Dino 246 engine back in engine bay | FerrariChat
Discussion in '206/246' started by LeoDino, Feb 24, 2024.
  1. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    Hi, the engine of my 246 is awaiting to return to its engine bay. I remember that some time ago, extracting it from its niche, was a nightmare. Very tight environment.
    I have searched this forum for a video showing engine installation, but have not found any. Can anybody here tell me if there are any, or altervativlely provide a video / fotos / hints?
    Help would be highly appreciated.
    Georg
  2. daviekj
    daviekj Formula Junior
    486
  3. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    Kevin, THANK YOU VERY MUCH. Very helpful
    Georg
  4. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,299
    Sergio Tavares
    Remove the rear crossbar,
    19mm wrench bolts seen from wheel well and wire safety tied bolt heads
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    When both removing and re-installing the engine consider removing the bell housing. It narrows the engine a lot and makes it MUCH easier to get into place. Re-installing these pcs with the engine installed is very easy and it is worth the time to follow this procedure.
  6. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    #6 LeoDino, Feb 28, 2024
    Thank you Kevin + Sergio + Nuvolari for all your helpful tips and recommendations. Today, I took a deep breath, and plunged the engine into its bay. Finally, it was less tragic than suspected. The most helpful item was a bar, that helped to tilt the whole engine.
    A very helpful item came form Fiat Dino and Fiat 130.
    Thanks again
    Georg
    GIOTTO likes this.
