Diff ratio | FerrariChat
Diff ratio
Discussion in 'Boxers/TR/M' started by godabitibi, Dec 31, 2012.
  1. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    What is the final drive(diff) ratio on the testarossa?
  2. Steve Magnusson
    26,822
    #2 Steve Magnusson, Dec 31, 2012
    If you mean just the differential gear set, the documentation indicates that most are 45/14, but some (e.g., late CH) are given as 61/17 (but this OM data set has an obvious calculation error so doesn't give confidence).
    But the transfer gear set also varies for year/version, so for the overall engine-to-rear wheels relationship, you need to do a (transfer gears) * (gearbox) * (diff) calculation for a particular year/version -- and it's quite "tall" in 5th gear for all of them compared to "normal" cars -- ranging from 2.720:1 to 3.036:1 (correcting the late CH calculation assuming 61/17 is correct) -- which it needs to be to get to 300 KPH ;)
  3. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Steve my question was for the final drive only. I wanted to know if the diff was a hunting type. Being what you said makes it a 3.21 which is a non hunting and no need to mark the tooth when desassembling. Thanks!
  4. Steve Magnusson
    26,822
    #4 Steve Magnusson, Dec 31, 2012
    I am glad to hear that you are thinking of that issue, so many don't when working on the transfer gears and/or the cam belt drive gears (if so equipped) -- and they should! ;)
  5. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    I always tell my students, are you comfortable in someone elses old shoes :) Same for the gears. And it can become a problem.
  6. ago car nut
    ago car nut F1 Veteran
    5,500
    Madison Ohio
    David A.
    OK, this might sound like a stupid question. What do you mean by hunting and non hunting?
    Does it concern a wear pattern on gears that always mesh with the same tooth and root?
    Ago
  7. Steve Magnusson
    26,822
    #7 Steve Magnusson, Dec 31, 2012
    Exactly. Because 14 and 45 share no common divisor, (eventually) every tooth on the pinion gear comes into contact with every tooth on the ring gear (so random reassembly relative to each other isn't an issue). The 308/328 driven cam belt gear has 36T and the driving crankshaft gear has 27T -- so an individual tooth on the driving gear only touches the same 4 teeth on the driven gear. Same issue for the transfer gears with 27T-28T-30T -- no problem for the 27T-to-28T relationship as they share no common divisor, but, on the 28T-to-30T gears, 1/2 of the teeth on one only come into contact with 1/2 of the teeth on the other so best to not alter their relative phase.
    Even keeping this relationship correct (when necessary), there's still a little dodgyness to reusing gears because it is impossible to remount them in their exact same locations relative to their corresponding axes of rotation (when you get down to the micron level) -- i.e., just the tolerances in the new bearings may move the axis of rotation for either gear a little from where it was, and, since the pinion gear and pinion shaft are an integral unit, you can't mess that up, but it's best to keep the relationship between the ring gear and what it's bolted to the same (if you are reusing both of those components).
  8. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #8 Philwozza, Jan 1, 2013
    Jeeze Steve..... My resolution for this new year is find a question that you cant answer.
    Its going to be a tough one because I wont know the answer either to know if you are right :D
    Happy new year
    P
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Happy Nwe year to you all !
    Steve, I hope that "so many" should leave this precious work to the few EXPERTS ... and don't try to save money.....
    In the end ... as allways ... they may pay a very differnt price ...
    Please leave it to the real specialists like Steve or Cavalino or ... xxx ...
  10. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    #10 turbo-joe, Jan 1, 2013
    as I know only the swiss versions have such different ratio.
    the swiss meassured the exhaust noise during acceleration in 3rd or 4th gear. and with the lower ratio from 14/45 the rpm have been to high and so the noise to loud. but why they changed those diff ratio and not the ratio from the main gears ( so from the clutch down to the gearbox ) I don´t understand.
    I put in as you see in the pictures a little different gears for the main gear box ( pirmary gear box or how you say to this??? ). so it is always easy and fast to change the ratio if I go on a hill track or a round track.
  11. Melvok
    Jul 25, 2008
    14,268
    Mel
    He Romano, please show us MORE ... ... for instance your exhaust system ... ;)
  12. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    on my car there is no real exhaust system:
    only tubes with diameter of 70 or 80 mm from the turbos and on each side then a silencer of 100 mm diameter. that is all. also the wastegates not to forget. pictures will follow the next days.
    because I remember from motorcycling: loud pipes save lives
    and a ferrari has to be heard discreetly but firmly
  13. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    #13 turbo-joe, Jan 1, 2013
