Anyone managed to remove/replace the 2 side rear quarter badges on a Diablo? All 3 badges on a 1996 roadster needed replacing and the only one the paint shop could easily remove, without causing any paint damage was the bonnet badge. Thanks in advance guys.
The parts manual shows no clip holding it on, probably just stuck on there with double sided tape as is the Badge on the read deck lid which I did remove, had to pry it off and destroy it in the process, no way to keep from scratching the paint either that I know of
If it is indeed stick-on type... trick I use is sliding fishing line behind it, working it back and forth to release the adhesive. Virtually harmless to the paint.
I would do this after heating the badge with a blow dryer, which shouldn't harm the paint. I've seen it done like this on several non-Lambos.
