Dino 308 GT4 Script / Badge | FerrariChat
Discussion in '308/328' started by IAA1963, May 18, 2019.
  1. IAA1963
    IAA1963 Rookie
    Sep 20, 2016
    7
    Hi,
    When I bought my 308GT4, it came without the badge on the rear bonnet. I was searching for a NOS badge for the rear bonnet for quite some time. Now I have the correct one, but I don‘t know the exact mounting position as the two holes are gone. So would be great to get some infomation regarding the original mounting position.
    I will mount the Dino GT4 Badge only. I will not add the Ferrari script. I think this is correct for a 1976 model, right?
    Thank you,
    Mark
  2. del.gil
    del.gil Rookie
    Jul 30, 2010
    23
    Paris
    Normally, you should add « Dino308gt4 », no?
    Did you try to use a high power light inside the bonnet to be able find the 2 holes with the transparency of the paint?
  3. absostone
    absostone F1 World Champ
    10,033
    look from inside the trunk
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I had the same issue. I peeled the covering from the inside of the trunk lid and could find the Bondo squishing out from the original holes. I drilled from the inside out to put the holes back in.
  5. IAA1963
    IAA1963 Rookie
    Sep 20, 2016
    7
    I have removed the cover inside the trunk, but I do not see the former holes from the badge.
