Dino DIY - Refreshing my 1973 246 GTS | Page 2 | FerrariChat
Discussion in '206/246' started by synchro, Jun 9, 2008.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #26 synchro, Aug 21, 2008
    Now that all the bolts are out, there will still be a bit of tension in the mounting. You can rotate the whole A-arm and pull but I found some light tapping with my rubber mallet was required to remove the A-arm. Once free, note its location then replace all bolts in their exact location.
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #27 synchro, Aug 21, 2008
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #28 synchro, Aug 21, 2008
    The Driver's side suspension has now been removed, repeat for the Passenger's side.
    Once the Passenger's side torsion bar mount has been removed, it can be pulled through the suspeniosn area and removed from the Dino.
    So far, the tasks have not been complicated - just turning wrenches and removing parts.
    See how easy a DIY can be!
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #29 synchro, Jan 8, 2009
    Now that the front suspension is off and the tie rods are exposed, the steering rack can be removed.
    NOTE: Examine the inner tie rod ends for tightness.
    Many people are familiar with the outer tie rod end where it connects to the front control arms, but the inboard tie rod ends are just as important and often overlooked. The Inner Tie Rod ends are inside those large rubber bellows and allow the arms to rotate downwards to control steering. With the outter tie rod end disconnected grab it and rotate the whole steering arm to a new position and let go of it - if the arm stays in that new position and does not fall down then they are tight enough to be considered good. If a control arm flops downward and requires assistance to be held in an up position then it is warn and is no good (or at least needs adjusting)
  5. swift53
    swift53 F1 Veteran
    8,489
    E.S.
    Alberto
    I am in need to open up my steering rack, yet lack the know how. I feel I must perform this procedure as
    my "L" is of an unknown past. The inner rod ends do not flop down, so at least that's good.
    As I have never driven the car, I do not know how the rack is, so I would much rather go through it now.
    Does a workshop manual exist, you know, the kind that goes through the complete dis-assembly and re-assembly of
    everything including engine and transaxle?
    Thanks for the great details of your teardown!
    Regards,
    Alberto
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #31 synchro, Jan 14, 2009
    Before the steering rack can be removed, the steering link shaft must be loosened and pulled away from the rack to allow space for the whole rack to be pulled back from the chassis. The steering link shaft is a rod with splined ends to connect on both ends with securing clamps. On the upper end it connects to the steering U-joint and the bottom end it attaches to the steering rack stub.
    Find the upper clamp in the spare tire compartment area by the brake booster and clutch cable. Remove this top clamp first by pulling the cotter pin from the castle nut and use two 11mm wrenches to loosen the clamping nuts. Spread the cfamp collar to allow the shaft to have upward play when you do the next step, removing the bottom clamp to free the shaft
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #32 synchro, Jan 14, 2009
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #33 synchro, Jan 14, 2009
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #34 synchro, Jan 14, 2009
  10. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Great info and photos!
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #36 synchro, Mar 9, 2009
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #37 synchro, Mar 9, 2009
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #38 synchro, Mar 9, 2009
    The bushes are not required to be saved BUT the front spacers must be re-used or replaced, so be sure to retain them.
    Once all the parts have been gathered, I sent them out to be powder coated in gloss black. Local shop "Powder Visions" does a great job and they came back so shiney that it tempoarily blinds me and I miss the photo focus of two of the A-arms and only show six in the photo.
    Total cost for powdercoating: $200 USD
    ..., but I told them it was for a FIAT!
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #39 synchro, Mar 9, 2009
    My steering rack had a torn boot, which could mean it needed a lot more than that so I started looking around for a specialist and stumbled onto a fellow club member (jh355) who owns his own medical engineering and manufacturing company. He has such a great passion for his Ferrari's and Bentley's that he's put a great amount of time and labor into them to investigate and diagnosing the issues of refurbishing. He has created some special tooling and performance processes for rebuilding them. One of his specialties are steering racks and he did an absolutely fantastic job. Highly recommend his craft.
    His opinion is that steering racks are one of the most critical components of Ferraris but are often overlooked.
    Read his exact words in post #7 onward:
    http://www.ferrarichat.com/forum/showthread.php?t=192248
    I asked and he gave me permission to print his contact info:
    STEERING RACK REBUILD: [email protected]
  15. rynoshark
    rynoshark Formula 3
    1,035
    Pacific Northwest
    Wow, great stuff Scott. Thanks for posting and including all the details on local suppliers.
  16. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,919
    Atlanta
    John!
    great thread. I am doing the same thing this spring. this helps a ton!!
  17. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Great job Scott. Brings back memories or nightmares not sure which. You got me motivated to start on my 73 coupe soon. THANKS?
  18. ferrari sulla pellicola
    ferrari sulla pellicola Formula Junior
    Jun 21, 2004
    621
    Los angeles
    Richard
    just read this thread and stoked to see youve discovered all its provenance!maybe i shouldve sold it to you for more money back then!!as for our Dino we've pulled out the complete interior and in the process of restoring it.the drag is i wont be able to have as much fun in the car with a perfect interior as we had on our desert run but at least i wont be ashamed to have it at shows!
  19. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #44 synchro, May 3, 2009
    Took some time out to finish the new home's garage. Removed the 2x4 shelves and bought a really nice quad set of Griot's stackable storage cabinets (each shelf within can hold 400 lbs), followed up with three Griots tool cabinets and a 12 foot wide 1.75" thick butcher block work benchtop. Way expensive but well worth it for being organized and able to find ANY tool when you need it. Each of the 21 tool drawers have big space for edge labels. Painted the walls semi-gloss, acid etched the floor then painted with epoxy and trimmed out the edge with black molding.
    Gary R turned me onto the longitudinally ribbed vinyl mats as a GREAT way to keep the floor clean. Found teh best place for these mats at American Garage Floor:
    http://www.americangaragefloor.com/blt-garage-floor-ribbed.php
    Invited over a bunch of friends and "Il Maestro" Sig. Carlo Durante who kept opening the tool drawers, smiling and voicing his approval "I like!"
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #45 synchro, May 4, 2009
    With the steering rack rebuilt it is now time to address the steering rack mounts. These are important because they are a main contributer to driving feedback isolation.
    They have bushes pressed into a cylindrical hole that was drilled only to a set depth resulting in a hole that does not go all the way through the half-moon shaped clamp making them rather difficult to remove. The other end has a reduced diameter meaning that when you try and push them out you can only push the inner "race". A hydraulic press only forces the inner part of the bush and some of the vulcanized rubber leaving the outer metal diameter still firmly embedded in the steering rack mount.
    The photo shows the mount with the old bushing still inside and a new Superformance bushing adjacent to it. I want the old one out and the new one installed.
  21. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #46 synchro, May 4, 2009
    I was stumped at this point and wanted to avoid damaging the interior wall of the mount so I called a friend, John H, who has some great equipment for his business; half a dozen Haas brand six axis CNC, numerically controlled, milling machines. When I told him the problem he said, "sounds fun, come on over!"
    He stopped his production line to lathe up a "pushing shaft" tool of the correct diameter to remove the inner portiion of the bushing, then set the mounting clamp in the CNC machine and precisely drilled out the outer bushing. Once the old was out, he pressed the new bushing in chasing it all the way down with a sized dowel tool he made. Last two photos show completed assembly with pushing dowel tools in rear, right. If he doesn't have a tool to do something, he just makes one!
    Now I'm ready to go and Dino #05702 will be steering tight now.
    Thank you John H. !
  22. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Scott,
    Congrats on the garage improvement. A word of caution, tho: Don't get too organized or you won't be able to find anything! That's my excuse for the disarray in my garage.
    Whenever I get motivated to clean up the mess, it looks great, but I can't find my stuff! How about some more pictures of the new Dino habitat?
    At any rate, thanks to you & John H. (from the looks of that jacket he's wearing, it's still a mite cold in your neck o' the woods) for showing us the way on the rack mount. I don't have access to that sophisticated machinery, but the process will be similar with my primitive tools.
    It's amazing how relatively easy some of these projects are when someone else takes the leap & shares the venture with the rest of us.
    Kudos,
    Coop
  23. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #48 synchro, May 9, 2009
  24. TKO
    TKO Formula Junior
    Oct 22, 2004
    790
    SoCal
    Tom Kearns
    Scott,
    Great project. Have you made more progress or got it back together again? I can't wait to hear your observations on how the car handles and feels compared to before.
    Cheers,
    Tom
  25. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #50 synchro, Jun 18, 2009
    I'm at a crossroads and may go deeper than originally planned (..and to think this all started with a hung up left brake caliper)
    Seeing Chanptc and OMGjon's projects make it look so rewarding and compelling.
    The real kicker is that I'm having a difficult time finding a paint shop that can do it. The local shops are either booked up for years or have not ever done one before. I've found one a long ways away that has done platinum level workon Dinos and is decently priced, but the distance makes it tough.
    After seeing many Dinos with paint bubbling at the edge where the flying buttress exterior meets the rear quarter panel, I think this area needs special attention of brazing.
