Differences between hunting and target shooting? | FerrariChat
Discussion in 'Other Off Topic Forum' started by 62 250 GTO, Nov 13, 2007.
  1. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Is it shooting at something that can move that is the difference or is that coupled with the range to the animal is not exact, there's no longer a paper target, you're no longer in the shooting range {comfort}?
  2. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    P.S. Is a .303 suitable enough for hunting deer?
  3. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    Yes.
    I've seen a lot of guys miss deer by shooting large calibers that they can't handle (they flinch when shooting). A .303 that hits a deer in the vitals will do a lot better job than a .338 Win Mag that sails right over his back.
  4. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    Many differences such as:
    - Shot placement for a perfect kill (lung or heart shot).....you just don't want to wound the animal and have it escape.
    - Bullet drop compensation in case of unknown shooting distances which you have to predict in case of hunting animals (in most cases there is no time to use a range finder).....it's easy to calculate bullet drop when target shooting (distance known) and adjust the scope accordingly.
    - A moving target is more difficult to hit than a stationary target.
    - Bullet choice is very important for different types of game.
    ......, etc.
  5. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    For me, it's the entire outdoor experience that makes hunting enjoyable. I love spending time out in the woods, and all of the work that goes into planning and preparation of a good hunt. And absolutely nothing beats the skip of a hearbeat when a deer walks under your stand on opening morning. You just don't get that at the range.
  6. Rickenbach
    Rickenbach F1 World Champ
    Nov 20, 2005
    11,297
    West
    Rickenhoser
    What kind of deer?
  7. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    That last part sounds like it should be in quotations in the front cover of the best selling hunting guide in the world. lol
  8. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    I didn't think there was much difference other than {mule deer}?
    What are you thinking? A different gun for different deer?
  9. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    I've read about bullet choices before, what's the big dif?
  10. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Is there a website that you know of that shows "vital" positions? I know "whereabout" in the neck to shoot but I would like to see diagrams or something else pinpointing where exactly to shoot.
  11. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    #11 8 SNAKE, Nov 13, 2007
    Yes, I'll get one for you. If you can avoid it, don't shoot a deer in the neck. If you don't hit the spine, a neck shot makes it nearly impossible to track a deer. Neck shots don't bleed much and usually take a while to get the job done. Most of the time, that means that you don't recover the deer, which is always a bad thing.
    A deer's vitals are just behind the front shoulder. Picture an 8" pie plate positioned directly behind the shoulder. That's where you want to place your shot. Keep in mind that if you're at an angle to the deer (say up in a stand looking down at the deer), you'll need to alter your point of impact so that the bullet travels through the vitals (in this case, hit the deer high behind the shoulder so that the bullet travels down, through the vitals).
  12. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    For deer, you want a bullet that will expand upon impact with the animal, delivering a lot of knock-down power. That way, the bullet will do its job and take out more of the vital areas that you hit. You wouldn't want a jacketed bullet that zipped right through the animal, making small entry and exit wounds. You also want to make sure that you're using a heavy enough bullet, but if you're using a .303 that shouldn't be an issue for you.
  13. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    There's not enough difference between the whitetail and mulie to worry too much about the caliber that you use. There are a few that are adequate for whitetails that are pushing the envelope for mulies, but most are good for either one. With that said, hunting conditions can be quite different between the two. You might encounter longer shots on a more frequent basis hunting out West. Around here, I rarely take a shot longer than 100 yards (although I did take a deer at 200 yards on Saturday). You need to factor in the terrain and conditions that you'll be hunting in when selecting a caliber. For longer distances, you'll want something that is fast and has a relatively flat trajectory. That way you won't have to worry as much about compensating for distance when you're taking a shot.
    Let me know the conditions and game that you'll be going after and I'll be happy to offer some suggestions.
  14. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    I thought the neck was one of the good ways to go, thankfully I'll be learning a lot from a guy who's been doing it for 30 years.
    Which side is the heart on?
    By vitals do you mean the heart and lungs are "that" close together as in side by side?
    I understand the angle comment.
  15. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    How many bullet options are there for a .303?
    What do you mean by weight? The actual weight of the bullet or...
  16. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    1. Small piece of advice. Just because someone has been doing something for 30 years doesn't mean the person is any good at it. I'm not saying this is the case with the person you're hunting with, but keep it in mind just the same. Neck shots are bad.
    2. Sides won't matter. Your bullet will almost always pass completely through the deer.
    3. Vitals are normally the heart and lungs.
  17. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Thanks for all the answers and tips, I should try to rent you for a season. lol
    I'll be hunting in Nova Scotia, it's a big rock covered with trees, waterways and hills.
    I think deer season started a couple of weeks ago and lasts a couple of months so the temps would be 50°F to -4°F, nearing the end of the season would be deep wet snow {possibly} and the coldest temperatures.
    I have an eight year old .22 and a .303 {from WWII} that seems to be in good working order but I can't see it being suitable for hunting {it being so old}. What would you recommend for a good rifle? Also I will want a scope, whether that's unsportsmanlike or not, I can just see myself winging an animal in the ass and it running for days and a hundred miles before keeling over.
    I also started a hunting thread in the sports section:
    http://ferrarichat.com/forum/showthread.php?p=137223583&posted=1#post137223583
    As for "fast and a flat trajectory" wouldn't everyone want that all the time?
    What's the difference between a rifle and a sniper rifle? I would want the gun to be able to hit a target at a few hundred yards and knock it the hell over. Being new I would never take a long range shot at an animal in case I wing it or miss it by a large margin and come close to something/ someone else.
  18. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    There are a ton of different bullet options out there for the .303 British. There are different bullet designs and weights. By weight, I mean the actual weight of the bullet (measured in grains). A quick search revealed bullet weights of 150, 174 and 180 grains available in .303. Any of the three would be perfectly fine for deer.
  19. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Good point on number 1.. I will assume he is a decent shot and a respectable hunter as I know a few people who have learned from him.
    So if I plunk one behind the shoulder it will catch the lungs and heart?
  20. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    I've never hunted in Nova Scotia before. I'd come cheap! :)
    There are plenty of people that use the .303 for hunting, but you bring up a good point. Since there are so many old rifles floating around, factory ammo is loaded relatively light in .303 British so that older guns in poor condition don't blow up or malfunction.
    There's nothing wrong with using a scope at all. This is an area where you will get what you pay for. Spend money on a good scope.
    Not all people want fast and flat. People that hunt in heavy timber and brush often want slow and fat because those rounds don't deflect as badly if they hit a branch. People that hunt open country want fast and flat. Do you know how long the average shot is in the terrain that you'll be hunting? In my area, I hunt a mix of fairly open woods and fields. I prefer fast and flat. The people that I hunt with use .30-06, .270 and .300 Win Mag. The .300 Win Mag (it's mine) is overkill on whitetails, but I've been very happy with the caliber. It's fast, flat, powerful, accurate and easy to find ammo. I like it because I can use one rifle (that I'm comfortable with) to hunt just about anything in North America.
    A sniper rifle is a pretty generic term, but would generally refer to a rifle that has been customized with a very precise trigger pull, action work and a custom barrel to produce outstanding accuracy. Just about any gun that you buy off the shelf today will provide good accuracy. The old standard seems to be MOA, meaning that the rifle is capable of shooting at least 1" groups at 100 yards. Nearly everything out there today will do this. I don't know what your budget is for a new rifle, but if you give me an idea, I'd be happy to suggest a few good rifles to look at.
  21. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    Yes, if you put the bullet behind the shoulder you'll catch the heart and/or lungs. Assume that you've got an 8" pie plate behind the shoulder. Anything in that area will get the job done.
  22. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Is the difference between the 150 and 180 considerable over 200 yards? I assume the 180 would drop more over a long range and not travel as far or as accurately but pack more of a punch when it reaches the target, is that correct?
  23. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    You are correct. The 180 gr packs more punch, while the 150 gr has a flatter trajectory. I don't think accuracy would be an issue between the two, but individual guns favor individual types of ammo. When you start shooting, you'll want to buy several different types of ammo (different brands, bullet weights, etc) to see what your gun likes the best. Shoot several 3 or 5-shot groups with each type and you'll be able to tell what gives you the best results.
  24. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    Neil, this is a really cool (and useful) tool that you can play around with on Remington's site. Toward the bottom of the page, you'll see three drop-down boxes that say "Select Caliber" in them. You can pick up to three different calibers and then compare their trajectory, speed, energy, etc. Let me know if you have any questions.
    http://www.remington.com/products/ammunition/ballistics/
  25. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    If you're confident in your shooting ability and with your rifle, then a shot in the control locker (head) is the best place to hit any animal. It will stop them dead in their tracks. I've seen animals shot clean through their hearts and still run 1/4 mile or more before collapsing, and in steep rugged terrain that could be a problem.
    But it's all about making sure you hit what you're aiming for. Front shoulder shots are a good way to cripple and/or kill one, but you will lose some meat in the process, maybe not a lot, but some good sausage meat.
    Best thing is to go to the range and practice practice practice until you're confident with your shooting ability.
