Delta engine comes apart inflight | FerrariChat
Discussion in 'Aviation Chat' started by TheMayor, Jul 10, 2019.
  1. TheMayor
    106,052
    Vegas baby
  2. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    All the TV commentators are talking "engine failure" but the engine is the only thing that DIDN'T FAIL. It kept running just fine while the hub nose cone was bouncing around on the blades. Certainly there was some issue with the hot shaft.
  3. tonyswfla
    tonyswfla Formula Junior
    Dec 2, 2007
    823
    Florida
    why did not they return to ATL?
  4. TheMayor
    106,052
    Vegas baby
    Exactly. That's why I said "comes part" instead of failure. Two different things.
  5. jcurry
    24,065
    In the past
    Jim
    But why did the hub nose cone fail/fall off the end of the shaft? Brg failure causing an imbalance? Regardless it is still part of the engine. Fortunate that they could shut it down quickly so a fan blade failure was prevented.
  6. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,605
    AZ
    Rick
    The entire N1 fan is gone.
  7. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    That's one hot bearing !!
    It may not have started as an "engine" failure (assuming the hub cone just detached).
    But once the cone started knocking blade bits into the engine, it sure ended that way.
    There's blade bits and damage all the way through.
  8. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I agree. That's what I said, also. J. Curry mentioned bearing failure and imbalance could be the cause of the nose cone departing the hub..
  9. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,184
    Texass
    Do you think it was still "running" at this point or just windmilling? Had to have automatically tripped, shutting off fuel as soon as the first blade came off, or?
    Nice view of the first row of stationary blades with the rotating blades out of the way...
  10. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,425
    FL
    Why is the MD88 even in service...it's 2019...
  11. Gatorrari
    Gatorrari F1 World Champ
    16,455
    Georgia
    Jim Pernikoff
    They're being replaced by 737-800s and -900s (fortunately for Delta, not MAXs) as those arrive in the fleet.
