DIFFERENCE BETWEEN 308GTS & 308GTSI | FerrariChat
Discussion in '308/328' started by mcaputo, Dec 5, 2007.
  1. mcaputo
    mcaputo Rookie
    Nov 28, 2007
    49
    canada
    mike c
    CAN SOMEONE HELP ME WITH THIS QUESTION.
  2. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
    308 GTS is the carburetted model, 1976-1979.
    308 GTSi was the initial fuel-injected model, 1980-1982.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,554
    Canada
    Newman
    As well, the steering wheel, console with gauges, seats and wheels are different.
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Fuel injection on the i, plus a few minor changes like moving the clock and oil temp. gauge from the left of the steering wheel on the lower dashboard to the center console at some point. Were power door locks introduced with the GTSi, or was that later?
  5. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Lets not forget that the GTS had 14inch rims with 205/70 series tires and the GTSi moved to the metric TRX rim 390mm (15.354 inches) with 220/55 series tires
  6. Bullfighter
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
    Probably the best thing the original post'er could do is pick up a copy of Keith Bluemel's Original Ferrari V8 book. There are numerous differences through the 308 range, and Bluemel does a good job with words and photos of describing them.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,854
    Cerritos, CA.
    Well the 308 GTS QV 1983-1985 is also a (GTSi) they just added two more valves per cylinder.
  8. Dr Tommy Cosgrove
    36,707
    Birmingham, AL
    Tommy
    The QV's were never referred to with the "i" from the factory because all QV's were injected. No distinction had to be made with them.
    The little GTSi on the fuse panel is left over stock from the backs of the 2Vi.
    So, to be absolutely correct, the GTS is from 76-82 and then again from 83-85.
    (I know, who cares...)
  9. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    So the early injected cars had no i on the fuse panel badge and got the carb's GTS or GTB badge and the QV's had i badges left over from earlier i cars.
  10. Dr Tommy Cosgrove
    36,707
    Birmingham, AL
    Tommy
    Correct. The first of the 80's all had GTS on the fuse panel. (or B)
  11. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    My car is a 1980 and does not have power locks. I am not sure if any 2Vi did... Hmnn?? Also, 1980 GTSi came with 14" cromodoras the same as carbed cars...
  12. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    My 1980 has the Campy's
    I've never locked the car so i can't speak to that.
  13. miketuason
    Feb 24, 2006
    15,854
    Cerritos, CA.
    I see! thanks
  14. jefffromcanada
    jefffromcanada Formula 3
    1,207
    Alberta
    When was this book published? Does it talk about 328, 348, etc?
  15. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    First published in 1997. Yes it covers all v8s up to and including the 348 and touches briefly on the 355 in the front of the book.
  16. Bullfighter
    Jan 26, 2005
    22,622
    Gates Mills, Ohio
    Jon
  17. jefffromcanada
    1,207
    Alberta
    Have you ever seen the book on a shelf at your local bookstore? or should I just order it online?
    Appreciate your help, thanks.
  18. vteqe
    vteqe Formula Junior
    Mar 5, 2005
    664
    long Island, NY
    Sandy
    Borders and Barnes and Noble usually carry Keith Bluemel's Original Ferrari V8 book.
  19. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I found mine at Borders. I've looked around though a few times for others and came up empty... I'd just order it online if its available.
  20. Jbryant
    Jbryant Karting
    Sep 23, 2006
    220
    California City
    Jeff Bryant
    My 1981 GTSi has power door locks and the drivers mirror was also electric until I replaced it with a new style of mirror.
    Jeff
  21. Ackmann
    Ackmann Formula Junior
    Nov 23, 2007
    499
    Salem Oregon
    Wayne Ackermann
    Bought my copy from amazon as a used book for about 1/2 price. Book arrived in about a week looking like new. I agree it isn't a fun read. Very Technical, but still a great referrence to the differences between years and model changes.
    Good luck.
  22. Tifosi1
    Tifosi1 Formula 3
    Feb 17, 2002
    1,560
    Pearl River, LA
    Kelly J. Vince
    The "i" Stand for improvment. " Bob Bondurant.
  23. Dr Tommy Cosgrove
    36,707
    Birmingham, AL
    Tommy
    No one caught my mistake. That should be 76-SEVENTY NINE (not 82) and then again from 83-85.
    I simply listed every year the first time around. Sorry about that.
  24. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    The louvers on the engine hood are different too.
  25. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    One of the best books you can get is "The Original Ferrari V-8" by Keith Bluemel.
    Barnes & Noble, E-Bay from time to time, Borders, etc... about $35.
