Diff project | Page 5 | FerrariChat
Diff project
Discussion in 'Boxers/TR/M' started by tuplakoo, Feb 19, 2021.
  1. Steve Magnusson
    25,144
    #101 Steve Magnusson, Sep 11, 2021
    See the cross-section drawing on page E38 of the TR WSM and the text on page E40:
    "...keeping the bearing lubrication holes toward the top."
    (Although something looks wacky in that cross-section drawing on page E38 as the relationship between the removable LH side cover and the ring gear seems reversed to reality -- the teeth on the ring gear point away from the LH side cover on page E38; whereas, on a TR, the teeth on the ring gear point toward the LH side cover. Wonder if they reused a drawing from a different model like a BB?)
    Natkingcolebasket69 likes this.
  2. Steve Magnusson
    25,144
    My mistake -- had the LH-RH reversed in my head. E38 OK.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    the hole comes to the top. so oil can get to the bearing
  4. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks to all. Fingers crossed the preload on the bearings will be good. Between the torch and the freezer, it was a hard job to replace bearing races.
  5. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    what was hard? it takes some time and with the right temperature it is done in less than 5 seconds each side
    so check the preload very well
  6. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Using an oven gets the entire bearing carrier warm which makes it easy (next time!) We did not have an oven, but went through a lot of propane using a torch to get the side carriers warm. As soon as they heated up, they cooled down (especially the driver's side). As well, a -20c freezer does not get the new bearing race cold enough to simply drop in, even after using the torch for 5-10 minutes on the carrier.
    Now that that is done, I will trial install the differential (I have to assume I do it without the ring gear mounted otherwise I would get a false reading), to check preload on the bearings (I think 3-3.5 Nm torque to turn the differential inside the cases when everything is tightened but without the ring gear installed.
    Once the bearing preload is ok, I then will need to check the pattern on the pinion / ring gear.
    turbo-joe likes this.
  7. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Test fit of differential today shows that it is hard to spin, with the side differential carrier bolts torqued to 25 Nm and the axles seals yet to be installed. Once initial friction is overcome, it does spin with some resistance, which might be in the ballpark.
    The manual gives no figure for tightening torque for the 8 17mm nuts on lock washers that hold each of the differential carriers to the sides of the transmission, but as the studs are just threaded into soft aluminum I would think the torque figures would not be very high. 40-50 Nm would seem far too high.
    The possibility is that it is too tight for the new differential case and bearings with the 1.6mm shim in place; I may order a 1.8mm one to see if that improves things; before going down that path, I want to check the pattern on the teeth.
  8. pshoejberg
    pshoejberg Formula 3
    1,696
    Denmark
    Peter H
  9. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thank you, I believe that is correct - I actually keep a 512TR manual around for my Testarossa which can be helpful, as it has a little more detail on some things which the cars have in common.
    The 512 manual suggests 53 Nm for the gearbox 'side covers'. At that level of tightness, the differential will not turn in the bearings, so I guess I need that 1.8mm shim. I hope it is still available.
    No sense it checking the pinion to ring gear clearance and pattern until I have that shim.
  10. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    why trying a 1,8 mm shim? and then may be try again other shims?
    now you have a 1,6 mm shim and when you fasten the 8 nuts with 53 Nm the diff will not turn anymore. so loosen those nuts and put between the cover and the shim or between the shim and the gearbox housing 4 fealer gauges, so in 3,6,9 and 12 with 0,2 mm and tighten again the nuts, then you see if it works fine. if not you may use thicker or thinner gauges. so finally then you know what shim you will need.
    I still have here some shims in stock, self made. also some shims with nearly 3 mm what you could grind to the exact size you need.
    later, when you check the pattern, you may use again other shims both sides then equal thicker or thinner to keep the preload.
    you may use the search function. I have written once how I always do this, but just now can not find so fast anymore.
  11. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
  12. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Many thanks for your response - my thought was to try a 1.8 and if too loose (0.2 is not that much?) I could grind it thinner. I will need to find (or buy) more feeler gauges to test as you suggest.
    Happy to buy shims from you, but delivery is always interesting in Dubai. I will pm you.
    As delivered, the car only had one 1.6mm shim on the passenger side. Do most people need to shim both sides to make the pinion and crown gear fit properly?
  13. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    most people - don´t know
    when I rebuilt a gearbox I always had to do so. until now I never only changed the diff. but may be when you only changed the diff it will work fine? so first adjust the preload without the crowngear and then check the pattern. but you not touched the layshaft with the pinion, so I think you not have to check the pattern, only the play what the crown will have to the pinion. you need a very little play only but you need a play ! ! !
    good luck
  14. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks. I get 3 hours each evening to work on this, it is amazing how fast the 3 hours goes. The plan this evening is to place 4 thin feeler gauge strips on top of the right side shim to approximate a thicker shim, torque everything to 50Nm and check the bearing tension. If that works, will install the ring gear with the feelers in place, torque it again and check the pattern and free play. Fingers crossed it all works without needing to put a shim on the left side (I will then contact you about a shim).
  15. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    wish you good luck john
    but you may use 4 equal feelers of course
  16. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Four 0.2mm feelers on top of my 1.6mm stock shim tightened with 50Nm of torque on both carriers gives good bearing tension (tight, but turns smoothly) and an 'in the ballpark' wear pattern on the teeth (the driven side looks better). As I do not want to touch the pinion, it may be hard to improve. Thanks to Romano and Paul Newman for their suggestions and guidance. A 1.8mm shim should serve me well.
    pshoejberg likes this.
  17. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    I can tell you from experience, that's a perfect pattern. As good as it gets. I could never get the coast side to center. And I went so far as to tear the whole gearbox apart to try and move the pinion. I disassembled/reassembled that gearbox at least 6 times before I decided it was as good as it gets the first time I set it up.
  18. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks (and many thanks to Romano for making a shim for me, as well as Paul Newman for making the quality differential case). I am really lucky that it fit together so easily with some helpful tips (also, maybe my gearbox case was not originally made on a Friday).
    I am travelling this week but looking forward to finishing the differential and mounting the engine back on the gearbox when I return to Dubai. Meanwhile, I am in Toronto, getting to enjoy driving my BB512 this week. No plans to replace the differential in that one, just saving up to buy more fuel. Actually, when I step on it, it makes clouds of black smoke, even when warm. Does anyone have BB jetting experience? (Perhaps a new thread)
    c4b4the04 likes this.
  19. samsaprunoff
    samsaprunoff F1 Rookie
    4,183
    Edmonton, AB Canada
    Sam Saprunoff
    Good day JohnMH,
    Just a heads up that simply changing out the jets may not sort out your rich condition. I have spent a fair amount of time on my BB's carbs and in the process I have a ton of respect for the original designers of these carbs... They are infinitely tune-able ... which is both a blessing and a curse. In addition to jets you may have to consider float levels, emulsion tubes, air correctors, and even review the size of the accelerator circuit return bypass valve (locatedin the float bowl). The bottom line is that there are lots of things going on which are interrelated and so any changes in one can affect others. Also... just a heads up that the "typical" manual float level adjustment (bending of the float tab that the needle vale sits against) is woefully inaccurate and is quite time consuming to get right. Having done this countless times I recently found a much superior measurement method which uses a calibrated sight glass that is affixed to the float bowl drain bolt. Doing this allows you to see and verify the float levels quite easily and accurately.
    Given my experience... and I still have a lot to learn ... I would suggest you find someone who is an absolute guru on these carbs, as there is a fair amount of knowledge and experience needed to truly sort them out especially so given the continually changing fuel formulations at the pumps.
    Cheers,
    Sam
  20. dinos
    dinos Karting
    Jan 6, 2013
    106
    Athens - Greece
    Dinos
    After 11 years of ownership of my 512 tr (1992, 44000 km bought my car from the original owner, never abused!) I finally did the major service (When I bought the car 11 years ago it was just serviced and all these years I did around 5000 km).
    To my great surprise my differential was ready to break!
    Actually, I was very lucky that it didn't cause any damage!
    As people said before in this forum.... "it's a matter of when the differential will break!"
  21. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    682
    Cupertino, Ca
    Ryan
  22. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    682
    Cupertino, Ca
    Ryan
    You haven’t driven the car much. I did mine too right after I bought the car.
  23. dinos
    dinos Karting
    Jan 6, 2013
    106
    Athens - Greece
    Dinos
    It's the only car that I never had a track day with since from day 1 I have read the postings and warnings from Melvok!
    Today (after 10 years waiting for the major........) when we opened the differential, from the one side it looked brand new...... but when we removed all, I couldn't believe my eyes (there was no indication of any problem... no noise..... no nothing!!). A time bomb ready to explode!!
  24. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    682
    Cupertino, Ca
    Ryan
    Prevention maintenance is always the way to go for a known weakness or problem, That’s why o did mine. Didn’t want an unexpected huge repair bill.
    dinos likes this.
  25. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    so also not changed during this time the timing belts?
