Delta Vee | Page 7 | FerrariChat
Delta Vee
Discussion in '456/550/575' started by scowman, Aug 6, 2018.
  1. Rifledriver
    37,089
    Excellent company.
  2. Rifledriver
    37,089
    Not hard to believe. In my opinion Bilstien never made good shocks. If I had a 550 they'd go early on.
    Cribbj likes this.
  3. Cribbj
    Cribbj Formula 3
    I always looked at Bilstein as being the "other" European damper manufacturer after Koni, but not even in the same league.
    Rifledriver likes this.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    All the best shock companies made motocross shocks. You lean a whole lot about shocks on a dirt bike. Never heard of Bilsteins on a dirt bike.
  5. Qksilver
    Qksilver F1 Rookie
    4,550
    PC, UT
    Joe
    Worked with Performance Shock in Sonoma on Ohlins for my 996TT and they were tremendously knowledgable.
    Wouldn’t think twice about asking them to help with a custom application.
  6. Rifledriver
    37,089
    Its how they started. Its no accident they are located at Sears Point Raceway.
  7. Rifledriver
    37,089
    True but a lot of MC shock companies never moved into automotive.
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Ohlins, Koni, Kayaba (KYB), Showa are (were) the big MX OEM players.
    White Power and Fox both did aftermarket MX and off-road truck suspension. WP had some late 80's deals with Husky & KTM for forks I think, but I do not know of any big OEM MX deals.
    I guess Marzocci and Ceriani did not as far as I can tell do automotive. I would argue they are smaller players without big OEM deals. I think they did some small unit Italian bikes and maybe some KTMs before they were orange.
    So I stick to my premise. The best auto suspensions were developed on the MX track.
  9. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
  10. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,960
    Southlake, TX
    Rob Lay
  11. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    He has been on the website in the last 30 days. Probably has seen this thread.
  12. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Still no email response.
  13. ShineKen
    19,892
    Southern California
    Nostradamus
    PSI wants $700/corner. No guarantees or warranties against leaks.
  14. ShineKen
    19,892
    Southern California
    Nostradamus
  15. ShineKen
    19,892
    Southern California
    Nostradamus
  16. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Ar
    Did they upgrade the lower seal? If not it will just fail again. The DV and PSI fixes use a larger seal with a new top ring.
  17. ShineKen
    19,892
    Southern California
    Nostradamus
    That’s a good question. I should ask or recommend.
    I know they replaced the seals, but not sure about an upgrade. PSI did not mention to me anything regarding an upgrade or did they guarantee against leaks.
    If they last 20-30k mi without a leak, I’m content at $130. I’ll worry about it a few engine outs later. My Nero 355 with 30k only had 1 leaking corner.
  18. stan996turbo
    stan996turbo Formula Junior
    Jun 11, 2004
    711
    Philadelphia
    Stan
    Did you need to provide provide them with a factory spec for the shock pressure?
  19. ShineKen
    19,892
    Southern California
    Nostradamus
    No. They know the specs.
