Dino 246 clutch release bearing | FerrariChat
Discussion in '206/246' started by JAMES NICHOLSON, Mar 3, 2020.
  1. JAMES NICHOLSON
    JAMES NICHOLSON Karting
    May 22, 2019
    84
    JAMES NICHOLSON
    Can any one help?
    I have just purchased a new clutch release bearing and retaining spring for a Dino 246 (1973).
    The problem I have is, how does the retaining spring hold the release bearing?
    To me the spring does not fit into the machined groove on the release bearing so when the bearing is moved on the shaft the spring just rides out and does nothing.
    I would have thought that the release bearing and spring stay together as a one piece item once fitted.
    If anyone has any images of the setup that would be great.
    Regards,
    Jim.
  2. Ken Ivey
    Ken Ivey Formula Junior Silver Subscribed
    Jan 6, 2013
    256
    Portland, OR, USA
    Ken Ivey
    I haven't been in that part of the car for some time, but generally, the bearing is pressed onto a carrier. The carrier is then fixed to the "arm' with a spring - allowing it a bit of flexibility when contacting the clutch.
    Ken.
  3. DinoParts, Stefan
    DinoParts, Stefan Karting Sponsor
    Mar 1, 2015
    141
    Eschwege, Germany
    Stefan Kratzer
    Jim, I think you are on the right track. I machine a wider groove for the spring before we ship to our customers because "what you get" from the factory does not fit.
    pshoejberg likes this.
