Dino 246Gt Clutch problems (1972) | FerrariChat
Discussion in '206/246' started by patrickvela, Oct 3, 2008.
  1. patrickvela
    patrickvela Rookie
    Sep 13, 2008
    16
    The Clutch is very very stiff on my Dino, it feels like the cable is sticking inside the casing. Can this cable be lubricated, and if so how?
  2. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    take tranny fluid or some other lubricant (wd 40 etc)....pour it in the front part of the cable by the front fire wall and take an air hose and blow it until it drips out of the back. It is possible that when the cable was installed that the casing in the rear cracked and maybe some rust formed....not a tough one to do
  3. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Tom is right on with respect to lubricating the cable.
    If you are in the mood for a bit more work, it is prudent to disconnect the cable from both ends. In the front it is as simple as removing the clevis pin. In the back it requires either removing the air filter housing (to gain access) or crawling under the car. If you can free the cable from both ends, then you should be able to easily slide the cable back and forth in the sheath. If this sticks, then you have your answer.
    However, there are a number of moving parts. The problem can be in the clutch pedal assembly, with rust forming on the pivot pins in the front. It is relatively easy to access these once the front spare tire area is accessed and the fiberglass trim removed.
    If the pedal moves freely without the cable, then it might be in the back in the bell housing, where the throw-out bearing release fork rotates on a pivot ball. If the cable moves freely and the pedal moves freely, then the trouble may well be with the pressure-plate fork and or the pivot ball, or with the helper spring (that large spring hanging from the end-bracket on the cam cover).
    Jim S.
  4. patrickvela
    patrickvela Rookie
    Sep 13, 2008
    16
    Thanks guys, forcing WD40 down the cable with air fixed the problem.
  5. GTA246GT
    GTA246GT Karting
    Oct 23, 2005
    79
    Sweden
    www.dinoparts.de sell an outstanding cable without any friction. Bought it myself and cured the problem.
    Highly recommended.
  6. Fraschetti
    Fraschetti Formula Junior
    Sep 27, 2007
    339
    España.
    Good afternoon Patrickvela.
    Forgive my boldness.
    Were you owner of the Dino 246 GT chassis 04316?
    A friend has purchased it in Spain.
    We would like to know the original color at 1972. Do you know this detail?
    Thanks a lot. Forgive my poor English.
