delayed start | FerrariChat
delayed start
Discussion in 'Technical Q&A' started by rob lay, Dec 14, 2021.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    sorry off topic, but this is the best place to ask for my 2012 Toyota Tundra. starting a few months ago my key turn start delays a little, but so far has turned over every time.
    is this an obvious symptom that points to battery, coil, or starter?
    I've thought about taking the battery into auto store for test, but won't waste time if it is coil or starter. No other signs weak battery, doesn't matter if it has sit for 2 weeks or I just drove it hours on the highway (obviously alternator fine) it behaves exactly the same with key turn plus no dim lights etc.
    You turn the key and now just a little delay and then it seems like a struggle to turnover, but always has so far. Not necessarily getting worse over last 2 months.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Measure voltage ..resting and starting and running and report back
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    I would also check voltage drop when cranking.
    If your car is diesel, there are quite a few pre-heating components that do not last forever. A relay made my cold mornings miserables for several weeks...
  4. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    it is just the Tundra V8.
  5. Steve Magnusson
    26,932
    How old is the battery?
  6. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    who knows, 2-3+. also not my DD, so goes a week at time without driving.
  7. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    CCA probably getting too low (on the battery)(cold cranking amps), sounds like it is marginal, best to replace the battery, suggestion: batteries plus (if you have one in your area) they will change it for you and they can test it too before changing, no fee, nice and simple
    {and no amount of charging it going to help if CCA is marginal, it means the cells are going bad}
    rob lay and PaulK like this.
  8. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    I would start with this first. It sounds like a discharged battery. Go with the cheapest and easiest solution first. If the battery is in good condition and is fully charged you can then go into measuring the starter draw (in amps) or voltage drop.
    Please note that this is for Ferrari technical discussion and since this thread is about a Toyota I will have to report this thread to the moderators. :p
    JTSE30 and rob lay like this.
  9. Steve Magnusson
    26,932
    Never good for extending battery life. One thing beyond the diagnostic voltage measurements that Dominick mentioned would be to measure the parasitic current draw at rest (but since it has been starting after a week of disuse, you probably don't have a serious issue there, but any added electronic stuff might have increased it a little). You may be caught between the trade-off of messing with a battery tender or just replacing the battery more often than is typical.
  10. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    I'm thinking bad battery.
    I just took a battery in to NAPA that measured 12.5-13 volts to be tested, they have a tool that can measure CCA and it was only 300 where is should have been 1425 CCA
  11. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    yep, I never thought about CCA, I just thought if battery wasn't dead after 1+ weeks sitting and no dim lights, then it probably wasn't.
  12. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
  13. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    although no problems starting or running, battery test showed so low it couldn't complete, so I just put in a new battery. actually haven't had many slow start problems the last couple days with it 70-80 degrees. have a cold front coming tomorrow, so that will be the real test. thanks everyone!
    WaltP likes this.
  14. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    well getting a new battery hasn't helped the symptoms at all, so wasn't battery related.
    I've also noticed the last few days where we've had a range in temps from 28 to 80 degrees that it isn't cold related. Truck sat outside all last night 28 degrees and actually turned over a little easier.
    I'll try to get a video of the start.
  15. moysiuan
    moysiuan F1 Rookie
    4,254
    Canada
    Time for a new starter. Might first check and clean the grounds and starter solenoid connection and make sure there is nothing badly corroded. The new battery was probably necessary to rule that out, sometimes batteries going bad can still bench test ok.
    flash32 likes this.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    ,+1
  17. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    fuel pump!
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Rob
    Unfortunately your description of not turning over let us think the rpm of the engine was slow and 0 for a few seconds .. not that the engine was turning and not starting which would have been a fuel issue
    Did I misunderstand..or did the fuel pump issue manifest itself in a weird way
  19. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    I don't know, but I do remember now 60k miles ago having a similar issue with the exact same symptoms. I believe the southern bound Tundras get a different fuel pump than the colder weather states. If not on this 2nd gen Tundra, they did on the 1st gens.
  20. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    so I'm starting to suspect that the new fuel pump didn't solve the problem.
    It was $1,400, so a little pissed if dealer was just throwing parts at it like an amateur.
    Can you properly diagnose a fuel pump issue on a 2012 Tundra, flow gauge etc? Doesn't it sound like based on symptoms and new battery that tech just assumed it was fuel pump?
  21. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Pressure test at fuel rail. Check fuel flow. Possible restricted fuel filter.
    rob lay likes this.
  22. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    628
    Eden Prairie, MN
    Matt
    So is the issue?
    1- Turn key and no starter spinning right away or
    2- Turn key, starter spins, but engine doesn't fire right away?
    For #1 - electronic, solenoid, relay would be the likely guess
    For #2 - Fuel pump, leaky injectors (if the car sits for a while and then has the issue i would think it could be this), or fuel filter is possible but less likely. Usually a fuel pump going bad will show up at speed before it shows hard starting problems. Could also be a bunch of other electronic stuff as well if the computer isn't getting a signal from something it needs (Crank position sensor) right away
  23. rob lay
    Dec 1, 2000
    64,288
    Southlake, TX
    Rob Lay
    Nothing noticeable is going on turn key, just silence and then varying delay before it kicks right on.
  24. JP365
    JP365 Formula 3
    Mar 8, 2007
    1,435
    Chicago
    John F
    I had that happen with a Toyota Sienna. Insert key turn, nothing. Turn back forth and then it would start. The ignition switch had worn out. My mother -in -law had a similar problem with her Buick. Keys had to be reprogrammed and a new theft deterrent module installed. Have you tried different keys?
    rob lay likes this.
  25. Steve Magnusson
    26,932
    There can also be another switch in the brake/brake pedal system -- i.e., the starter motor won't engage unless the system "thinks" you have the brake pedal pressed down. Don't know if that applies to your particular truck, but many ICEVs have this safeguard.
    rob lay likes this.
