Did I use too much liquid gasket? | FerrariChat
Discussion in 'Technical Q&A' started by troy_wood, Feb 14, 2009.
  1. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Have you ever finished torquing up a piece (valve cover, etc) that required RTV and had a lot of squeeze out that made you wonder if you used too much? After all, a 3/32" ball of detached rtv could create havoc (oil starvation) for the lubrication system if it were to get lodged into an oiler hole.
    Last night I put the valve covers back on my 348 and was surprised at the amount of squeeze out (hondabond ht) of rtv applied to the circumfrence of the outer cam seals at the front of the engine. I deliberated for quite awhile on whether to remove the cover and reseal or not. In the end I left it on.
    How often do the pro's witness detached pieces of rtv clog oiler holes resulting in engine failier?
  2. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Hi Troy - I used Permatex hi-temp RTV on my valve cover gaskets (outer circumferences). The general guideline is to use as thin a coating as possible, but this stuff is thick, and I wanted to work quickly before it set too much, so did the best I could. I did have a little bead up on the outside, and know there are small beads on the inside too. I think I'm going to do a relatively early oil change to check if I'm seeing any RTV in sump.
    I know most don't use any, but since the gaskets were not perfectly flat in a few spots, and outer circumference didn't have red teflon (or whatever) strips on them, I decided to use the RTV. I also tapped on the covers with a wood block around the plug holes to help make sure the covers and gaskets sealed around those before I tightened all the way.
  3. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    This seems pretty honest - theres no way you can get around quickly enough (and do a perfect job) before the rtv starts to set up.
  4. Rifledriver
    37,288
    The oil filter pick up strainer and the oil filter will stop whatever might come off in that particular spot however a major cause of oil leakage at the cam seal housings in the 4 valve motors is from sealant clogging the drain back holes just behind them and flooding the surrounding area with oil looking for an escape path.
  5. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    This is really good to know. Thanks for your time Brian.
  6. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    Wasn't there a TSB on just this problem and a hole drilling fix or something?
    Also, I used the anorobic (sp) gasket sealer on my cam covers and seals. Expensive compared to the others, but for 2.5 years and no leaks, me thinks it was worth it.
  7. Rifledriver
    37,288
    328 had a mod to the cam seal carriers for drain back and 348 had a mod to the drain back holes.
  8. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    3 that I can recall right off the bat. One was still in warranty and was a 1.5" worm that completely sealed the oil feed to a 456 1-6 head.
  9. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    wow - worms... that's an ugly thought but I can completely see it.
  10. Rifledriver
    37,288
    #10 Rifledriver, Feb 15, 2009
    Same thing reached an epidemic in BB's and TR's. So much so a service bulletin was issued and the factory changed their assembly procedures.
    One reason we have all reduced using RTV to a bare minimum.
