Diagnostic OBD1 data | FerrariChat
Discussion in 'Technical Q&A' started by Huskymaniac, Jun 2, 2021.
  1. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Is it possible to get diagnostic live data from any of the OBD1 Ferraris like the 348? Ideally, someone cracked the communication code with the ECU and wrote a PC or Smartphone app to communicate to it.
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,232
    Georgia
    Wade Williams
    I have not heard of anyone being able to do this.
  3. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Is there a Ferrari tool that can capture live data? If so, what connector is used on OBD1 348s and 355s?
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
  5. Ferrari Tech
    Mar 5, 2010
    1,232
    Georgia
    Wade Williams
    There is a three wire connector near the ECUs that can be plugged into with an SD1 or SDX, I would think aftermarket readers would need to plug in there as well.
  6. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
  7. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,281
    Mel
    My F shop had a little F computer, connected via SDI (not SDII) to my 512TR
  8. windsock
    windsock Formula 3
    1,162
    No one needs to "crack" this. It has been readily available, SD1, SD2, SDx, Autel, Texa, some work better then others even the Ferrari tools for some functions you will find the SD1 works but SD2 does not. As others have stated it is a three pin connector that you need the three pin Fiat connector to connect with.
