dino 246 on emergency ignition mode | FerrariChat
Discussion in '206/246' started by Sal Manzur, Dec 23, 2004.
  1. Sal Manzur
    Sal Manzur Formula Junior
    Sep 12, 2004
    291
    Upland Ca
    Salvador Manzur
    I recently learned my 72 dino is using "emergency mode" for starting.
    I believe this means the dinoplex unit is not working or was removed?.
    Looking at the owner's manual, if the car originally came with an emergency mode, it must mean the dinoplex was not very reliable.
    On emergency mode, is it safe/reliable? How can I tell what is on the car?
    Sal M
  2. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Most Dino owners don't use the dinoplex. I am fine running the Marelli coil without dinoplex.
    Can anyone explain what the dinoplex do exactly? How does it help prevent spark plug fouling?
  3. Slim
    Slim Formula 3
    Oct 11, 2001
    1,735
    Pacifica, CA, USA
    richard
    I don't think it's true that "most owners" don't use the dinoplex. I think most do use it, or a new replacement unit like the MSD 6A which is the same style of capacitative (?) discharge unit like the dinoplex. It helps avoid spark plug fouling at low speeds around town by assuring that there is always a strong spark at the plug. It also allows the points to last longer since they aren't seeing full current but are just acting as a trigger.
    Having said that, when my dinoplex died, I flipped over to "emergencia" position and didn't notice any loss of performance. Nor did I notice any big improvement when I installed the MSD as a replacement 3 months later.
  4. tzucc
    tzucc Formula Junior
    Jun 3, 2003
    316
    what the heck is emergency mode, don't recall seeing that in the manual... let me know, since I may need to use it someday.
    #4948
  5. dm_n_stuff
    Dec 10, 2003
    43,711
    26.806311,-81.755805
    Dave M.
    Dino's have dual ignition systems, a standard coil system, and the Dinoplex system.
    Then when (not if) the Dinoplex fails, you switch to the backup (emergency) system. It's a little switch on top of the dinoplex unit.
    Ignition switch must be in the off position before switching to the emergency ignition system.
    Lots of folks are running happily on the backup system. I believe it may not provide as hot a spark, allthough I may be completely full of crap on that.
    I just seem to recall hearing that somewhere. And that it tends to use up the point faster.
    DM
