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    Hi, just a one off set i found in storage for the last 17 years, taken out of a car when nearly new, as it was getting turned into a race car. Totally original, just cleaned very well, with a tiny amount of re-connalising to remove some storage marks.
    cheers
    Mark
  22. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    What u up to Mark?
  23. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    hi, been busy on other things, hopefully get the cover off the car today and get stuck in again!
  24. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,968
    London
    Mark McCracken
    #199 275GTB, Jul 16, 2014
  25. Steve Harkness
    Jul 28, 2012
    448
    perth Australia
    steve Harkness
    Jesus,Mary and Joseph !!! You have great taste just like me. Being Irish I'm an escort nut job.in the good old days I had a Mexico and then a mk 2 rs 1800. I currently have my eye on a ford anglia over here at the minute which needs some TLC but the missus says if I buy anything else she's leaving !! Looks like it's coming home hee hee
