Dino door lock mechanism | FerrariChat
Discussion in '206/246' started by tx246, Sep 25, 2005.
  1. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    #1 tx246, Sep 25, 2005
    The passenger side door lock on my dino would simply rotate freely when the key was placed in it. i took the door apart and there appears to be a grommet that attahces to the actual locking mechanism on one end and to the tumbler via a small mounting point on the back side of the tumbler. obviously, there should be something that holds this in place. looking in the dino parts guide , it is shown as item 45 and 46, or part number 0200373 and 0200359. my parts guide is in italian. can someone help me with what these are called and a possible source?
  2. dm_n_stuff
    Dec 10, 2003
    43,711
    26.806311,-81.755805
    Dave M.
    Have you tried a locksmith??
    Dennis McCann doesn't have these. Is it simply a bushing and an internally threaded bolt?
    Hard to tell from the picture, and I haven't had mine apart.
    The mechanism is used in a bunch of cars from that era. Porsche, Alfa, Volvo, VW and BMW.
    Try these guys.
    http://www.swedishtreasures.com/1201.html
    oh, on the parts.
    45 is a bushing - bocolla
    46 is not translatable, at least not in my limited Italian Parts list in my head.
  3. Kliz
    Kliz Karting
    Mar 6, 2005
    77
    #3 Kliz, Sep 25, 2005
    I R&R'd the driver door lock/latch mech. as well as the power window sys. a couple yrs ago and recall that the lock cylinder had a ball-end stud that the latch arm fit over.
    The #45 was a thin nylon ? washer/bushing with an ID slightly smalled than the ball-end so it had to be pressed over the ball, holding the arm in place. The assembly was locked on the ball-end with a Circlip of the appropriate size compatable with the thickness of the washer.
    I'm not sure this was the original setup but it works fine. It's very hard to tell what these parts really look like from the parts manuals. I would think a nylon washer with the appropriate ID and thickness could be found at the local Ace Hardware. Circlips are readily available.
    Hope this helps you!
    Bill
  4. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    #4 John Corbani, Sep 25, 2005
    Had the door apart when I read your post and shot this pic. Lock comes out easily. Just loosen the nut.
    Actuating arm is held on lock by circlip. Nylon washer is between arm and circlip.
    Arm is attached to latch mechanism by a nylon clip. Can be freed with fingers but finding the exact point to push is a trick. Once you get everything out, fixing is easy.
    Make sure you mark and write down the exact angular position of lock and the key position BEFORE YOU REMOVE THE LOCK. Makes life easier when replacing. Don't ask me how I know.
    Good luck.
  5. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    john and bill,
    thanks for the pics and info. does anyone know what size circlock is needed? that will definitelt solve the locking problem i am having.
  6. Kliz
    Kliz Karting
    Mar 6, 2005
    77
    Sorry! I neglected to measure the Circlip when I had it out - it's probably metric but you can take the whole mech. to Ace and maybe find a combo that'll work. If not, a specialty hardware like McMaster-Carr has large selection of various retainer rings ( www.mcmaster.com. ). They would even have the nylon washers.
    If you have calipers, measure the OD of the ball-end. A retainer with an ID that is smaller but large enough to allow room for the washer should work.
    Glad you didn't get hit too hard by Rita!
    Bill
  7. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    alright, to show my stupidity, i went to home depot looking for a circlip, abd they looked at me like i was nuts. are these know by another name, or do i need to go to an auto parts store?
  8. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    is the "circlip" a retaining ring?
  9. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    Shawn,
    "E-clip" is the name more often used. I go to our local ACE hardware store to buy all the metric hardware I need. The have an unbelievable assortment of metric hardware. They even have stainless steel and some hardened washers / lock washers.
    Regards,
    Richard
  10. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    On a side note, "Snap rings" are the other common type of retaining ring. There are internal and external "snap rings". I am in the process of rebuilding my distributor and it uses an external snap ring for the lower bearing and I will be using an E-clip for the upper bearing. E-clips come in metric and SAE sizes. E-clips look like a circular "E".
    Richard
  11. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
  12. Kliz
    Kliz Karting
    Mar 6, 2005
    77
    To my knowledge, Circlip has been the generic term used for all circular type retainer rings. Getting more specific, there are Snap-rings, E-Circlips, C-Rings, K-rings, U-rings and many others. All are intended for slightly different applications.
    I believe, for this particular application, the E-Circlip or the U-Ring will work best. They can both be pushed onto the Ball-shaft with your finger or the blade of a screwdriver without the need of snap-ring pliers. The U-Ring has a longer lead-in and is easier to install in tight places but may be more difficult to source at Ace Hardware.
    Bill
  13. Bryan
    Bryan Formula 3
    Shawn:
    both Ace Hardware and Home Dept have large selections of SAE and metric hardware. I have found e-clips, snap rings (little holes at each end that work with special tools to open and close), and c-clips in the drawers.
  14. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Wow, what a blast from the past. I don’t remember this thread at all.
    Shawn
  15. daviekj
    daviekj Formula Junior
    486
    I purchased the white door lock bush from Superformance. However, I had to file both flats down from 4.5mm to 3.0mm to reduce the thickness to enable the e-clip to insert.
    My original e-clip is split and not ideal. I have normal e-clips with correct ID but nothing with an OD large enough that prevents the locking arm from coming off. Any source suggestions from those have worked this before?
    Kevin
    UroTrash likes this.
  16. daviekj
    486
    Also a few tips if anyone need to adjust their door lock. If doing with door open, you will need to rotate the door locking disc to the closed position (naturally it will be in the open position) to allow the locking arm t0 drop.
    After cleaning and oiling, the mechanism works rather nicely.
  17. swift53
    swift53 F1 Veteran
    8,273
    E.S.
    Alberto
    I find it funny that Ferrari would use the TM name of a German component, a SEEGER® ring :)
    Very punctilious, or?
    Regards, Alberto
    TTR likes this.
