Dino 246 GTS:restoring hard top | FerrariChat
Discussion in '206/246' started by raywong, Aug 7, 2005.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I already got the 2 rubber gasket on the inside of the window, but I couldn't find the part number of the rubber strip on the outside of the window.
    anyone know?
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Sorry, I'm no help on the part numbers
    but I'm also in need of changing the Targa top side rubber.
    Where did you find yours?
    BTW,
    Lee at T Rutlands quoted me:
    T top seal set 4 pieces........$588.00
    Includes rubber pieces with aluminum strips inside and foam glue on seals.
  3. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Hi Ray,
    We've got a whole shelf full of these strips - cost £17.55 (GBP) each plus shipping
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Do you have the larger black foam(/rubber?) Targa top side seals with aluminium rivet rails on it?
    What is your company's name/web site?
  5. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Hi Malcom, is it the aluminum part or the rubber part or both? I should have asked you when I ordered the gaskets.
  6. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Ray,
    I will post a picture for you (camera at home so will be a few hours)
  7. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    You will need to register for this site...www.owners.ferrari.com
  8. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    #8 Ferrari_tech, Aug 11, 2005
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Thank you for the info, I've been registered for years.
    I have rather large rubber foam pieces that attach to the side of the targa top with pop rivets that look much wider/taller than the images you show. It is possible that a previous owner changed it, but doubtful.
    To confirm, is this the piece that rivets to the side of the targa top and mates with the top edge of the window?
