348 - Difficult to start when the engine is hot | Page 2 | FerrariChat
348 Difficult to start when the engine is hot
Discussion in '348/355' started by marc556, Jul 18, 2020.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #26 Ferrarium, Jul 26, 2020
    Ernie he has what looks like an FPR where the IAC should be he was thinking it was 4 fpr's total.
    As stated replace both FPR's (#1 both sides). What ever those canisters are (#2) are unclear, previous posts show 348 with 2.5 ECU but parts diagrams show IAC for all years and ECU versions. This is interesting perhaps the 2.5 was different. Maybe euro not U.S.?
  2. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    The problem is solved...
    It came from the FPRs, Mine are 3.0bar.
    I replaced the FPR on both side and now, the no more difficulties to start the engine when it is hot !
    Thank you so much form your help guys !
    Wade and Qavion like this.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Qavion likes this.
  4. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I’ve just ordered the parts for the fuel pumps....
    Qavion likes this.
  5. Qavion
    Qavion F1 World Champ
    14,622
    Ian Riddell
    .... and then your fuel quantity sender will fail :D
    I've just ordered a custom sender (just in case).
  6. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    The fuel quantity sender is a sh..t!
    Mine has a very bad precision... and the low level light turns on when there is 1/3 of the full volume.
    If you have a solution......
  7. Qavion
    14,622
    Ian Riddell
    Marc, there's a guy on the Club Scuderia website (UK) who is developing them (for the 355). If you have problems with that website (many people do), I'll ask him him if it's ok for me to send you his email address (in a Private Conversation).
    Note that the 355 and the 348 have the same sender, but he's only tested it on the 355.
    Note also, for 355 owners, there is an additional (separate) fuel level processor on the 355, so some fuel indication problems would have to be diagnosed first to eliminate that as a probable cause. Also, the 355 doesn't use the low fuel level light contacts of the sender. The fuel level processor triggers the light based on quantity signals. I'll ask the developer if his sender has a low level switch for the 348.
  8. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    well, very good idea...
  9. Qavion
    14,622
    Ian Riddell
    Marc, the developer, Brian Robbins, has just confirmed that the sender is compatible with the 348. There is an optional fitment tool (i.e. extra cost). I'll give you his email in PM.
    Even if you can find an OEM version, apparently this one is an improvement on the OEM version and cheaper.
  10. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Very good news.... thank you so much
  11. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    Cool. Where did you get the replacements?
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    JasonS likes this.
  13. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    One guy on Fchat ordered 2 FPR in USA and sent to me in Europe, because there were not available here.
    I suppose you can order the FPR on Rockauto.
    Qavion and JasonS like this.
  14. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    In Europe, you can get the Bosch 0 280 160 731 (that superseded 0 280 160 715) here: https://www.rendcarparts.com/en/search/search (Volvo 960).
    I also just saw this inexpensive Herko PR4061 (https://www.ebay.com/itm/New-Fuel-Pressure-Regulator-Herko-PR4061-For-Various-Vehicles-72-98-3bar/381699070900?epid=253828346&hash=item58df099bb4:g:r8wAAOSwRwxcgU5d) which cross references to Bosch 0 280 160 731 and also shows "Ferrari 348 GTB 348 GTS, 348 Spider 348 TB 348 TS". I don't know the quality of Herko products but they are US made, Florida.
    Qavion likes this.
  15. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    When you replace these, is it a simple swap out, or do you have to purge the lines after.....prior to starting engine?
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Simple swap out.
    JasonS likes this.
  17. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    OK, so I'm not really having any hot start problems, but since these items were cheap I figured I'd put some new ones on for good measure. I ordered a couple PR161 from Rock Auto as suggested. I went to put them on today and low & behold they are not correct. I didn't know there are 2 different styles. The fuel line from the pump on my 91 TS is threaded, not push on (pics below). Anybody know where this version can be found? Is there a common replacement part # that Rock Auto might carry? The factory # is 147281.
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #43 Ferrarium, Aug 15, 2020
    There are 2 pressure regulators for different year split , one with a barb and one with 2 threaded fittings.
    The PR161 mentioned in this thread for this car is the is the 3.0 BAR.
    The PR298 (I think) is the 3.8 BAR, typically 92 on, SS and Spiders generally.
  19. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    Thanks, yep, mine looks like the PR298 on my '91.
  20. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep get a return label and get the other ones, simple. While the fuel is disconnected pull the injectors and have them cleaned. I sent them out and go them back in 1 week. I used Mr. Injector and while waiting I power-coated the fuel rails.
    JasonS likes this.
  21. m.stojanovic
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    The connection on the FPR that is either push-on or threaded is for the return line to the tank (practically no pressure in it), not the line from the pump to the FPR.
  22. JasonS
    JasonS Karting
    Sep 5, 2019
    68
    Green, OH
    Jason Stropki
    ah yep, I see that in the drawing now, good catch. same result. :)
