Dino Compagnolo Wheel Valve Stem | FerrariChat
Discussion in '206/246' started by Hondo, Aug 30, 2024.
  1. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    I have a 1974 246 GTS with wide campagnolo wheels 14 X 7.5 and I am looking to replace the Valve Stems.
    The problem is the standard valve stem replacement is for the narrow wheels and is too small. I have tried Superperformance and said to try Ferrari Chat so here I am! I would appreciate any help.
    Thanks!
  2. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    Welcome to Fchat.
    I moved your thread to the very knowledgeable Dino section, as I expect you will have more response there.
    swift53 likes this.
  3. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
  4. pshoejberg
    pshoejberg Formula 3
    1,831
    Denmark
    Peter H
    Is that the original valve stems you are swapping out with aftermarket stuff (Or trying to swap)?
    Best, Peter
  5. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Yes these are the original valve stems as far as I know. I can replace the inner air valve but the bottom rubber is shot. I never anticipated having a problem getting a whole new valve stem . Venders advertise this as a replacement for the original ones that will fit Compagnolo wheels but they are too small for the wider flared wheels. I could try to make new seals but the bottom rubber is stepped to fit the wheel hole.
  6. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    same problem with datonas.
    go to a large tyreshop and see where they get theirs.
    it will probably a truck that goes around all the tyreshops.
    you only need the rubbers the rest you can get re plated
  7. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
  8. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Thanks! I have run into a dead end. The inner valve is pretty standard. I guess at this point I will try making some rubber washers to see if they will hold air. Most of the wheels nowadays use pull through rubber valve stems. Tried contacting Compagnolo but no response.
    Ed Greene
  9. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    I found some for a set of original Minilites that had a 12,5mm hole.
    If only I remenbered where...
    I will try to find the source.
    Regards, Alberto
  10. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Thanks, I appreciate any help.
  11. pshoejberg
    1,831
    Denmark
    Peter H
    Do your outmost to keep the original stems for historical reasons. Some day you’ll thank yourself for doing that. Get them re-chromed and get someone to engineer a new set of seals + retainers for them. I’m surprised if someone on f chat havent engineered a solution already?
    You’re in the right forum for sure - hopefully someone will chime in soon. Good luck with the project.
    Best, Peter
    Sergio Tavares likes this.
  12. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    #12 swift53, Sep 1, 2024
  13. gcalex
    gcalex Formula Junior
    607
    Mostly New Hampshire USA
    Alex
    Oh man, I was so furious when a shop "lost" my original stems. (quotes, because I'm still not 100% sure that they did not lift them to put them on a "more important" car...)
    pshoejberg and Sergio Tavares like this.
  14. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
  15. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
  16. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Thanks so much, they look like what I need. I might be able to use the washers they come with to complete my originals! I will post my results as it may help others!
    swift53 likes this.
  17. Edward 96GTS
    Edward 96GTS F1 World Champ
    BANNED Silver Subscribed
    Nov 1, 2003
    11,097
    does manual show details?
  18. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    Edward,
    Glad to help! Besides, the cost is low and delivery is quick.
    Please do let us know.
    Howard, they may be functional for Daytonas too...
    Regards, Alberto
  19. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    brilliant Edward, have see before bu had forgoten
  20. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    apologies I meant Alberto.
    Thanks Alberto !!
    swift53 likes this.
  21. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Nice information. Did the later stems still have stampings? My are from my 1974 Dino. Thanks for your input.
  22. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    #23 Sergio Tavares, Sep 2, 2024
    your style tried is for early Dinos, for later there is the stem cap seal
    For 1974 the stem ferule on new stem image is wrong position in your figure #2, please turn it upside down.
    example:
    https://awitalian.com/product/ferrari-tire-valve-174166.html/
    or at tire hardware
    https://tirehardware.com/product-category/tire-valves/
    only $1.56 complete , .453 & .625 rim holes
    even if you only need a seal is great value
    https://tirehardware.com/shop/chrome-1-25-performance-specialty-valve-tr416/
  23. Hondo
    Hondo Rookie
    Jan 16, 2022
    20
    Edward Greene
    Thanks for the info. I am amazed at the responses I have received. They are very much appreciated!
    pshoejberg and swift53 like this.
  24. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Did all go OK?
