Diagnostic scanner for a 360 | FerrariChat
Discussion in 'Technical Q&A' started by 78bonanza, Apr 7, 2020.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    350
    Jim Cear
    Hi all, I’ve research as many threads as I could find on scan/ diagnostic /reset tools etc . I’m trying to get a better sense for what may be the correct choice for me. Basically I’m a DIYer for as much maintenance as I can do given the limitations of my garage space.
    Other than buying an outrageously expensive Leonardo , etc. what have others found to be useful for a budget of approximately $1500?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Launch X431 Mini Pro.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    Just be careful about like other diagonsis tools with 360 ..depending on transmission tcu version you may not be able to connect and see the data or change the data within that cpu .. I know the tcu from stradale
    Sent from my moto g(7) using Tapatalk
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    There is a newer device called thinkdiag that costs 120 get one free brand for one year .. it may do all the same functions as the pro minii but after one year I think you can't use it .. where I believe the pro mini just won't allow updates but still can be used
  5. greek75
    greek75 Rookie
    Apr 18, 2011
    3
    Cyprus
    Can someone help me out? I’m looking for a DIY diagnostic to do TCU gear learning, PIS setting etc. My TCU is the 193263 version with the CFC201F.05. Which one is the cheapest one available that would work with this TCU?
    Thank you all in advance
