Did you drive your Dino today? I did! | Page 32 | FerrariChat
Discussion in '206/246' started by dinogts, Nov 28, 2013.
  1. Ken Ivey
    Ken Ivey Formula Junior
    251
    Portland, OR, USA
    Ken Ivey
    Wonderful, I know you'll love having a drivable Dino - nothing better. Pictures would be nice. I hope that wasn't the car with the clutch cable problem.
    Regardless, congratuations...
  2. Skippr1999
    Skippr1999 F1 Rookie
    4,476
    Let’s see pictures
  3. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,842
    Western NY
    Fred
    MarkT likes this.
  4. Pawilly
    Pawilly Formula Junior
    300
    Lancaster, PA
    What a lovely Fiat Dino on a gorgeous day on the road!
  5. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,791
    Southern California
    Rob Calisi was in town and helped me yesterday with my Dino. Seems my radiator fans would only stay on for a short time. We checked the radiator and seems to have a cold spot in the area of the fan switch. We hooked up a manual radiator fan switch using the right side interior fan switch (combining the right side interior fan to the left fan toggle switch. Anyone know why Ferrari would have separate switches?). Having a manual radiator fan switch gives me a bit of piece of mind and keeps my coolant temp in the range. Probably time for a new radiator or recoring. Seems Superformance is waiting for restocking the original FIM radiator. Rob says the lines in the radiator are so thin that it’s difficult to properly clean. Anyone have experiences properly cleaning a Dino radiator? Anyone have cold spot issues in their radiator or recoring experiences? Who’s the best radiator shop in SoCal? We went for a long drive afterwards. I can keep my temp in the range with the manual fan switch and seems the issue won’t keep me from driving it!
    Pawilly likes this.
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,132
    Norfolk - UK
    Tony
    cleaning out the old cores is rather hit and miss and considering all the effort you go to pulling out the rad and re-installing it = Not worth all the effort (and possible disappointment ) in my opinion.
    I had mine re-cored several years ago and you hardly tell the difference, they can flow test the rad but its much better to just get it re-cored in the first place.
    While you are in there try fitting a thermoswitch with a lower temp range, the original switches on at 84 C and off at 75C, try one that switches on at 80C and off at 72.
    pshoejberg likes this.
  7. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,791
    Southern California
    Thanks Tony. We tested the radiator switch that was in it and it still functioned. We did however replace it. The problem is the fan goes off when the temp gauge is above that. We’re thinking it’s the cold spot in the radiator hence the decision to make the fans turn on manually. Yes, I think recoring or a new rad is in the future.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,132
    Norfolk - UK
    Tony
    The problem is that the gauge takes its temperature from the cylinder head and the fan switch from the bottom of the rad so there is a lag in between these two measuring points. The fan can dissipate the heat from the rad cores very quickly and cause "hunting" on the fans. Heat loss through the pipes before it gets to the radiator can cause lower entry flow temperatures.
    Do the fans operate driving along and do you need to flick on the fans while on the move? Does it boil over when stationary?
    I feel some cars now actually run slightly hotter now with much higher ethanol content in fuels, unless we see some re-jetting then engine max combustion temperatures will increase and that will transfer heat into the engine coolant ie read higher gauge values.
    Tony
    celestialcoop likes this.
  9. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,791
    Southern California
    Its running really well. It’s never overheated or boiled over. Fans been have been turning on and off fine until just recently. Manually turning on the fans brings the gauge temp down to just above 90.
  10. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,791
    Southern California
    Tony[/QUOTE]
    Temps are fine on the move w/o the fans. Temp creeps up when sitting at idle for a bit. Fans turn on but go off almost immediately. When I turn the fans on manually temp goes down to 90. We think there’s blockage in the rad keeping the area by the radiator switch cooler.
  11. racerboy9
    racerboy9 F1 Rookie
    2,632
    I have the dreaded Dexcool nightmare in my old truck. I have used oxalic acid (wood bleach) many times and it works much better than the radiator flushes found at the parts store. It is the active ingredient used in the old GM heavy duty flushing formula. You can get it on Amazon.
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,132
    Norfolk - UK
    Tony
    Could be blockages in the radiator, funny why it reads a temperature to kick in then switches off so quickly - if the rad was blocked and the lower portion was cooler then it would be like that all the time. ie poor flow. However If the engine temps are elevated at idle due to poor flow then it could get a slug of hot water enough to turn on the fans momentarily!
    do you know the range of the newly fitted thermoswitch? Normal units are
    ON - 84 deg C
    OFF - 75 deg C
    DIFF. 9deg C
    If you install a thermoswitch with a small band then you will be getting a similar scenario, the differential needs to be at least 10deg to stop the fans from "hunting" or short cycling.
    start another thread if you want, rather than bung up this one!
    Tony
  13. UroTrash
    Jan 20, 2004
    40,213
    Purgatory
    Clifford Gunboat
    Took the Dino for a drive this morning.
    Had to wait for a large group of Canadian tourists to take their sweet time crossing in front.
    DinoLizard and GIOTTO like this.
  14. -K1-
    -K1- Formula Junior
    Jul 10, 2008
    699
    Northern Italy
    Ken
    Would it be ok to ask your thoughts on the aesthetics? In my very humble view I’m not keen on the size of the wheels, the flares or the headlamp covers. I’d love to get the Motec and injection on a standard v6 engine though.
  15. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,791
    Southern California
    From what I’ve seen, Mototechnique is really capable. Every time I’ve contacted Kevin I’ve gotten a wonderful and complete response. His Motec system looks really well thought out and looks completely standard with the DCNF look throttle bodies and standard air box. I have, as of yet, not experienced it (I’ve experienced Kevin’s V8 Dino with Andy Cohen. I was super impressed by the engineering and drivability). The benefit is getting the most out of your motor and having it function flawlessly from immediate startup to perfect drivability at all altitudes. I love the idea of hidden tech that makes the driving experience better. The Dino is underdeveloped when compared to the 911. Modern fuels are oxygenated. This creates problems with old fuel systems. A vintage Dino has the opportunity to be updated with the 1) engine, 2) gearbox, 3) electrical, 4) brakes, 5) wipers, 6) cooling system 7) HVAC and the 8) suspension in a hidden discreet way. I love the idea of making a Dino usable for everyday and capable on the track and back roads.
    Freeman
  16. skierlawyer
    skierlawyer Formula Junior
    Sep 12, 2010
    385
    Golden, CO
    Brian
  17. Eltel246
    Eltel246 Karting
    May 14, 2012
    175
    London
    Charles Hill
    Nice sunny crisp day in London. Decided to get the car out for probably the last time before it’s put away for the winter. Had a great time with the car after recommissioning after being laid up since 1993. Not missed a beat since I drove it out of my garage in July!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    DinoLizard, -K1- and JHNurse like this.
  18. Ribolla_67
    Ribolla_67 Karting
    Sep 6, 2016
    94
    Austria
    As the streets seem to be free of salt and the weather was fine today, I could not resist the temptation to finish the hibernation at least of my Fiat Dino Coupe . My other classics will sleep until end of march.
    everything went well, after a minute of turning the engine without Dinoplex to build up oil pressure, the machine started immediately and ran smoothly. Great music!
  19. Sal Manzur
    Sal Manzur Formula Junior
    291
    Upland Ca
    Salvador Manzur
  20. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    Stunning Sal. I remember we were parked next to each other at Concorso Italiano in ‘06.
    Cheers
    Pietro
    01296
    Sal Manzur likes this.
  21. Sal Manzur
    291
    Upland Ca
    Salvador Manzur
    That was my second Concorso Italiano. I have made more cosmetic improvements since then and received several platinum awards. I do drive the car and enjoy driving it very much.
  22. Sal Manzur
    291
    Upland Ca
    Salvador Manzur
    I tried to send a private message but apparently I didn’t know how. I have the phone number of a few Dino owners for a once per year greeting. If you like I would be pleased to have yours
