difference between CT Off and CST Off ? | FerrariChat
Discussion in '458 Italia/488/F8' started by Race3, Aug 16, 2012.
  1. Race3
    Race3 Karting
    Nov 14, 2010
    144
    ok, i've read the manual but i'm still a little confused between CT Off and CST Off.
    Here's my understanding, is this correct? With CT (traction control) off, the car still use ABS brakes on individual wheels to maintain some control in a slide but it does not cut engine power as normal in other modes. And with CST Off (Stability control) the car allows full slides and does not active ABS or engine cut off, thereby allowing you to fully spin out.
    Is that a correct explanation? If not, can someone clarify?
    thanks.
  2. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    That is my understanding. I keep my modes on all of the time, just me :).
    Lee
    Viperjoe likes this.
  3. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    CST off retains ABS for braking (i.e. no lockup) but will not use the brakes/et al to help keep the car pointed in the right direction....but turns just about everything else off. The e-diff still works.
    CT off turns off just the traction control....so if you want to "drift" and do fancy, tire smoking slides, it will let you do that, up to a point, then it will try and help you avoid doing a donut/spin...gives you a longer leash to play, but not completely free
  4. 4RE Bob
    4RE Bob Formula Junior
    Feb 7, 2004
    567
    Muskoka, Ontario
    Bob
    I think you are mostly correct. Even in CST OFF, the E-diff is still on in it's mildest form (most freedom). So you can spin, but oversteer exiting a corner may be controlled somewhat by the E-diff. In both modes the ABS is still on for braking. It cannot be shut off, ever.
    From the manual:
    CT OFF mode: When this mode is selected, the F1-Trac traction control system is disabled whereas stability control remains active. This setting is used on the racing track.
    CST OFF mode: This mode allows the driver complete freedom and control of the vehicle for track use. No electronic system other than the E-Diff controls vehicle stability.
  5. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    549
    I absolutely adore the TC Off setting in my Italia. It's an absolute blast, and seems to cut in just when I need it. I've never owned a car with just the right amount of leash before.
    Does anyone have experience with other cars that behave the same way? Any daily drivers?
    Sent from my Pixel 2 using FerrariChat.com mobile app
  6. j09333
    j09333 Formula 3
    1,306
    Ct off brakes each wheel at needs when sliding while modulating gas pedal for you
    Cst off you control the slide
  7. FFan5
    Jul 7, 2018
    549
    Exactly, but the important note is with CT OFF or CST OFF, the traction control unit would let you burn the tires off in a straight line. CT OFF only gets involved in a slide, which is the only time I want it around.
    I've owned a few cars, and none have had this awesome setting. All just had a stupid "Sport" traction mode that cut in more often than the 458's "Race" does. Does anyone have experience with other cars that behave the same way? Any daily drivers? Or is this killer feature a Ferrari only?
  8. dustman
    dustman F1 World Champ
    11,080
    Track mode in Perf seems to be similar and allows the car to go bathsh!t
  9. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,166
    i can turn the stability control off in my 911s. it believe its more like CT off then CST off
  10. Petrolhead#32
    Petrolhead#32 Formula Junior
    673
    NorCal
    Petrolhead#32
    I know this is a very old thread, but I have a question for you all about this:
    Today I took the 458S for a spin around the amazing mountain roads we have here in NorCal, and I decided to play a bit with the two options I have never tested: CT off and CST off. To be honest, I only used the CST off in a few turns that I know really well and with full visibility ahead. I don't like to take any chances outside the track. Therefore, I didn't really feel much difference because I didn't push it much.
    But the point / question I'd like to post is that I could swear with the CT off setting, I felt a more aggressive throttle, engine note and steering feel, even more so than in Race mode. I don't see any of these performance-related enhancements on the settings instructions. In fact, from what I've learned the engine is both the same for Race and CT off.
    So was it just my mind messing with me, or is there any truth to this feeling?
    Thx in advance.
    Bandit23 likes this.
  11. Bandit23
    Bandit23 Formula Junior
    250
    Miami
    I had this same sensation in my 458 Italia, on CT off mode, the car felt much more aggressive, and just wilder and you can just push it more .much different feeling to Race Mode,
    i too thought it was playing with me ha!
    Im glad a 458S owners feels the same :)
  12. Petrolhead#32
    673
    NorCal
    Petrolhead#32
    So today I spoke to someone who owns a Scud about this, and he explained something that makes sense to me. Let me see if I’m able to replicate it…
    Basically in CT off mode, the throttle limits are not there to help you, to avoid getting in trouble coming out of the turns. The resulting sensation is that it’s more alive and aggressive. So therefore the acceleration is more abrupt, less progressive and more punchy, but it’s also more troublesome if you don’t know what you’re doing.
    I’ve always thought the only difference was in traction - e-diff, but apparently there’s more to it with the elimination of the throttle control added to it.
    I’m not 100% certain this is real, but this makes sense to me. I’d love for some expert to provide thoughts.
