Dim Panel lights mondial t | FerrariChat
Discussion in 'Technical Q&A' started by HarfooT, Feb 18, 2011.
  1. HarfooT
    HarfooT Formula Junior
    Sep 28, 2010
    308
    Prince George, BC
    Hugo McLeod
    I have completely dismantled my switches panels next to the gear shift and the trunk panel, and the underlights are super dim... when i look at the spider web of small lights, most are quite dim, some are bright... ideas?
    Has anyone used LED's or something else?
  2. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Just checking....Have you messed with the dash light dimmer switch, just to see what happens?
  3. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    Mine are the same. Did you locate the bulb? Maybe replacing that and cleaning the ends of the fibre optic "spider web" might improve it.
