Derek's 308 engine rebuild | Page 17 | FerrariChat
Discussion in '308/328' started by derekw, Oct 16, 2016.
  1. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Just a heads up to anyone pressing in new A-arm bushes-- check that the A-arm doesn't crack as you press in the new bush. Luckily my friend Henry, who is helping put the car back together, spotted this one when he was going to tack weld it. The crack formed from a previous weld point that I had ground off. I should have filed any grooves at the edges to be rounder and reduce stress concentrations.
  2. TheBigFish
    TheBigFish Rookie
    May 23, 2019
    15
    William J Bass
    I used the Energy bushings so not an issue for me.
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I got the brake brackets back-- they're made in 7075 so almost as strong as a medium carbon steel but very light. For anyone who tinkers with CAD and doesn't have expensive software, I found a free online FEA provider which was a nice find (simscale)-- I usually get someone else to do it who has the software. My "off the top of my head" cutouts actually stood up pretty well to the simulations. I just need to borrow a drill press to drill the new mounting holes in the Wilwoods (between the standard holes and the body) as I gave mine away when I left Canada. I’ll post some pictures when I get it all together. I tried the Boxter discs and Wilwood calipers inside the 14” wheels and it was quite close to fitting. When I moved the wheel 18mm outwards from the original offset it would clear or be very close. A few mm can be cut off the outer edge of the disc. I’ll see if I can find a similar disk with a deeper hat for the 14” wheels.
    i-velocita and marklintott like this.
  4. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I finally had time to pick up a drill press and get the brake kit together. There were a few things I had to file and grind with a Dremel but it all fits together well. The countersunk screws were 0.5mm proud of the bracket so spun them in the drill press and ground them down a little. The outside raised boss on the mount holes had to be filed flat to give a flat surface for the adapter plate. I will Dremel off part of the inside boss to match the washers. The disks touched on the inside so I Dremelled off a couple of contact points on the inside of the caliper bridge.
    If I was only building these brakes to use inside 16-17" wheels I would have used a radial mount Wilwood caliper but went with this setup as I can remove the plate and switch to the original disk and 14" wheels. If you want to go this route send me a pm as I have 4 extra pairs of brackets and countersunk screws (finally found them at Misumi so bought a packet and ground the all down flush for the brackets.)
    miketuason and marklintott like this.
  5. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I had a question about the bracket price and the lug stresses after drilling. The brackets are £100 for a pair incl. four of the 12.9 steel countersunk screws. If you want help sourcing the Porsche disks and Wilwood calipers I can help but best prices for both are mentioned above.
    The drilled lugs are still plenty strong. I ran simulations and the highest stress is on the leading hole when the new holes are used (with the bigger disks.) Even when I put all of the force onto the thin wall of that one hole it is still well below the yield strength of forged aluminium. In reality the force is distributed to the contact surfaces on both sides of both of the lugs so the factor of safety is high. Here are a couple of photos from the outside without the disks. Elegant solution to the space problem but a bit of drilling and grinding to get the fit snug.
    Saabguy likes this.
  6. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I dropped the wheels off on the weekend and hope to have the car running and registered before Brexit happens (if it ever does!) They were a pain in the arse (ass) as I kept finding new little spots of pitting and corrosion, casting bumps and holes that needed cutting off or filling... They turned out nicely from 1 meter but little imperfections that annoy me close up. Still trying to get the numbers to make up an order of coffin-spoke 16" or 17" wheels-- currently there seem to be more people wanting 16" but there are no deep 16" forged blanks so we would have to go cast which requires at least 20 sets to be viable.
    Pero and miketuason like this.
  7. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Quick couple of questions— finally had a chance to visit my 308 (work and life has been busy for a while.) I just have the 1978 parts catalog with me which is only marginally helpful.
    Is there a six-blade connector I need to find that perhaps connects to pressure sensors (right of pic.) Also what is that tube sticking up in the side of the bell housing? Breather?
    The shiny aluminium part testing on the cam cover is a blanking plug where the air pump pulley used to be. Let me know if you need one as I can get some more made.
  8. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I had an idea about the mystery 6-blade connector-- might it be for the missing catalytic converter thermocouples??
    I have put an arrow on the tube into the bellhousing- is this a breather? Any help much appreciated :)
  9. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
  10. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Thanks Joe. I must be missing the cap so will try to find one or put something porous on it.
  11. jmaienza
    Jan 8, 2009
    629
    Massachusetts
    Joe
    My breather was leaking a fine mist of fluid. I ended up putting a K+N mini-filter on the tube. No more leaks.
  12. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Two things to report on my ongoing adventure... firstly I bought an engine and gearbox for an engineless GTB here in the UK but the car sold (to an electric converter) just after I bought the drivetrain so I decided to build it up as a spare or for sale with all the usual better parts (forged 10.5:1 pistons, cams etc.) plus some IDFs on a new manifold that I'm having made. So many people asked me to find NLA CIS parts that I thought there may be a market for IDF manifolds. Cheaper and more tuning options than the DCNF. I might do a version for the QV in case there is interest. I just got some parts back from vapour blasting and they look a bit too good! I'll sell the std pistons in case anyone needs one (or a set.)
    The guy in Kent who has been tinkering with my 308 for a year is losing the space he has for it and I still haven't found space for me to work on it within an hour of London (W1B.) If anyone has some space to rent or knows of a place where I could store and work on it (electrics, put the windows in and a few other small bits and bobs), please let me know. I would also like to hear of a competent garage within a few hours of London that doesn't charge usual supercar prices as I might get someone else to finish it. I only have space for engines and parts at home, not a whole car :-(
    thorn likes this.
  13. dave80gtsi
    dave80gtsi Formula 3
    1,948
    Ohio
    Dave Meredith
    Ooooohh! Please do tell!
  14. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    277
    Australia
    Hi Derek, something I was told recently about Wilwood brake callipers is that at least here in Australia they are not DOT approved for road use. Apparently most model Wilwood calipers do not have a dust boot for the piston, because they are predominantly designed for track use. Without a dust boot its much easier for dirt, road debris, etc. to make its way into the piston/bore and cause failure of the piston seal. Not really an issue on race tracks that are generally cleaner than our roads, and race cars are generally serviced/inspected between outings. This information came to me second hand, so not saying it 100% correct re the calipers, but thought I'd mention it. Cheers. BB
  15. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Thanks Brock, I suspect Wilwood doesn't want the liability of DOT approved parts so they are sold as "racing only." The failed calipers I have seen over the years have all been pistons stuck due to rust. These are a nice unsprung weight reduction and probably dissipate heat better than the old iron ones.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    On My QV that connector has has 9 but I see a lot of the same colors I think...I only know the ones I needed and yours may be different
    yellow + +12V switched ignition power
    Brown=oil temp
    Grey= Water Temp
    Grey/yellow= oil light light
    grey/black=oil press gauge
    derekw likes this.
  17. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Dave, I have drawn some initial CAD files and my neighbour (with a 3D printer) is currently printing the first prototype for fitment testing (we have nearly 10kgs of filament left from printing ventilator prototype parts in the spring.) The manifold will be short enough to have a decent (85mm tall) air filter on top of the IDF or throttle body. I may put some injector bosses on the tubes as well for anyone who want the injector closer to the port. If anyone is interested in a set let me know as I'm currently negotiating MOQs and prices with both UK and China suppliers. Manifolds are likely to be about £100 and 40 IDF copies (which can go up to a 36mm venturi) will be about £500 for 4, I will also do a nice Ferrari themed air cleaner and linkage to suit.
    The hieroglyphics in my drawing show the limits of Sketchup's tube bending extensions-- free but you get what you pay for :)
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    Have you tried onshape? Also free if you don't mind the files being public, but it acts much more like a normal CAD package than sketchup. You can always export the files and delete the public ones once you're done but I've had good luck with it overall
    derekw likes this.
  19. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    from that angle it looks like the carb flanges are set at the wrong angles and and the tube bends in an odd way......I'm sure its just the render angle but it sure looks weird!
    sten likes this.
  21. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Yes it does look more than 45 degrees and the two IDF flanges don’t look parallel or even in the same plane. Freecad render of a step file. Any thoughts on including bosses for injectors? Are there any short throttle bodies available with only the butterflies?
  22. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    The Ti retainers I ordered finally arrived (lots of delays into the UK due to the Brexit no-deal deadline fast approaching.) They are for the standard springs or the slightly softer Opel springs that CAT cams recommends. Saves almost half the weight. I have 8 sets extra as I had to buy 10 and am keeping two sets. £160 plus post if you want a set.
    My spare engine's liners and pistons are so good (all at std 81mm with no apparent wear and hone marks still in the bores) that I may just buy new rings. Has anyone used just 2 compression rings? Which grooves? thanks, derek
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    Years ago on Indian motorcycles....we used the top 2 for what its worth.
    The retainers look great.
  24. Gmac
    Gmac Rookie
    Oct 24, 2016
    1
    Graeme McCallum
    If anyone needs replacement pistons, Bigg Red (see Derek's earlier post) do a rear piston/seal kit with for both rear callipers for £43 on eBay (BRKP169)
    derekw likes this.
  25. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Thanks Graeme, I popped two stainless plugs for the rear calliper adjusters into the post fir you. Beers on you next time!
