Differences between 95 MY and 96-99 | Page 2 | FerrariChat
Discussion in '348/355' started by Dave rocks, Nov 27, 2014.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Not familar with that recall
    Can you tell what it relates to?
  2. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    1995 rear bumper has a pair of seperate fixing plates that bolt to the inside of the bumper for the inner fixing mounts...these are part numbered.
    Later 5.2 cars have these plates complete with the bumper...no seperate part numbers.
  3. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    1995s' interior never goes sticky.
    Later ones all do.
  4. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Kidding ;)
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Clutch cooling/heatshield differs in size/shape between 95's and later cars
    Obviously...
    Steering wheel
    Glovebox
  6. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    95s have a dual intake system and produce 10 more hp :).
  7. F355Bob
    F355Bob Formula 3
    Intake cams are different to accommodate second cam phase sensors, sump cover is different to accommodate second crank sensor. I believe throttle bodies are different on 2.7
  8. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Great thread Dave. As a 95 owner, I'm finding this fascinating.
    Thanks, Henry
  9. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    #34 308 GTB, Nov 27, 2014
    Thin (~1.5 mm) front shock mounts for 1994 and 1995 cars. They are thicker from MY1996 on.
    This was a problem for 1995 Challenge cars with their Challenge shocks and 1800 lb (and later 2200 lb) front springs which could result in cracking. The 1996 F355 Challenge Manual issued instructions for bolstering the front shock mounts. It might also be a problem for early F355 owners who have upgraded their springs and shocks.
    See these threads:
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/403961-my-track-day-experience-2.html
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/430621-h-r-versus-fiorano-springs.html
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    My 99 has those same snaps but in defense I changed them , Much better design.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Sorry I don't think this is a fact because my 99 berlinetta f1 gets air through pillar.
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Post a pic. If so it's not original. I tried running it this way on my previous 5.2 car and it does not run correctly in crosswind conditions due to the induction being "Y'd" together behind the maf sensor
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Just looked at my engine out photos and they r original just like ricambi has in their parts book. Heavy insulated hose. I will post a pic when I can or if someone can tell me how to export pics off my Facebook I will do it right away. Other wise have to wait till I'm at my computer in California.
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Ok, just wondering how close you looked at it because on 5.2 cars the induction hose runs directly under (actually touching) the duct at the rear of the 1/4 windows.
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Well maybe I will look closer at pics hang on.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    And your saying if you run it the other way from the ducts the car runs funny?
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    By not run correctly what do you mean, idle, wot, I would suspect even in cross winds the faster you travel the less effect, but just a guess.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Yes, because the induction y's together it will get cross flow that messes up the maf signal. If I was at a steady cruise and there was wind from the side I could feel the car nose over and surge from going lean.
    Reconnecting it to the factory configuration fixed it.
  19. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    You guys are saying the same thing (I believe), the C pillar area is the rear window area
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    No, he is stating that 5.2 inductions connect at the corner of the windows.
    I'm saying they go under the duct at the windows, squished above the radiators and connect to the door scoops.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Even with your y system tied together ie, using both your original over the rad hose and the window hose it did this or did you just feed from the window like jay did? The reason I ask is my car definately does not die going lean.
  22. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,301
    CT
    John Kreskovsky
    My SN is a couple 100 below that. Single pump.
  23. 4respy
    4respy Formula Junior
    Aug 15, 2014
    601
    los angeles
    steve
    Yes..95s US cars did not come with a factory radio..neither did my 97
  24. johnk...
    Jun 11, 2004
    11,301
    CT
    John Kreskovsky
    #49 johnk..., Nov 28, 2014
    Are you sure? My 95. Also came with a manual for the HiFi system. Could have been added later, I guess.
  25. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,201
    Adelaide, South Aust
    Steve
    #50 Steve355F1, Nov 28, 2014
    That looks like the same system my '98 has, and I'm fairly sure that it was only available with the later cars, so yours probably had it installed afterwards. Happy to be corrected though.
    It barely made it past the first page before losing the plot, but as I'm a man of my word...
