Devon Tread 1 Timepiece | FerrariChat
Discussion in 'Ad Archives' started by Lumberman, Dec 7, 2015.
  1. Lumberman
    Lumberman Karting
    Jun 24, 2004
    246
    Atlanta, GA
    Will
    #1 Lumberman, Dec 7, 2015
    I'm clearing a few items from my collection. This is a highly coveted piece and well sought after, but I have to part with it. Includes all original packaging in excellent condition. Leather strap shown and additional rubber strap. $13,750.
    The Tread 1’s unique functionality reinvents the watch, extending far beyond the boundaries of traditional watchmaking. The movement of the Tread 1 is a mesmerizing display of DEVON’s own patented system of interwoven Time Belts that displays hours, minutes and seconds in a way that’s never been seen before.
    Four extremely compact microstep motors drive the movement of the four belts with efficiency, exacting power and steadfast accuracy. The belt assemblies are mounted on a central chassis, which allows for the perfect clearance of the moving parts and also creates the illusion that the parts are floating within the case. Fiberglass-reinforced nylon allows for belts that are only 2/1,000 of an inch thick while being strong and stable enough to ensure continuous accuracy. This technology is adapted directly out of the cockpits of modern airliners like the Boeing 747 where these same belts were used in avionics packages to indicate vital measurements such as air speed and fluid levels.
    At the heart of the Tread 1 is an onboard microprocessor, essentially a tiny computer, that controls all of the watch’s functions. It gathers data from a temperature-compensated crystal and a proprietary optical recognition system, which continuously monitors and verifies the position of the Time Belts thereby ensuring steadfast accuracy – in fact, the Tread 1 is accurate to within one halfsecond per day.
    The belt assemblies are mounted on a central chassis, which allows for the perfect clearance of moving parts and also creates the illusion that the parts are floating within the case. Lubricant-free ruby bearings are used at the friction points of the movement, a thoughtful engineering detail which precludes the need for lubrication and significantly reduces required maintenance.
    Power for the Tread 1 is provided by a robust lithium-polymer rechargeable cell that runs for up to two weeks on a single charge. When recharging is required, it is accomplished inductively, without wires, via a charging tower in only a few hours.
    The window into this mechanical masterpiece is a crystal produced from scratch-resistant polycarbonate with bulletproof durability.
    The five-piece case design is made from 316L, surgical-grade stainless steel, the hardest and most durable steel available in the world. The case is produced in five elements through advanced computer numerical control (CNC) machining. DEVON began production of the Tread 1 in late 2010 with four variations that consisted of different combinations of exposed stainless steel and titanium-colored DLC-coated parts, depicted here.
    • Manufacturer's Reference # 858744002008
    • Gender: Men's
    • Case Shape: Rectangle
    • Case Size: 48.45 mm x 53.44 mm
    • Case Thickness: 19 mm
    • Case Material: Stainless Steel
    • Crystal: Polycarbonate
    • Dial Color: Other
    • Dial Markers: Arabic
    • Movement: Other
    • Movement Caliber: Devon Design
    • Strap/Bracelet: Other
    • Strap/Bracelet Material: Leather
    • Features: Power Reserve, Second Hand
    • Manufacturer Warranty: 5 years
  2. jehu999
    jehu999 Formula Junior
    Dec 2, 2011
    670
    Coastal Central Fl
    James
    Very Cool and Tempting. Would rather have this than a Rolex or most other watches I've seen. GLWS.
  3. darth550
    Jul 14, 2003
    61,145
    In front of you
    BCHC
    #3 darth550, Dec 8, 2015
  4. Lumberman
    Lumberman Karting
    Jun 24, 2004
    246
    Atlanta, GA
    Will
  5. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,300
    NYC. / E. Hampton
    Michael
