Dino Door Handle | FerrariChat
Dino Door Handle
Discussion in 'Technical Q&A' started by premieram, Jul 4, 2005.
  1. premieram
    premieram Karting
    Jun 10, 2004
    216
    All over the place
    Joseph T. Seminetta
    Hi all:
    I hope everyone is having a good 4th of July.
    I did an "oops" the other day. I pulled the door handle to my 1973 Ferrari 246 GTSi a bit aggessively when the door was locked. Now the handle is stuck "flying" in the out position. The door will still open and close but it looks a bit silly.
    Any thoughts on how to fix this? I assume I have to remove the interior door panel but I am affraid of what I might find :)
    Thank you in advance for your help.
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    I think you should be OK. Just unscrew and remove the pannel. Odds are you bent a connecting rod/wire that with a little care and more time than you think it will take can be bent back into shape.
    It it were the door handle I think it would have just broken off. Chromed pot metal if I remember correctly.
    Drew Altemara
  3. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Funny thing about the Dino 246, if you lock the door and then try to open it too hard, you can break the small cable actuating the latch. I did this and used aircraft stainless cable for a little more strength. Lube it well as it follows in a little "L" shaped tube and can become frayed if it drys out. Kind of a tough little job if I remember right.
