News
Digital camera electrical problems...
Discussion in 'Other Off Topic Forum' started by rob lay, Apr 29, 2004.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Social Subscribed Miami 2018 Owner
    Dec 1, 2000
    50,825
    Southlake, TX
    Rob Lay
    Well, my first digi I got about 2-3 years ago started having problems a couple months ago. I have the Sony DSC-P5. The battery only started lasting about 30% as before. I tried two other batteries as I thought that was the prob, but still same probs. Actually, the camera got worse. If the flash was on the camera would shut off and freeze. I couldn't even get the camera to turn back on to close the lens. It would work again with the power line, so I do think it was something with the camera circuits to the battery, but not the batteries.
    I of course can't go without a digi, so 1 month ago I bought a Sony DSC-T1. This camera rocks! 5 mega pixel and it's smaller than a deck of cards.
    My question is if it's worth it to get the DSC-P5 fixed? Is it unfixable or if it would cost more than $100, I doubt it would be worth it. Where would I take it?
    I've had such bad luck with high tech electrical devices that run on batteries. Seems like right at 2-4 years they just stop working, I swear they design them to only last that long so you have to buy another one like I did. My cell phone, digi camera, and digi camcorder have all had electrical problems.
    Thanks,
    rob
  3. LAfun2
    LAfun2 F1 Veteran
    Oct 31, 2003
    6,106
    California
    Ryan
    Sorry to hear of your troubles Rob. The T1 is a nice camera. I was looking at that but finally decided I may order the Elph S500 canon.
    However if you can't fix it and want to sell it cheap, I will take it off your hands. I have gone without a camera all these years, and a used one might not be a bad idea. :)
    I do agree on your theory that they design to not last long. My home cordless phone needs to be replaced every 2-3 years because the battery can't keep charge anymore, makes me :mad:
    I have had good luck with cellphones though, since I have the old skool 3390 or whatever. It is the 4 lb one.
  4. richard_wallace
    richard_wallace Formula 3
    1,950
    Cincinnati, Ohio
    Richard Wallace
    I am with you Rob - I have been through about 3 now... Usually after 2 batteries wear down (not holding charge) - the camera seems to do the same - most of mine last 2 years... However with the technology changing so fast - this is about my upgrade timing... Honestly, I would put it on e-bay with the problem listed - you might get a little for it - people will buy them to fix, or part. The problem with getting it fixed - which you can send it to Sony - depending on the problem - you might spend more to get it fixed than you think it is worth... Might want to give Sony Tech a call - they may know what the problem is... (http://www.ita.sel.sony.com/support/) Go to digital imaging section - you can do online support or go to contact sony... (should be a number in there somewhere.)
    The other thing you can do - if you bought the old one with Amex Gold/Platinum or Visa - sometimes you will find that with these cards you get and extended warranty... The other thing to consider - since you take a lot of shots - you might want to buy and extended warranty for the camera... I typically never do this - because it usually is not worth it - but on things like digital cameras, some of the high-end MP3 players - and Tivo's I do (I have had 3 tivos crap out after the 1 year warranty runs out - and that get's me a new unit - usually upgraded to the current model.
    Just some thoughts,
