Delta Vee | Page 3 | FerrariChat
Delta Vee
Discussion in '456/550/575' started by scowman, Aug 6, 2018.
  1. Affordable Supercar
    22
    Either way, if the fine folks at Delta Vee came up with the solution it means that the same solution is accessible to anyone else - with some research. Seals can't just be fabricated with chewing gum and a pair of pliers: unless Delta Vee has a hidden ISO 9002 facility in the back of their shop they are using an off-the-shelf application.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, you don't need to be ISO to do good work but that's an entirely different topic. It's possible, and likely, they have worked with a vendor that specializes in seal manufacturing and that vendor produces seals for them, to their specifications, and only sells to them.
    So, "off the shelf" is probably not meaning a standard, stocked part.
  3. fatbillybob
    Aug 10, 2002
    28,638
    socal
    OK! You guys fight it out and decide who gets to deconstruct my blown out shock. I only have 1.
    Sounds like PSI is not interested.
    Laserguru is donating his time. Does he have the tools and knowledge to take this apart? Once the seal is out it can't be destroyed so that is can be copied, sourced, or remanufactured. Thanks for volunteering!
    DRocks and I have history but he does quality work and probably has what it takes to get this apart and could probably make it or source it. Finally, he has the infrastructure to sell it or make it available for sale.
    So whatever the community wants I'll do. We could even have Laser take it apart and DR figure out how to make it. I love it when the braintrust beats these problems.
  4. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Well, my name says a lot actually. I'm a PhD laser physicist who runs a R&D firm in very high energy lasers for the DoD. We have plenty of resources in the labs.
    I, can't, however promise anything like an infrastructure that could do downstream shock rebuilds or source parts. Our overhead and G&A, all gov't audited and approved yields some very commercially non-competitive pricing. Your tax dollars hard at work.....
    If DRocks wants to lead and play, it may be a more straightforward path for the community. I will be willing to assist at any turn.
    wax likes this.
  5. fatbillybob
    Aug 10, 2002
    28,638
    socal
    OK PM me your addy and I will send the shock to you next week.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Guys, while the topic is interesting to me, we don't have the resources at this time. Too many other projects in development at this time.
    Thanks for the confidence.
  7. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    I think that settles it. I’m willing to donate some funds for incidental costs and materials. Whatever the result I think the end product should be a written report on the. Rellacmwnt process and materials used to be made available to anyone who wants it.
    I hope we can agree on that.
  8. fatbillybob
    Aug 10, 2002
    28,638
    socal
    Gets shipped to Eric this week.
  9. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    What are the requirements/specs for the seals? Our prototype and cryogenics labs use plenty of them, some with operational requirements up to 30,000 psi. Most are COTS as well.
  10. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    We are not sure yet. No one other than DV has seem to have successfully figured it out yet.
  11. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Wade, when I get it and get a chance to do teardown, I'll cheerfully be in touch. I'm expecting an older seal compound (like a chlorinated PTFE) that can be superseded by something newer. We'll have to see about the physical config.
    Does anyone in this loop have any ideas about this failure mode? Besides leaking, do there tend to be damaged shock rods? Particular wear patterns? I understand that the system (including accumulators) used Dexron IV or better. Is that correct? Data, gentlemen....all you got.
  12. Cribbj
    Cribbj Formula 3
    Failure mode for the 550 Maranello shocks is leakage, however for the 456 (someone correct me if I'm wrong) it's leakage, as well as occasional bursting of the shock. body itself, but I'll let someone else chime in on the cause of the bursting as I'm certainly not an authority on the 456 system.
    There's usually some light scoring of the shock rods themselves, but it's usually polished out by the shock rebuilder.
  13. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Thanks. I'm aware that failure of the accumulators leads to hydrolock in the rear shocks and the bursting of the shock body. Usually noticed by the rear suspension becoming really hard and unforgiving. I haven't experienced it and also understand that periodic replacement of the accumulators (essentially a half fluid filled, half nitrogen filled separated bladder design) is a seriously recommended maintenance procedure. Another place where the cross-referenced parts list is absolutely invaluable.
    So for the 456 fronts and the 550s, this is essentially an issue of a crappy seal material? Breaks down from the fluid? Poor tolerances on the part design and fabrication? I get once you have leakage you're equally likely to get foreign material intrusion and scoring.
    Thanks for the info. Always good to get as much input and failure modes as possible when doing FMA.
  14. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    The 456 rears have the same accumulator seal leakage problem. The rest of the shock is nothing special. It’s the accumulator seal problem that prevents anyone other than DV from servicing them if that seal is leaking. Solve that problem and the world of service companies opens up for us. No more bottle neck at DV
  15. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    I think you mean actuator seal.
  16. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
  17. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    I will surely keep everyone informed as the project progresses.
  18. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    We should try to get you a rear shock as well. Maybe a blown out one is available? You could examine the top seal in that just the same as the front shock.
  19. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Dear God, man! Next you'll want statistical analysis on a sample of 1.
  20. JayEff
    JayEff Karting
    Aug 8, 2017
    213
    Michigan
    I'm guessing this is a combination problem, not just a bad seal but a bad design etc.
  21. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    My guess is hard to get to.
  22. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    If it’s worth doing
  23. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    So, in the leaking seal failure analysis world (aerospace at least), the first suspicion always rests on the gland design. If that isn't done properly based on the loading of the seal both static and dynamic, you're sure to get deformations of the seal shape. Second suspicion is poor material selection such as an incompatibility of the seal material and the working fluid. One would think this isn't all that tough to do with all the data available from both seal and hydraulic fluid manufacturers but it's amazing how often it happens. Third is the surface finishes, contaminations, etc. We'll see.....
    Dave rocks and Wade like this.
  24. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    Glad to see you thinking about it. Failure though is kinda normal at this age of the car no? Especially considering these cars can go fo long periods of non use.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Don't forget quality control and parts not manufactured within specification.
    Laserguru likes this.
