Dino 246 alternative quarter light latches | FerrariChat
Discussion in '206/246' started by Bazza, Jun 28, 2022.
  1. Bazza
    Bazza Rookie
    May 9, 2015
    6
    Doesn't matter how many times I glue my catches on, they fall off....
    There are two fixes - buy new glass with holes and fit catches with a stud through the hole.....
    OR
    there are catches around with a neat U shaped plate that wraps around the window glass to hold the catches in position
    Does anyone know where to find /who sells them in uk/europe preferably??? Please!
  2. racerboy9
    racerboy9 F1 Rookie
    2,642
  3. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Gary Bobileff does the U shaped bracket. It's an easy fix, not having to take the glass out etc.
  4. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,077
    never lock the latch.
    NYC Fred likes this.
  5. swift53
    swift53 F1 Veteran
    8,283
    E.S.
    Alberto
    nor the car :)
  6. TTR
    TTR F1 Veteran
    5,889
    Riverside, CA
    Timo
    Third fix/real solution (same as in Daytonas): Re-adjust/-form adjacent window frame components to alleviate pressure caused by their inadequate fit & shape.
    Anything less is just a band-aid.
  7. DrDweeb
    DrDweeb Karting
    Nov 30, 2013
    167
    Is there a picture of this device?
    I guess a conversion to drilled quarter glass and latches would work, but might be overkill on my car. This device might be a winner.
  8. er72
    er72 Formula Junior
    322
    Roslyn Harbor, NY
    Eugene
    Glue the latch to a metal washer of the same diameter and then glue the washer to the glass. This will lift the latch 1 mm away from the strike plate, so there is never tension on the latch.
    Eugene
    PS I have a few extra reproduction strike plates (3D printed). They're available on eBay or PM me here if anyone is interested.
  9. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I have used this approach, not using a washer but a solid piece of stainless and welded it on to the latch. I then glue with light curing glue and a purple curing light. So far so good. The Gary Bobileff latches are a good alternative. Just give him the thickness of your glass and he makes them to fit. A bit pricey but an easy solution that looks good also. I had 2 sets made recently at a cost of $1200 a set. I also use Eugenes strike plates.
