Derek's 308 engine rebuild | Page 11 | FerrariChat
Discussion in '308/328' started by derekw, Oct 16, 2016.
  1. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #251 derekw, Apr 30, 2017
    To weigh the big ends while I was lightening the heavier ones, I mounted and old piston pin on my dial gauge base as a small end pivot and then raised the scale to give a horizontal rod. Nice idea but in practice sliding the rod on and off moved the base slightly (even stuck down with press-stick.) This made it hard to get the precision of 0.2g I had with placing the end centres on stuck-down toothpicks so I went back to that system. Since it's a flat plane crank and bob weights aren't used to balance the crank, accuracy (the actual weight) is not important but the precision is (repeatability and relative weight.)
    I started with the Dremel but it was very slow so I used a fine flap-wheel on a small angle grinder which worked very well. Two rods were almost 4g off and the next five needed 1-2g to match the lightest BE.
  2. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #252 derekw, May 8, 2017
    I noticed that one of my rod caps has a small area of pitting adjacent to the bolt. While it is not a high stress area I'd rather get another rod or have it re-sized to take off a couple of thou. Does anyone have a conrod they can spare (max 575 grams?) Thanks!
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    That is 575g incl. bolts/nuts. C or D rod needed 528-536g without bolts/nuts. Can trade for $, cheap Chinese parts, or 12yr single malt Scotch :)
  4. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    Hi Derek
    I you want to avoid cracks starting on the high stress points of this damage ( and you should in this case ! ) you can grind it smooth with a Dremel or so to eliminate micro tares.
    Grts
    Patrick
  5. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Patrick, I can have the rod resized a little by grinding a small amount off the cap mating surfaces and then honing round to spec with a big end hone. This eliminates the pitted surface. Unless I find another rod soon that is what I'll do.
    Cheers derek
  6. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,005
    Cape Town South Afri
    Dave
    Think I have 7 C rods , problem is they are in South Africa !!! I can check for you in the morning if you are interested ?
  7. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    That's very kind of you Dave but I think the post might be expensive and risky (are they still on strike, or in the shower :). Let me try here in N. America for a few more days. Cheers derek
  8. duck.co.za
    Jan 9, 2007
    1,005
    Dave
    Impressed on your knowledge of our politics .
    I used 355 Ti rods when I built my motor , ordered the pistons with the bigger gudgeon pins .
  9. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I'm an ex-Ikey (College House) and Hilton before that. Mum in Knysna, sister in Plett. Watching and hoping for you guys...
  10. duck.co.za
    Jan 9, 2007
    1,005
    Dave
    #260 duck.co.za, May 11, 2017
    Wow small world !! Nobody coming to visit ? Could put it in their luggage ?
    Otherwise cover the postage and you can have it . It's not like I am breaking up a set .
  11. Einsteiger
    Einsteiger Karting
    Oct 9, 2014
    125
    Overland Park, KS US
    Kevin
    Looks completely FedEx-able. :) Makes an excellent Christmas gift. ;)
  12. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Took it to a well respected local machine shop and he said the pitting will disappear with the resize. He'll do it once I have the new ARP rod bolts as several have suggested that they are a bit tighter than the original bolts so better to resize with the new bolts. He'll check all the rods while the machine is set up for 47.13mm BE and 18.5mm SE.
    Someone asked me about dynamically balancing the rotating assembly with bob weights. They had paid a reputable engine rebuilder for this service and pointed out that others in this forum have suggested previously that bob weights are needed to balance the crank. Perhaps I'm mistaken but I always thought that flat plane cranks don't need bob weights due to their geometric symmetry (as in a straight 4-cylinder, adjacent pairs cancel out each other's primary imbalance.) The secondary imbalance can't be helped without balance shafts which is why our rods can be as varied as they are-- imperfect primary imbalance is not noticeable due to the secondary imbalance vibrations (i.e. my balancing efforts on the rods are not going to be felt.)
  13. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #263 derekw, May 15, 2017
    As some of you may have heard, we have been having a lot of rain and boating season has come early to our neighbours across the Ottawa river with over 400 homes flooded. I was sick of waiting for a hot day so soaked the heads with Gunk gel for a few hours and then blasted them with the pressure washer to get rid of any last dirt, dust and porting debris. Put them in a warm oven with the fan on for an hour and they are ready to put the valves, springs, lifters, cams in.
  14. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #264 derekw, May 15, 2017
    I started assembling the heads and wasted a stem seal when I forgot to put the spring seat into the 3rd valve I did. Decided it was better to put all the spring seats in place before doing a single stem seal. I'll put two extra viton stem seals in any sets ordered from now on.
    I found that the easiest way to press on the seals was with an appropriately sized socket on an extension that you can press down with while moving the extension in a circular motion to work the seal over the guide. Oil them first and check they are straight and all the way on afterwards.
    My trusty home-made spring compressor works well and saved me a drive out to the tool supply shop. It's an old, blunt hole saw attached to a C-clamp with some access holes cut out of the sides with a cutting disk (to allow the collets/keepers to be pushed into place.) Careful not to compress too far as you can damage the seal.
  15. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    ... the "appropriately sized socket" should only press down on the steel shoulders of the stem seal. Oil the valves before you put them into the guides and I smeared some assembly line on all the valve seats which rust if you just look at them.
  16. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #266 derekw, May 17, 2017
    All the valves are in. I used Comp Cams assembly lube on the valves and guides but may put a little bit of moly/zinc cam paste on the tips, tappets, cams. I've seen how rings don't seat with the use of moly but I plan to dump the oil after 30 minutes so the assembly lubes will mostly be gone. Any thoughts on this approach?
    I got a set of 100 valve shims (3.3-4.7mm) from Autopartsways.ca. For a change something was cheaper in Canada (Partsgeek has them in the US.)
    https://www.autopartsway.ca/partdetails.cfm?w0133-1604802/crp
  17. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    ... if anyone is doing a rebuild or valve adjustment and needs shims, send me a PM with the thicknesses you need.
  18. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #268 derekw, May 25, 2017
    I spent a couple of hours adjusting the valve clearance. Everything takes longer than expected-- partly me being a beginner (and not that smart sometimes) and partly the peculiarities of the engineering.
    I spent a while trying to figure out why my one cam was a bit tight. Loosened the caps in turn and found the two culprits. The journals looked fine so I mic'ed the cam journals, put a bore gauge into the caps-- no problems. Then I notice that a couple of the caps have their ID numbers on the inside whereas the rest were on the outside. I had used the casting numbers on the cap tops, assuming they would all have been assembled in one direction. Once I put all the stamped numbers on the outside, all was good.
    Another hiccup is that two of my exhaust valves are a little tight with 3.30mm shims so I have to get some 3.20 and 3.25 shims (my set starts at 3.30.) Does anyone have a few thinner shims I can buy/swap. If not I'll buy some from an online Fiat, BMW, or Volvo parts dealer. I think the combination of the new valves and cut seats have pushed the tips up a bit. I checked my Cat cam lobes (10.75mm lift) and they still have plenty of space to the edge of the shim but the 13mm lift lobes must be close.
  19. Rifledriver
    37,089
    #269 Rifledriver, May 25, 2017
    There is a limit on how thin the shims can be.
    Anytime a valve job is done it is SOP to hold the valves in position and measure and correct installed height to avoid that issue. It is part of putting the motor back where it should be, the object of the exercise. And if the needed shims are smaller than what was offered by Ferrari with new valves the condition of the seats needs to be questioned. It is a pretty certain indicator something is out of spec.
  20. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #270 derekw, May 25, 2017
    Brian, The BMW S14 and S38 have shims down to 3.00 and some of their variants had pretty big cams and high seat pressures so I'm not worried about using 3.20 and 3.25mm. When I have a chance I'll check the cam base circle, it may be a little bigger and those two valves perhaps a touch longer. The seats all looked really good (my machinist barely touched them when he cut them.) I check again tomorrow.
    As the valvetrain wears, do you need thicker or thinner shims generally?
  21. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    As the valve seats wear down, you need thinner and thinner shims to maintain cam clearance. When you can't get a thinner shim, you need a new thicker valve seat.
  22. Rifledriver
    37,089
    Bingo.
    The seats are done and need replacement.
    We needed to be asked if it was going to need thicker or thinner shims as time goes on? And this is supposed to be an overhaul by a qualified person?
  23. Rifledriver
    37,089
    And just WTF has that got to do with any of this?
    Did you really ask that question?
  24. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    An easy answer when you think about it, but I would suggest that Derek has a lot of balls in the air right now, so a little too much going on in his head, and it slipped out. It's happened to all of us.
  25. MickyB
    MickyB Karting
    Aug 21, 2016
    97
    Hungary
    I can help you out, i have a few of diameter 33mm/ 3,20-25 !
    But i'm oversees ! maybe the shipping will cost more then the parts....
    I would use shims in thickness until it goes above the cup surface!
    so don't change seats! valve lengths usually vary +-0,1mm too,even oems which can
    make some minor diff...
    Ps we sometime grind thicker shims to smaller ......
