430 - Dimensions of 430 engine mount | FerrariChat
430 Dimensions of 430 engine mount
Discussion in '360/430' started by aec, Apr 8, 2021.
  1. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    Would somebody be able to provide me with the dimensions of a 430 engine mount? In particular, I am interested in the distance from the top of the upper metal plate to the bottom of the lower metal plate, as well as the diameter of the round rubber.
    I am looking to adapting 430 engine mounts to fit in a Mondial t. New Mondial t and 348 engine mounts are basically unavailable at any reasonable price.
  2. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    I took measurements of all four sides of two mounts. They measured 25.25 to 26.05 MM. The higher readings were on the sides.
    Let me know if you would like additional measurements.
  3. AandSC
    957
    Jax, FL
    Allen
    The diameter of the round rubber part to the left in the pic above is 71.35mm at the top and 75.23 at the bottom. The round rubber part on the right in the pic above (between the two metal plates is 80mm at the big end.
  4. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    Thank you so much! I will now check if this is going to be feasible with at least some metal work.
    AandSC likes this.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    There are at least 2 firms in the uk that will make them as a special, not going to be £950 each.
    Have a look at. avmountsonline.co.uk. Or. gmtrubber.com.
  6. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Ricambi had the heavy duty mounts for the best price. 190255 $60 Ea.
  7. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    AandSC likes this.
