430 - did the battery off switch in front and now emergency blinkers come on randomly | FerrariChat
430 did the battery off switch in front and now emergency blinkers come on randomly
Discussion in '360/430' started by goto35march, Jun 14, 2020.
  1. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    ive been trying to pass smog and car just cant get ready (cats still say inc.)
    friend of mine said just unplug battery and replug and try again.
    intead of unplugging battery i went to front of car (frunk) and when car was off i turned off the battery switch then turned on.
    now my emergency blinkers come on randomly. almost like when im slower speed they come on. anyone have this problem?
    i went on the fwy and it was finethen as soon as i pulled over and poped brake the emergency lights came on with the triangle in car.
    what could it be? should i do a real battery reset with taking out black terminal from battery?
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Battery switch could be bad or providing weak contact.
  3. brookliner7
    brookliner7 Formula Junior
    843
    San Antonio, TX
    Hans
    Huh that sounds strange.
    The closest similar experience I had was One time my parking lights kept flashing/blinking and I also had the triangle of death. All I ended up doing was holding the fob button down for like 20 seconds and it reset something and it was fine. Good luck
  4. Bill ochrane
    Bill ochrane Karting
    Oct 26, 2018
    202
    Galveston, Texas
    William Cochrane
    Turn the battery switch off again. Lift the negative cable from the battery. Wait 10 minutes while crossing fingers. Replace the negative cable on the battery. Turn battery switch on. Wait 10 minutes for the car reset.
    goto35march likes this.
  5. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    thank you! will try that!
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Not sure what taking the negative off is going to achieve, try taking both off and do it right. The switch in the fromt compartment is in the negative line and not the positive.
  7. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    Thanks will try today
  8. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    So to add `more to my story is that my alarm does not work. My key fob does not turn lock or unlock the door. I only use it to drive. Could it be related to the key? Going to get the key programmed or new key from dealer soon.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    They can program them, a new key costs mega money
  10. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    i really think its related to the immobilizer. when the hazards blinks the immobalizer lights are flashing too.
    question is do i need a new new new immobalizer or just program?
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    The immobilizer is Programmed to the key otherwise how would you release the immobiliser
  12. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    could it be the actual switch. i will make a video and upload of the problems.
  13. goto35march
    goto35march Karting
    Jul 23, 2009
    231
    talked to a ferrari mechanic,. thats my alarm going off. he said my siren is prob dead. he can reset alarm. question is can i reset alarm and not take it in?
