348 - Difficult to start when the engine is hot | FerrariChat
348 Difficult to start when the engine is hot
Discussion in '348/355' started by marc556, Jul 18, 2020.
  1. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    Hi Guys,
    Some of you know that I’ve problems the start the engine of my 348 when the motor is hot.
    I’ve used the car like this for one year or more.
    It is not a problem of grease inon the flywheel... it is new.
    Coils and amplifiers are new.
    When I stop the engine when hot, if I start again within 5 sec, it starts perfectly but if I wait 20 sec, it becomes difficult.
    Today, My son followed me with his Porsche Boxster and he told me that there was a strong smell of fuel behind the 348....
    Do you have any idea ?
  2. Qavion
    Qavion F1 World Champ
    14,238
    Ian Riddell
    ernie likes this.
  3. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Yes, cranking is fine...
    But why is there a smell of fuel behind the car when I drive it ???
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,211
    Serbia - Niš
    Miroljub Stojanovic
    The engine is, for some reason, running too rich. A few things to check first:
    1. Vacuum lines to the pressure regulators. If one or both vacuum lines are leaking or collapse (maybe only when they get hot and softer), this will cause higher fuel pressure.
    2. The pressure regulator(s) themselves - you can check the fuel pressure if you rig-up an adapter. According to the manual, with the vacuum lines to the regulators connected, you should have 3.4 Bar (+/- 0.2 Bar) at idle and 2.7 +/- 0.3 Bar when you switch the engine off. If the vacuum line to the pressure regulator is leaking or is collapsed, you may get ~ 4 Bar at idle.
    3. The coolant temperature sensors.
    Other reasons could be leaking injectors but it is unlikely that many of them would leak, perhaps one or two which should not cause the kind of rich running that you have. Another possibility is bad contact(s) in the MAF sensors connectors - check them and clean them if dirty/corroded and do not use any dielectric grease on the pins.
    Qavion likes this.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    What year 348?
    Re fuel smell when followed. Does it have the cats on it?
    Ferrarium likes this.
  6. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Thank you for all your comments..
    It is a 1990 348Tb (ECU 2.5)
    The cat casings are on it, but there are empty...
  7. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    just a stupid question, do you have a pic of the vaccum lines ?
  8. marc556
    590
    Wiltz (Lux)
    Marc Foyen
  9. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #9 Ferrarium, Jul 19, 2020
    Here is the fuel, vacuum would be 72.
    I agree with Miroljub, sounds a bit like leaky/stuck injector or bad fpr. Any CEL lights? Are the working, when you turn the car ignition on but not start do they light up?
    Double check loose fuel lines, injector rail, filters, fpr, cracked fuel line on filter, check for leaks around the pump, drain and in/out lines and eliminate physical leaks first, probably can only tell when system in pressurized you may smell it in the garage if it is a physical leak. If not and only when behind car, running rich is likely
    Injectors, FPR, O2, MAF is the order I would start replacing. But that's me I replace everything. Its all due anyhow its a matter of time before you start getting stranded for all those items anyhow.
  10. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    ‘Are the working, when you turn the car ignition on but not start do they light up?’ Checked....yes it is ok.
    I shall check if there is leakage....
    I keep you informed
    Thanks a lot
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    If CEL's are working and your not getting a CEL due to rich condition, O2 or water temp sensor etc is likely a physical leak, or at lease I would suspect that first. That's for the fuel smell. Not sure how its related to hard start except perhaps low Fuel pressure perhaps.
  12. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I shall check this week and keep you informed.
  13. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Well, there's your eye burning, fuel stinking exhaust.
    Pangea and Qavion like this.
  14. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Which explains why mine did the same, but only somewhat. Turns out, I had one good cat and the other was empty. What's odd, they both seemed like they were there since the beginning (badly corroded mounting hardware).
    Qavion likes this.
  15. Qavion
    14,238
    Ian Riddell
    On my non-Ferrari car, this vacuum line going to the fuel pressure regulator was resting on the engine in the "V", and got very hot which accelerated the degradation of the rubber. I don't know if it's the same on the 348.
    Unfortunately, the Ferrari fuel pressure regulators themselves are hard to find and quite expensive. I see there are part number variations between cars (at least on USA cars).
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The replacements are on rock auto and come from std products. The Bosch fpr new don't exist.
    Sent using FerrariChat.com mobile app
  17. marc556
    590
    Wiltz (Lux)
    Marc Foyen
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #18 Ferrarium, Jul 25, 2020
    The FPR is #1. There is one on both sides in that location.
    #2 is supposed to be an IAC your car looks like its a vacuum can there. They look like this. Never seen a car with a can there like yours. Its's #13 in the parts diagram. They are way cheaper if you xref parts.
    Qavion likes this.
  19. Qavion
    14,238
    Ian Riddell
    Hard to say. For now, I would just be checking the vacuum lines to both FPRs. You won't know if an FPR is faulty until you check the fuel pressures. If you can pull the vacuum line off the FPRs, check for fuel in the vacuum line.
    I can't figure out what "2" is. It doesn't appear in any of the parts manuals. Things like IACs and Aux air valves need an electrical connector.
  20. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Regarding ‘2’, it seems to be original, the same on both side and clean mount.
  21. m.stojanovic
    3,211
    Serbia - Niš
    Miroljub Stojanovic
    The thing (#2) that looks like FPR is a "frequency damper" - it dampens the pulsing in the fuel line caused by the injectors. It is strange that you have the dampers as it appears that they were used only on 328s and Mondial QV. What is the Bosch numbers on it?
    I have one damper (Mercedes, I think) with a vacuum port and the Bosch number on it is 0 280 161 007.
  22. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I shall check if there is a number on it.
    was it orginally installed on 348s ??
    It is very strange, isn't it?
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #23 Ferrarium, Jul 25, 2020
    Not installed on 348 that I know of, no diagram show it either. Regardless I would replace it with the IAC as the Mondial T diagram shows the same IAC as the 348.
    Good option = https://www.ferrarichat.com/forum/threads/iac-valve-options.616769/
    You can also xref the Bosch part number it was used on Audi and VW cars as well then search for the Audi and VW numbers.
  24. m.stojanovic
    3,211
    Serbia - Niš
    Miroljub Stojanovic
    Looking at your picture, I just realised that the damper (#2) appears to be in the idle air line, not in the fuel line. If this is the case, this is somebody's idle air control re-engineering attempt. This thing is, on some engines, inserted in the fuel line to dampen (smoothen-out) the fuel pressure pulsing as the injectors open and close, not used on any 348.
    On the 2.5 348, the idle air is controlled by a by-metallic device having a 2-wire connector:
    See this thread for more details: https://www.ferrarichat.com/forum/threads/fuel-pressure-regulator-348-tb-euro.569486/#post-145821210
    With regard to the 2.7 348 idle control valve (motor) with a 3-pin connector (like the pic below), you cannot use it on the 2.5.
    steved033 and Qavion like this.
  25. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Replace both.
    You car is 30 years old = the fprs are 30 years old.
    Time for some new ones.
    Wade likes this.
