Delco Alternator Rebuild & Upgrade | FerrariChat
Discussion in '348/355' started by lbell101, Jul 16, 2017.
  1. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    After I finished my major a couple months ago I could hear a rubbing or bearing noise. It was isolated to either the alternator bearings or the tensioner bearing. So I decided to change both.
    Removing the alternator is relatively easy. Just release the tension on the tensioner, remove the belt, three bolts and a couple of wires and it is off. Of course, this job was made more difficult because I put the lower bolt in from the front during the major. That made sense at the time since I did not have to remove the shift cable bracket. So I had to cut the bolt.
  2. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
  3. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    The front casing was just slid off in this case but others I've been inside took some light tapping to remove. There is also another washer inside the unit on the shaft that must be kept to be reinstalled later. Then the front bearing was removed with a socket and hammer.
  4. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    The armature was removed by tapping the rear bearing with a socket and hammer. This removed the armature with the bearing. All the electronics were then removed. To get to them, a plastic cover inside must be removed. I used a small punch from the outside to tap the plastic attachment points to release them. Electronics removal is just a couple of screws after snipping the wires that hold the stator in place.
  5. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    This is where I hit a problem. The rear bearing was so messed up that it was pretty much frozen to the shaft. The contact slip rings are so close to the bearing that it made removal without damage a problem. So I purchased a cheap $50.00 rebuilt alternator to use its armature and rear bearing. Following the same procedure, it was torn down.
  6. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
  7. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
  8. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
  9. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    Then the stator was set in place with the wires pushed through the plastic cover. The armature was set in place and the bearing was tapped in until flush. The front cover was installed and the three torx bolts reinstalled.
  10. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    THe stator wires were then cut to length and the terminals crimped. There is a small plastic cover that just pushes over these. The washer, fan, pulley and bolt were reinstalled with an impact.
  11. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    The alternator was reinstalled. No more noise and it is charging great! I'm hoping it is actually outputting the much higher amperage as advertised but have not tested it.
  12. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    informative post.....thanks for taking the time to post.
  13. Wade
    Wade Three Time F1 World Champ Owner
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Great thread. The amp upgrade is good to know.
  14. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,259
    Ian Riddell
    Impressive. Thanks, Larry.
  15. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,323
    Palos Verdes
    Vince V
    Very nice post.
  16. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Great post. My Delco alternator just failed and I need to do the same. My alternator failed shortly after my cooling fans turned ON. I fried my diodes. I spoke to my local alternator builder and he does not recommend a higher DS130 current output because the idle current is lower than stock.
    One thing that peeked my interest is that I could use a modern alternator which has considerably more output current at idle. I would need to modify the top and bottom brackets to use a newer alternator.
  17. lbell101
    lbell101 Karting
    Mar 24, 2013
    230
    Temecula, CA
    Larry
    Thanks. I had some concern about idle charge and the upgrade as well because usually output increase means a reduction in charging at idle. But I'm not getting a light at idle and everything seems fine. I have not tested output with a meter. Maybe I will do that this weekend.
  18. emac
    emac Formula Junior Silver Subscribed
    Sep 14, 2014
    851
    upstate SC
    ernest
    Very nice documentation! Thanks for posting. We used to have a place in town that rebuilt starters and alternators....they went out of business and no one around here does this kind of work anymore. Sad.
