diagnosis help | FerrariChat
diagnosis help
Discussion in 'Technical Q&A' started by mebozart, Oct 25, 2024.
  1. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Bloomington, Indiana
    Matt Bozarth
    I have a 2000 360 purchased with unknown history. Expected to be working through some issues and need some help from others. We are trying to identify why we have a few issues and are tracing electrical signals to identify problems. Can anyone tell me what the line voltage should be to the ignition coils and injectors when cranking? Currently we a supply voltage of ~ 4 in the circuit for both. I have looked through my manual (I have a printed copy) and have searched here but cannot find the answer. Can anyone help?
  2. Rifledriver
    37,086
    Battery voltage. If either goes through one of the small relays that is a known problem with them.
  3. Qavion
    Qavion F1 World Champ
    14,260
    Ian Riddell
    Which bank is faulty? The L/R Master Motronic relays behind the seats provide 12 volts to the igniters, injectors and a few other components at key turn on (on their respective banks). The left and right relays do need a command from their respective ECUs (I believe the ECU does this after the key is turned on an the ECUs run though a very brief self test).
    We are discussing similar issues in the message thread "Problem Child" on the 360/430 forum.
    If the problem is on both banks, you must have ignition key power supply issues.
  4. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    Thanks for the replies to this post so far. I have not had much information to formulate a reasonable question so far but now do. I would love any help that can be provided. As I have stated, unknown history on this car so I have never really had the car running right. When I purchased the car we performed a timing belt service first. We replaced the belt, all pulleys, hydraulic tensioners and both variators. After that, the car had a slight miss and that has taken us down the electrical path. After a decent amount of testing, we found low voltage on the controlled side of a couple of relays in the passenger side. Voltage that was at 5V to 2.5V. It was not constant and changed each time we probed the wires post relay. (I cannot remember the relay but I can confirm and reply if that is indeed pertinent" That made me believe that I had an ECU problem. I took the ECU's off and sent them to Specialized ECU. They said that I did indeed have one ECU that was fried. They stated that voltages were "all over the place". I found a brand new ECU and they reprogrammed the ECUs and sent them back to me. I also had them do the Immobilizer bypass at the same time. Once getting the equipment back, I followed the instructions on the bypass and believe that works as it should. There is no blinking light left of the wheel and my lights no longer flash if I do not click the fob. However, the car will not start. We performed a quick check and we have zero fuel pressure at the rail. We connected a lab scope to the passenger side ECU to check injector pulse and ignition pulse. We have none on either one. Specialized ECU claims they have a good 360 in their shop that they have installed my ECU's on the car ran fine. Before we go nuts testing, I thought maybe someone could speak to this issue directly. I have a service manual and would start by checking various signals unless someone has a better idea. If I take them at their word, I have known good ecu's so that should mean something on the car side is causing an issue. We have not done more than the above initial testing today so I do not know if we have power and grounds anywhere else. We will start testing so If there is something to check, I would be happy to reply with the status. Thanks!
  5. Qavion
    14,260
    Ian Riddell
    I would confirm that you have a constant 12 volts to the injectors/igniter on both banks with the key on (ECUs fitted). I don't know if the lack of scope signals is due to no power in the wires from the car or no signal from the ECU. If you do have 12 volts, then it's the ECUs not doing their job or the ECUs are missing data they need from all the engine sensors (MAF's, crank sensors, throttle bodies, etc)
    Also check you have power at the ECUs. There are a number of pins which need live battery and key power.
    e.g. pin 15 (power from the inertia switch).
    pin 16, 47 and 48 should have key power
    pin 15 should have live battery power from fuse 68 (fuse numbers may vary from car to car)
    Unfortunately, some of these ECU connector pins can't be tested for power unless you jumper the Master Motronic relays (pins 3 & 5).
    Just to confirm... the engine is cranking during start? You didn't have to jump the starter motor?
  6. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    The car cranks with no problem. It just has no attempt to start. No sputtering, coughing, nothing. It’s as you would expect with no fuel, spark or ignition.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    I dealt with a couple of these 360 issues this year. It's hard to troubleshoot over the internet.
    What changes did you make to delete the immobilizer? Software and hardware changes are needed.
    When the ECUs are all hooked up and power is on, what messages did you see on the instrument panel? Red, Amber, or Green messages after the key is turned to On?
    Are you able to hook up an OBD2 scanner and connect to both ECUs?
  8. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    @yelcab - I deleted the immobilizer by using Specialized ECU's bypass module and connecting the two wires stated in their instructions. If you set the key to run, the dash toggles between the drivers door open, rear hatch open and the ASR light. I am concerned that I have one or two bad throttle bodies. Is it possible that this fried the brand new ECU simply by cranking? Can you ohm the throttle bodies somehow to confirm they are pulling too much amperage?
    @Qavion - We did check for 12V with key on at pins 15,16, 47 and 48 and we have that. We have not checked the MAF, cam or crank sensor supplies yet. I am happy to do that if we are not on another track with the ASR light and throttle bodies.
  9. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    The F1 car will not enable ignition if the rear hatch is open or the door is open. That will lead to zero fuel pressure.
    The ASR on after the key is turned on means your two ECUs are not talking to each other. That is a separate problem.
    Close the door, and the rear hatch. Turn the key to on, what does the instrument panel say now?
  10. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    Now the hatch and door warnings are gone. Rear hatch light is on below speedo even with hatch closed. ASR light is on. You’ll see both in picture
  11. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    With that ASR amber message, your car will not start.
    Are you able to connect an OBD2 scanner to either ECU? You NEED to get one of these scanners.
    flash32 likes this.
  12. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    I am not able to connect to either ECU. I have tried an X431 Launch and Our MS906 PRO. Both say "unable to connect to control unit". Doesn't matter if you are trying to look at left or right.
  13. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    That means your master ECU is not coming out of self-test at all.
    You now need to look at the various power supply pins and grounds coming into the right side ECU. Start getting your DVM out.
  14. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    I replied to the suggestion to check power on the right side ecu and did that. Found 12V K/O power at pin 15, 16, 47 and 48. Are you aware of someone already listing places that power should be provided? I can dig into the service manual but didn't want to duplicate work if this information is already out there. I assume the ECU wakes up with K/O power and grounds into various terminals? I assume after power to the right side ECU it would run a series of checks then wake up the Left side?
  15. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    No. In N, a F1 car can be started with rear hatch or/and door opened.
    ASR on after the key is turned can also appear if the right ECU is not powered properly and thus is not broadcasting on the CAN bus. Dashboard detects this situation and set the ASR icon.
    Qavion likes this.
  16. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    You should see 12V also on pin 32 when key is ON.
    With key ON, can you hear the throttle bodies moving when you press the throttle pedal.
  17. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    It's pin pin 15, 16, 32 and 48
    Pin 32 needs 12V, not pin 47 which is ignition switch.
  18. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    Yes, 12V on pin 47 at key ON makes the ECU to command the Motronic relay and then get 12V on pins 16, 32 and 48.
    pin 15 is connected to permanent 12V.
    Qavion likes this.
  19. Qavion
    14,260
    Ian Riddell
    I missed pin 32, but isn't the ignition 12 volts? o_O
    That's the F1 warning symbol, not the rear hatch.
    The F1 system enables cranking when its conditions for start have been satisfied, but as the symbol is still there, something is not right.
  20. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Yes, the ignition is 12V BUT it is a power supply pin that feeds anything. Pin 32 is a power supply pin that feeds circuits inside the ECU. If that is missing, you have problems.
    That F1 gearbox symbol should not be ON when the car is running and engine is purring. But when the key is on and the engine has not started, its being on does not mean much.
    He needs to figure out why the two ECUs did not come up and out of reset.
  21. Qavion
    14,260
    Ian Riddell
    I still don't follow you. The ECU is not going to wake up if it doesn't have key power (e.g. if pin 47 is bent). But, anyway, because there is 12 volt power going to the igniters and injectors, it's fair to say that the ECUs have woken up and energised their respective Master Motronic Relays. Because of this, I assume part of their self testing has been completed (?).
    Would the immobiliser circuitry do this?
  22. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Ian, here is my last battle with this no-start 360.
    Immobilizer worked and enabled right side ECU.
    Right side ECU went through self test and came out of reset. It sent a signal to the dedicated CAN line to wake up the left side ECU, and then it waits.
    Left side ECU was lacking one of four +12V power signals, the one feeding the throttle housing, and it never came out of reset.
    The left ECU never saw communication from left side ECU and did not enable ignition on its right side circuitry. Engine cranks and cranks and cranks and ..... never fired.
    The amber ASR message is displayed on the instrument panel signifying that the ECUs cannot talk to each other.
    Once I figured that out, I ran a separate 12V wire to the missing signal feeding the left side ECU, the car fired right up.
    Matt is having something similar or along the same line of problems. Go find that missing signal ... These are now 24 years old wiring harness. **** happens.
    Qavion likes this.
  23. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    He said the Immo is bypassed, and that is all we know.
  24. Qavion
    14,260
    Ian Riddell
    On the F355, if the immobiliser is not disabled, you can't get the OBD port to talk to the ECU, but it doesn't stop the operation of the ECU-controlled injector/igniter relay. I can't help but think that something has gone wrong with the Immo modification.
    Could this be another possible sign that the Immo has not unlocked both ECUs?
    @mebozart Did you check power on those pins on both ECUs (including pin 32).
    Would you have details on the wiring modification required?
  25. mebozart
    mebozart Rookie
    May 16, 2022
    44
    Matt Bozarth
    I’ll check and let you know tomorrow. Cars at my shop and it’s about 8pm here now.
    Qavion likes this.
