Dim dash lights - again | FerrariChat
Discussion in '308/328' started by rolindsay, Oct 20, 2006.
  1. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Yes, another thread regarding dim dash lights.
    We all suffer with dim dash lights, well, at least the older 308 owners do. The fix some folks try is the same as used to upgrade the older British cars - higher wattage bulbs. That solution works but the problem is heat. Run those big bulbs long enough and you'll melt your gauges - or at a minimum, warp something inside from the heat. Therefore, I am going to address that problem.
    Today, there are a number of cheap and bright white LEDs available, even at Radio Shack. I hope to fabricate some new lamps for my 308 using the original lamp bases but with new LED and voltage dropping resistors. No, the dimmer will probably not work right but the gauges will be visible and as LEDs produce only a tiny fraction of the heat, the gauges will be bright AND stay cool.
    One could even go for bling-content and change LED colors to suite one's mood. My mood is always bland so white LEDs will do the trick. As incandescent bulbs are quite yellow in color temperature, the white LEDs should produce a really clean and crisp look to the dash at night, bringing out the blue accents of the gauge hands, etc..
    I'll post results once I have them. Right now I need to get some door work done...
    rick / '79 308GTB #28133
  2. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Rick,
    You can eat more carrots. That should help.
    Barry
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,831
    Cerritos, CA.
    Rick, My 84 308 QV is also very dim I was thinking about going to a higher wattage bulb but I think I like your idea about the LED. Please keep us posted as to how and what led you're going to use. Thaks.
  4. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    At last I understand the problem – I’m too darn old!
  5. ClydeM
    ClydeM F1 World Champ
    12,061
    Wayne, NJ
    Clyde E. McMurdy
    There goes another excuse
    "Honest officer, look for yourself. I have no idea how fast I was going. Can you see this dang Italian guage?"
    Do look a couple of threads ago, someone did post a link which seemed to show new LED mounts on the old bases.
  6. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    I do tend to type before search. That's almost like surgery before diagnosis.
    Thanks for the reminder.
  7. thecarreaper
    thecarreaper F1 World Champ
    18,120
    Savannah
    you guys need to bypass the rheostat altogether. and install the Sylvania bulbs. add the jumper wire and you are done. i have done this on 4 308s with NO ISSUES at all, and have nice, crisp night time lights. i did a thread on this with pics in either Tech Q&A or the 308 section about 2 years ago.
    let me know if i can be of help, but dont overcomplicate things and make more work for yourselves!
    THECARREAPER
  8. gt500blue
    gt500blue Formula 3
    Oct 18, 2006
    1,851
    Texas
    GT
    I would love to see the pictures and step by step. I just bought my first 308, and since my eyes are the best at night already, it would be really great to upgrade! I'll try the search from a few years ago, but if you can get them posted again, that would be great!
  9. thecarreaper
    18,120
    Savannah
    put "dash lights" in the search engine and the threads should come up.
  10. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I put Birdman's fuse blocks in my car and that helped the dash light issue quite a bit. I still have to have a look at the tack, but the others are bright. My dimmer still works too. The dimmer switch feels like it needs work too. I'll probably by pass it later.
    Bob Wassam
  11. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    You don't need higher wattage bulbs. You just need to replace them with the same type. Car dash bulbs get dim with age; it's just how they are. Especially 1970's vintage bulbs! My '72 was so dim you could bearly see them; just swapping them out made all the difference. Modern dash lights don't have this problem.
    Ken
  12. Rachane
    Rachane Formula 3
    Sep 5, 2005
    1,086
    San Francisco, CA
    Rachane
    Did the bulb updating and dimmer bypass on my 328. Better, but still a long way from ideal. I think this is just a "best possible" situation. The center instruments are reasonably well lit now, but the speedo & tach remain pretty dim. However the tach is somewhat easier to see than the speedo, so I have become accustomed to noting the tach speed at various gears/speeds, and using that as a glance-read.
  13. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #13 spiderseeker, Oct 23, 2006
    I did the lamp upgrade and the gauges are reasonably well lit, I have NOT done the dimmer bypass yet, as I didn't think I needed it. (85'qv)
  14. thecarreaper
    18,120
    Savannah
    that looks great ! cool pic too !!!
  15. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Agreed, although I did a double take on the oil pressure! My gauge reads " 6 " in the middle, not " 85 "! LOL! And I like the high mileage. Keep driving it!
    Rick
    '79 308GTB with 80k kilometers ...and climbing
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    All incandescent filaments deteriorate with age.....
    They are supposed to be dim, so as not to detract from exterior view!
    You can tell, I hate to work on things???
  17. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    That they do! Don't we all?
    I agree. I've always turned down the rheostat on all cars I've owned so as not to be distracted by a brightly lit dash panel.
    Really?
  18. richy montana
    richy montana Rookie
    Dec 20, 2019
    3
    Ricardo Montana
    Guy's
    Did you ever have the time to read the manual?
    If your answers is NOT...
    Here you have it!
    INSTRUMENT
    PANEL LIGHTING
    "... When the position lights are lit, the instrument panel lighting brightness can be changed.
    If the button (R) is pressed for less than 2 seconds, the icon (U) will apear on the multi-function display.
    When the button (T) is pressed, it is possible to adjust the instrument panel lighting brightness within a range
    varying from 0/30.
    After 10 seconds of inactivity, of if the button is pressed, the multi-function display will return to its original
    setting..."
    IT WORKS GUY'S!
  19. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
  20. mwr4440
    58,047
    Bavaria, The 'Other' Germany
    Mark W.R.
    Nice Try.
    There is NO 'R' Button on a 3x8.
    There is NO 'Display' either.
    These are REAL Cars.
  21. richy montana
    Dec 20, 2019
    3
    Ricardo Montana
    Ferrari 360 F1 Spider 2003.
  22. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    OK, that's nice - but why are you posting this in the 308/328 section in a thread about 308/328 instrument lighting? o_O:p
  23. richy montana
    Dec 20, 2019
    3
    Ricardo Montana
  24. 308 milano
    308 milano F1 Veteran
    5,350
    Montana
    Kim
    No problem. Happy holidays!
