Degreeing cams | Page 9 | FerrariChat
Degreeing cams
Discussion in 'Technical Q&A' started by fatbillybob, May 2, 2007.
  1. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    A long time Fcar mechanic showed me something he learned at the factory. Once the timing is set so close that moving the locating pin one hole is too much you can loosen the can sprocket locking bolt and then slightly rotate the crank in the direction you need to correct just enough to pull tension on the sprocket. Tighten the sprocket bolt before releasing the tension. This will give you a few more thousands of correction.
  2. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Aaaand I was wrong. I got it just about exactly right, well within spec. Just took more time than I wanted it to!
  3. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Yes, that would be akin to loosening the cam bolt and tapping the cam with the rubber mallet while the dowel is still in; there is a little wiggle in the dowel. That's how I got it! :)
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    One more trick to add to the bag.
    Thanks Joe and Pete.
  5. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    It is time for a major, prior to offering up the car and I just printed out this thread to try to be able to get it right.
    Having never dialed in the cams, I am looking forward to the process and getting it timed right, (euro spec) for the next caretaker.
    This forum was the reason I felt comfortable enough to buy a 308, and I am still leaning on it and loving it.
    I must scale it back a bit, moving into retirement, wish I had been a bit more clear sighted about the future costs, but ah hell, it is what it is.
    Looking forward to studying the collective wisdom re: timing.
    Thanks Guys,
    chris
  6. fatbillybob
    Aug 10, 2002
    28,693
    socal
    #206 fatbillybob, May 4, 2015
    What I do is widget the crank at TDC as close as I can get to dead on TDC. I find that if I hold pressure on the breaker bar at TDC for a couple of seconds the crank will stay. Besides after you set the cam cog pin you need to drive the crank in the driven direction through the entire cycle carefully holding the breaker bar at TDC without letting go then recheck the dial gauge to see the cam in on target. It is a confirmation check. If it is OK you can torque the cam bolt If it is not then you tweek 1 cam cog pin either way and try again going one more full cycle to see if you are not within spec.
    You do not have to do this at all. Once you got the timing right as I stated above you can torque the cam bolt. When you go in the driven direction one full cycle again the dial gauge should be in spec at TDC. Now move to the next cam.
    By the way the delrin faced mallet has become my friend about half a dozen years ago. It makes pulling pins with just the fingers and moving the cam shaft as needed to install pins to get the right dial gauge readings easy. I got too much rebound with rubber mallet and needed too much force. Delrin face makes for very light gentle taps.
  7. fatbillybob
    Aug 10, 2002
    28,693
    socal
    It just goes to show you how precise this process is. When done in this way you can tune +/- 2 cog holes and the assembly marks do not appear to move. That's why I think the cam timing scribe marks at the back of the head are just about useless when you consider not only the issue with +/- 2 cog holes but also parallax reading error in a mirror. It is no wonder that so many cars I have done in the past using lobe centerline method appear dead on the assembly marks. The 550's bucket lift is something different. There is much more tweeking of the cog pins to meet the Ferrari bucket lift spec than a calculated lobe centerline. But at this point I don't think it matters much because cam timing is a compromise setting. The last few degrees only means something in racing where you would tweek timing and test for many conditions on many race tracks and then set up cams for those varying race conditions.
  8. Rifledriver
    36,855
    Well for that answer you need to calculate how much .015 is in degrees. they give you +/- 1 degree and it is achievable. Sometimes no hole will line up within that. I just take the sprocket off and relocate it and try again.
  9. Rifledriver
    36,855
    That works to some level most of the time. Some cars the hole/pin is a loose fit and you can get an entire degree, sometimes nothing but it is always worth a try. I cinch the bolt while turning in the direction desired.
    Some of the motors have holes drilled around the entire circumference of the cam and the sprocket. Those are pretty easy. Some of the 8's and the flat 12s had three holes and they can be an exercise in removing and relocating sprockets.
  10. fatbillybob
    Aug 10, 2002
    28,693
    socal
    The 550 looks to be drilled 360 degrees around but there is one dead hole and it seems the one you need ends up there all to often. I hate that.
  11. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Brian,
    Indeed, I was able to get it torqued exactly in spec; I detailed that in my other thread. Thanks for the help!
    PK
  12. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    Yeah. Until it's not in spec.
    The whole point of the exercise is that the cam needs to be in spec AFTER the cam bolt is torqued. It can be in spec before you torque the bolt, but the process of torquing the bolt will often lock the sprocket to the cam out of spec. After you have torqued the bolt and you rotate the engine over again and return for a second measurement, the cam is out of spec again. That's because the torquing process allowed the cam to move slightly relative to the sprocket.
    The way I got around this with my car was to set the cam further out of spec than it should be prior to torquing, which allowed for the slight shift in the relationship of the cam/sprocket during torquing. Now that the bolt is torqued, I can repeatedly turn the engine over and measure the lift at TDC to be exactly what spec says it should be.
  13. fatbillybob
    Aug 10, 2002
    28,693
    socal
    I did not have that problem maybe because I do weird shizz with matchbook covers and lock down the cams before I torque them. I also measure with the orings out and cambolts in hand tight with a palm ratchet. I'll pull the bolt, tap with mallet, finger pull a pin, replace the pin to where I want, hand tight the cam bolt now read the gauge and spin the motor to confirm, then lock the shafts down and use a torque wrench not the impact gun.
  14. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    #214 Robbe, Oct 12, 2015
    First of all, great post and really informative. Finding TDC was easy with a glassfibre rod on the piston and a guage.
    But I have a question regarding finding the start of the opening of the intake valve.
    When turning ClockWise as mentioned, and as suggested (rotation arrow)by the degree wheel, the first action to start on the degree wheel is the exhaust valve moving, not the intake valve!
    So should I turn Counter Clock wise for intake valve action? Or turn an almost whole cycle of say 300 degrees to see the intake valve open? That would mean that the TDC is not the TDC of the cycle that pushes out the burnt gasses, so the wrong one.
    Turning CCW should see the first action as "end of closing" of the intake valve, so that would not be 28 degrees I would think.
    I am sure I am missing something here, but what?
    and on TDC, the marks are off by more than I expected. Is this normal? As much as 10-15 degrees off on the degree wheel! I have checked TDC several times, in more positions of the rod on the piston, as straight as possible (pic shows crooked setup, but still gave same reading)
    I have not measured the degrees of opening and closing of the intake as I first wanted to know how to measure, Cw or CCW for the intake.
    Please enlighten me some more! Thanks.
  15. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I haven't read this whole thread so I'm not at all certain about this, but it sounds like you might be at TDC on the compression stroke when you're wanting to be at TDC on the exhaust stroke? See if rotating the crank 360 degrees puts you where you want to be with the cams. Remember that the cams turn at half crank speed, so rotating the crank 360 degrees will move the cams 180 degrees.
    FWIW, I'd look for a more accurate way of determining TDC before actually timing the cams.
    Good luck!
  16. Robbe
    622
    The Netherlands
    Thanks!
    As the marks on the cams are only about 4-5 mm off, I assume I am on the right cycle, as another 360 turn of the degree wheel (and crankshaft) does not show marks on the cams.
    Still puzzled...
  17. mwr4440
    57,858
    Bavaria, The 'Other' Germany
    Mark W.R.
    Two 360's on the crank = one 360 on the cams.
    To get the extra 0.5 - 1.0* +/- or anywhere under on the cam, I use my wife's nail file on the pin. Very Slight sanding makes a very Big difference.
    But don't tell her that.
  18. Robbe
    622
    The Netherlands
    Sorry, but I do not understand it?
    Thing is that I am sure I am on the right cycle (as the cam marks almost line up, 4 to 5 mm apart, on any other cycle they would not even be visible), but when turning CW I first encounter an exhaust valve movement on the degree wheel. When I should encounter an intake valve action...
    Could it be that the degree wheel is a mirror image from what is needed with this engine?
    It is normally used for US V8's with a central camshaft.
  19. phrogs
    phrogs F1 Veteran
    7,322
    Michigan
    If you turn your crank 360 degrees once your camshafts have only spun 180 degrees that's why you don't have cam marks after one spin of the crankshaft.
  20. Robbe
    622
    The Netherlands
    I do have cam marks, only they are 5mm off! And that is a lot I think, could well be 20 degrees on the crank/degreewheel.
    I have to admit that the picture of the marks is not that clear, but if you look carefully at the pic you can just see a faint mark about 5 mm off. The mark (on the cam) is filled with oil, so a bit shallow and not visible well.
    But it is there, and 5mm off. To me that sounds like way, way too much off.
    Anybody ever seen a mark that much off, after having checked TDC like 10 times?
    Maybe I better check on cilinders 5-8 first, to see how they are tdc and marks wise.
    Maybe my 1-4 belt has jumped a tooth before (not on the current set of belts and tensioners, they look good and within spec.
    As far as I know there are no factory tdc marks on the flywheel on a 355, right?
    The pm 1- 4 and pm 5-8 are from other models?
  21. Rifledriver
    36,855
    #221 Rifledriver, Oct 13, 2015
    Something is very wrong with your procedure. The marks cannot be that far off.
    The process is very simple. Find and mark TDC. Turn the motor to TDC overlap and check your degree wheel adjustment. Turn it back until the intake valve is closed +20 degrees or so. Set dial indicator on intake cam follower exactly parallel to valve stem with indicator set to 0. Turn motor in direction of travel until the valve is open the amount shown in the service manual. At this point the motor should be at TDC. If not readjust sprocket as required. Once you think you have it test 5 or more times for an average because the cam follower often turns slightly upsetting the measurement.
    On the exhaust side start at TDC and measure how much the valve closes.
    It is really that simple. If it does not come to you seek help from someone who has done a bunch of 355's.
  22. Robbe
    622
    The Netherlands
    I agree, something is not right at all.
    This is my procedure for finding TDC:
    - In the plug hole of cilinder 1 I have inserted a glasfibre rod, that rests on the top of the piston.
    - the dial gauge is connected to that rod. The dial gauge is stabile, see pics.
    - I have turned the crank clock wise till the marks on the cam caps and the cams line up.
    - then I have turned the crank CCW some 30 degrees, and have watched the dial hand move as the rod is being pushed upwards, translating into hand movement on the dial.
    - the hand stops moving when the piston is on its highest point. Overshoot, and turn CW. When the hand stops moving again (highest point piston), then I have set the pointer on the degree wheel to the TDC mark.
    - next step is turning the crank CCW and CW to find the real TDC without the slack in the connections. When done, that was my real TDC. Slack was only 1 degree by the way, so never of influence to the present problem. Crank left at TDC.
    - then I looked at the marks on the cams , to notice they were 5 mm off, and not 1 mm or so which I had expected...
    - engine was running before service. Would an engine with a skipped belt tooth on one bank be running? Because that is what I think has happened in the past. The present set of belts and tensioners is ok, tension at 2.5 mm, belt not dry, service was just because last date was not known to me. I just wanted to see if the cams needed degreeing, but now I am unsure what to do next.
    - would correcting 5 mm on the cam (25 crank degrees??) be lethal if I would have made a mistake somewhere?
    In other words, should I correct it or not?
  23. Rifledriver
    36,855
    I cannot watch over your shoulder so I cannot comment on your process.
  24. Robbe
    622
    The Netherlands
    Thanks for the info, that is indeed also a good way to find TDC. I will look in the WSM to find the amount it has to be open, I have seen the table somewhere over here as well I remember.
    I will be working on it tonight, will post my findings.
  25. Rifledriver
    36,855
    If you were not doing that, what were you doing?
