Diablo Owners? | Page 2 | FerrariChat
Diablo Owners?
Discussion in 'LamborghiniChat.com' started by JohnMH, Feb 19, 2023.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    Thanks. Peeking under the rear bodywork, I can see the tops of the rads and check the connector on the water temp sensor. The connector looks corroded. One thing, there appears to be a jumper wire added to the connector which connects two wires of the three, which causes me to think that the po either did not want to replace a temp sensor, or did not know enough to clean the connector terminals. Before I start cutting wires and experimenting, might anyone have a wiring diagram? I am trying to order a full service manual for a 93 2wd car, but they are hard to find.
  2. 97diablo
    97diablo Formula Junior
    914
  3. 97diablo
    914
  4. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    Quite a collection of manuals.
    When I started a restoration of a Countach in 2008 I learned that there are a lot of passionate (crazy) and helpful Countach people out there. Seems that the Diablo enthusiasts are even more helpful. Many thanks to all.
    Boomhauer likes this.
  5. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    My Diablo questions continue. My early car is missing its original Konis, in their place are some Japanese replacements. No idea if they are any good (I have not driven the car yet).
    I found a complete set of shocks from a SV locally. I am interested in buying them, but should figure out if they will fit an early car (I suspect so, but my early car has no front end lift feature, while the SV shocks do). Can the lifting feature could be added to my car through simple wiring and a discreet switch, or does it require some form of ECU which I may not have?
    As well, they will almost certainly need a rebuild; does anyone do that work? Koni rebuilt my Testarossa shocks to be as good as new, but I recall reading that they do not service the Diablo shocks. Any truth to that?
  6. Schwafu
    Schwafu Karting
    Feb 12, 2023
    73
    Germany
    Schwafu
    It will be a real task to add the lifting system in your car. You need several components which are no longer available. I would recommend to find the correct shocks in used condition and refurbish them. They are here and there available.
    The non-lifting shocks are no problem to refurbish, the lifting shocks is a PITA, what i have experienced and heard so far.
  7. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    I note the first SV's did not have a lifting system (1997) but the 1998 and later cars did. I have yet to see the used shocks on offer firsthand, but maybe I am lucky (the shocks from an early Diablo front shock and a 1997 SV have the same part number).
    Do those people with the non-lift equipped cars have major ground clearance issues?
  8. Schwafu
    Schwafu Karting
    Feb 12, 2023
    73
    Germany
    Schwafu
    Not really. Of course you have to take care but even on the cars with lift system i never use it... because i am scared the system could fail :D
  9. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    My other cars include a lowbody LP400S and a BB512 with a very low front spoiler, so I am used to approaching even painted stripes on the road at a 45 degree angle.
  10. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,372
    In Houston, even the 45 degree thing doesn’t work sometimes so it depends on your area. Yes, even the lift shocks can be re-built IF that is the problem.
  11. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
  12. SGM
    SGM F1 Rookie
    Sep 27, 2006
    2,797
    Rockville, MD
    Steve
    ryalex likes this.
  13. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    Wow. Ok, yes, that is now on my list. Terrible.
  14. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,550
    Austin TX
    https://www.ferrarichat.com/forum/threads/bbqd-diablo.193739/
    You wrote in that thread it was the fuel regulator (per inspection by the insurer), and that you were not sure if it had rubber fuel lines or not. That car was a '91 with some modifications...(wheels, wing, outside mirrors were typically dark grey/black..)
  15. SGM
    SGM F1 Rookie
    Sep 27, 2006
    2,797
    Rockville, MD
    Steve
    The initial thought from the investigator was a faulty fuel regulator. But he was also able to determine through all of the prior service records that the original fuel lines had never been changed and that they were probably rubber ones and not stainless steel. Either way something in the fuel system failed. Also, to note was that the car had sat for roughly 7 years with hardly any use since the last service. The wheels were the only modification I did to it.
  16. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,051
    Switzerland
    Raymond S.
    Also stainless steal braided fuel lines age, inside is the same rubber...
  17. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    An additional question - as I trace a slight misfire, how can I access error codes in the LIE computers? Is there a rare and exotic LIE specific tool to interrogate the computers? I note the 1996 and later cars has normal OBD functions.
    As my 1992 car lacks the ability to flash codes on the dashboard I can just throw parts at it or swap parts from the left and right banks (Testarossa diagnostic style), but there must be a better way.
  18. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I have heared that the Weber/Marelli test tool workd for Diablos. But also that Lamborghini made their own ECUs. So what is right and wrong? There are quite a few cars with the Weber Marelli injection/ignition system like the 1987-2000 Maserati Biturbo cars, Lancia Integrale and many more.
  19. gutshot, Boomhauer and Spyder-Man like this.
  20. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,372
    And it is a Roadster, the most fun Diablo to drive....the Countach store was probably just jealous.
  21. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    why does your car lack the ability to flash codes? did someone remove the bulbs? there is no specific LIE tool to interrogate the computer, its all done by blink codes. Many Diablo's have the dash lights removed or disconnected to mask an error code. There is a LM Console, that plugs into the LIE's that can read parameters when the car is running, but they dont read the blink codes.
  22. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,787
    Dubai / Bologna
    I have not disassembled the dashboard yet, but missing bulbs could be the cause. My car is missing so many things (usable wheels, an exhaust system, bumper, fog lights) however dashboard bulbs may he next on my list.
    Can you provide details of the LM console referred to?
  23. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    It reads the following parameters from the LIE
    THROT: the angle opening of the TPS
    RPM:
    SADV: Spark advance
    MAP: manifold pressure
    VBB: Battery voltage
    KTJTRIM: correction factor for injection timing based on self learning memory
    TH2O: water temperature
    TAIR: Air temperature
    TINJ: battery voltage correction factor
    KTJTAR: air temperature correction factor
    KTJFAR: throttle valve correction factor
    CFH20: water temp correction factor
    KLAMBDA: 02 sensor correction factor
