Dino 246 gts seat belts. | FerrariChat
Discussion in '206/246' started by JAMES NICHOLSON, May 4, 2020.
  1. JAMES NICHOLSON
    JAMES NICHOLSON Karting
    May 22, 2019
    84
    JAMES NICHOLSON
    Can anyone help?
    I am looking for a correct set of seat belts for my RHD 1973 UK spec 246 gts.
    Not sure if they are static or inertia reel type?
    Regards.
    Jim.
  2. HMB-Dino
    HMB-Dino Formula 3
    2,282
    Pebble Beach, CA
    RonG
    Can't speak to UK specific cars, but I believe static belts were replaced with retractible ones in 1972 with the E-series. I would think the switch would be covered in The Dino Compendium.
  3. Bluebottle
    Bluebottle F1 Veteran
    8,530
    Newbury, Berkshire, England
    Mine - 246GT #06934 - has static belts.
  4. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,331
    Iain
    UK cars had 3 point static belts. The only change to the set up was the switch from the airline style lap receiver lift type buckle to the more modern stalk type receiver with the red plastic push button release on the centre console which happened sometime in 1973.
  5. daviekj
    daviekj Formula Junior
    486
  6. JAMES NICHOLSON
    May 22, 2019
    84
    JAMES NICHOLSON
    Kevin,
    Thanks for your reply.
    I already have a pair of original Klippan receivers,(red push type) which came with the basket case car.
    The seatbelts were taken off many years ago and presumably lost.
    I would like to try and source a pair of Klippan static belts to suit the receivers.
    Regards,
    Jim.
  7. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    Here are the red push button style Klippan belts for a DeLorean. Still available new NOS. They’re retractable but you’d get the hardware and webbing to make a set of static belts. only buy the RH/Passenger side as they don’t have the extra wiring for the seatbelt light. RH and LH are the same otherwise.
    https://store.delorean.com/p-10094-seat-belt-kit-rh.aspx
    https://store.delorean.com/c-398-8-7-6-seat-belts.aspx
