Dino 246 Upright Bearing Removal | FerrariChat
Discussion in '206/246' started by racerboy9, Jan 1, 2005.
  1. racerboy9
    racerboy9 F1 Rookie
    2,648
    I am restoring the susupension on my two Dino 246's and would like some tips on removal of the rear upright bearings. I read the thread on 308 upright rebuilds but remain unclear of how to go about removing the Dino's bearings.
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,949
    The Cold North
    Tom
    #2 tbakowsky, Jan 1, 2005
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    308 and 246 are near identical.
    early GT/4 even has the cast iron uprights of a 246, while most GT/4 and all 308 have an alloy unit, they're exactly the same method.
    Series 1 246 and 206 have an external large nut (36mm?), but it does little, you don't even need to undo it, it's just where the hub flange is made as a seperate part to the shaft, later cars have it as one integral shaft.
    Series 1 cars also have a better hub seal, but then unsealed bearings inside. The seal is not good enough so simply order sealed bearings if yours is one of these, and have double the protection!!
    I just did a Series 1 rear bearing job, but the reason was that the internal ring nut was loose. It's a tricky job and you'll need the proper tool to do it tight enough, you may also need to machine/replace the spacer if they've been loose for a while.
  4. racerboy9
    racerboy9 F1 Rookie
    2,648
    I guess my main problem is trying to pull the inner bearing so I can remove the big circlip and spacer and then press out the outer bearing. I have the special nut and drive-flange out and the bearing retainer cap off. Do you try and pull the bearing out with a puller? I can't seem to move the spacer between the two bearings in order to get a spot to press the inside of the inner bearing. Also that would be pushing on the inner race of the bearing which is not good if the bearings are a tight fit.
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    There's no need to move the big circlip.
    The spacer will just move over if you give it a tap with a soft punch. Brass or Alloy is ok.
    Then, just confidently hammer the inner bearing out from the other side. You're changing it anyway, but you won't do any real damage if you use a big hammer and big punch, and only hit it hard a few times, not tickling it 1000 times!!
    For assembly, do it in a press to avoid the shock loads going into the bearing. Once fully assembled, hammer it (soft hammer) from each side to "settle" it all, and it'll run smooth as silk.
  6. racerboy9
    racerboy9 F1 Rookie
    2,648
    Thanks for the help Phil. I plan on reusing the bearings as they are low miles and perfect. I just think they are ready for new grease after 30+ years.
    sturrisi likes this.
  7. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Don't do it. Bearings are quite cheap (about AUD$250 for all 4 including the 2 seals too), there's referance numbers on them and you can get them from any local bearing supplier.
    Also, as I said way back, you can specify modern ones with integral seals which you can fit and forget forever (within reason).
  8. YBB2000CC
    YBB2000CC Rookie
    Aug 29, 2023
    1
    Steven
    Old thread but looking for the stub axle nut torque for the upright. Cannot find it anywhere. Thanks!
